Dear AnyBody team! ![]()
I'm currently working with the new thoracic spine model with volumetric elements to simulate subject-specific sagittal spinal alignment profiles.
The model works really well, however I have some 'constraint above tolerance' errors in some cases, i.e. when the subject's posture causes the rib cage 'sinking' into the volumetric structures.
I'd like to modify some of the drivers in the rib cage so that it does not sink into the abdomen. So my question is, which drivers should I change to "raise up" manually the ribcage?
So far, I gave it a try by changing the Pos value of this driver: Main.HumanModel.BodyModel.Trunk.Joints.RibCage.Manubriosternal.driver
AnyKinEqSimpleDriver driver = {
AnyKinMeasureOrg &ref=.ManubriosternalJointMeasure;
DriverPos ??= {2};
DriverVel ??= {0};
CType ??= {Hard};
Reaction.Type = {Off};
As a result (see the screenshot below), the ribcage has lifted, however, something strange happens to the first rib and the sternum seg. ![]()
Could you please provide me some advice on how to solve this problem?
Thanks a lot!
Cheers,
Alice
