Aline
(Aline Van Oevelen)
February 7, 2024, 11:34am
1
Dear AnyBody community
I am experiencing problems with executing the inverse dynamic function of my AnyBody model step by step (F6 in AnyBody) through Python.
I tried the following macro command in which I reload the main.any and include every time one additional step:
macro = [
'load, "Main.any" '
for i in range(0,11):
macro.append(
'operation Main.RunAnalysis.InverseDynamics "step" ',
Knee_JRF = app.start_macro(
macro,
folderlist,
search_subdirs=r"\Main.any",
logfile="BatchProcessingLogs_JRF/RunAndSave.txt",
However the "step" is not executed correctly.
Additionally, I want to extract in every position (thus every step) the stl of femur and tibia. I tried to save these stl using the following macro command:
macro_save1 = [
'classoperation Main.HumanModel.BodyModel.Right.Leg.Seg.Thigh.Drw3 "Export surface" --file=Femur.stl" --scale=1 --reference=global ',
'classoperation Main.HumanModel.BodyModel.Right.Leg.Seg.Shank.DrwSurfTibia "Export surface" --file=Tibia.stl" --scale=1 --reference=global',
However, the saving is canceled.
I want to thank you in advance for helping me with this!
Aline Van Oevelen
melund
(Morten Enemark Lund)
February 8, 2024, 9:49am
2
Hi Aline
I don't think I have heard about anyone doing something like that I will try it myself, and get back to you.
There may be some work-arounds if the "step" operations can't be interleaved with the export. But let talk about that when I have taken a closer look.
Best wishes,
Morten
melund
February 8, 2024, 12:00pm
3
Hi Aline
It think it should work. I tried on small toy example and the following python code worked for me:
Hope it makes sense.
import anypytools
def export_macro(obj, filename):
macrostr = f'classoperation {obj} "Export surface" --file="{filename}" --scale=1.0 --reference=global'
return macrostr
macro = [
'load "Demo.arm2d.any"',
'operation Main.ArmModelStudy.InverseDynamics',
'step','step','step', # These first 3 steps are initial conditions
'step',
export_macro("Main.ArmModel.Segs.LowerArm.PalmNode.DrwSTL", "out-0.stl"),
'step',
export_macro("Main.ArmModel.Segs.LowerArm.PalmNode.DrwSTL", "out-1.stl"),
'step',
export_macro("Main.ArmModel.Segs.LowerArm.PalmNode.DrwSTL", "out-2.stl"),
'step',
export_macro("Main.ArmModel.Segs.LowerArm.PalmNode.DrwSTL", "out-3.stl"),
'step',
'step',
'step',
'step',
'step',
'reset', # This final reset seems to be necessary to avoid an error message when AnyBody Shuts down
print(macro)
app = anypytools.AnyPyProcess()
app.start_macro(macro)
Aline
(Aline Van Oevelen)
February 9, 2024, 8:43pm
4
Hi Morten
Thank you for helping me out!
I had to adapt one line of your code in my script to make it work:
'operation Main.RunAnalysis.InverseDynamics',
Best wishes
Aline
system
(system)
Closed
June 13, 2024, 8:44pm
5
