Hello
Is it possible to run the output files that i received from inverse dynamic analysis, because i have many models and i have output data of them stored as anyset , anydata.h5 and txt formats. I dont want to run my analysis again to see my graphs. is it possible that i just load these values somehow back into anybody to view the chart view ?. is this also possible with model view ?.
Hi Bharathhns,
Yes this is possible, for a mocap model this is a built in operation sequence called "LoadAndReplay" it will also allow you to see results.
