Role of fps in analyses
Hi!
Suppose that I have perfect c3d file with small parameter frames per second, equals 60. Will it be enough to exact analyse of fast motion, like jumping?
hard to answer. I would recommend a little higher frame rate. It really depends on the motion. But you should also be aware that the muscle recruitement in the AMS is based on the assumption of a skilled, controlled motion. For many very fast motions this may not be the case.
Sebastian
