During run analysis I am facing error in kinematics analysis now. Can you help me sort it out, I have attached the error as image
Hi Harshini,
It seems like the most probable cause for your error is large difference between the load time position of the mannequin and the initial position from the mocap data. Can you try to position the mannequin closer to initial position of the mannequin data?
