I tried to load the BikeModel3D file, which was created from the
AnyBody group, from the repository.
If I load the model, allways I recieve the follow message:
MinMaxNRSimplex : Unresolved object
I tried to change MinMaxNRSimplex to MinMaxSimplex, so I could see the
model but I couldn´t do the InverseDynamicAnalysis.
The models in the repository require version 1.2 of the system to
run, and this is the reason why you are getting the error message.
The MinMaxNRSimplex is a more robust optimizer we added to the
system after version 1.0 was released.
This is only the executable file of the anybody system, and after
you unpack it, you should move it into the directory where AnyBody
was installed and let it replace the anybody.exe file that is
already there.
The first time you start the system, it will ask for the license key
again. Simply provide the same license key as you used for version
1.0.
Best regards and good luck with the bicycle model.
John, AnyBody Support.
— In anyscript@yahoogroups.com, “jrgleemann” <jrgleemann@y…>
wrote:
> Hi John
the
> Please could you help me?
> Best regards,
> Jürg
