Hi, I want to save some results to csv files.
So I am studying Anypytools tutorial.
but It doesn't work and I don't know why it gives the error.
Here are my code and error message.
Completed: 0, Not processed: 1
ImportError Traceback (most recent call last)
C:\Anaconda3\envs\py37\lib\site-packages\anypytools\abcutils.py in start_macro(self, macrolist, folderlist, search_subdirs, logfile)
773 try:
--> 774 with tqdm(total=len(tasklist), disable=self.silent) as pbar:
775 for task in self._schedule_processes(tasklist):
C:\Anaconda3\envs\py37\lib\site-packages\tqdm\notebook.py in __init__(self, *args, **kwargs)
238 total = self.total * unit_scale if self.total else self.total
--> 239 self.container = self.status_printer(self.fp, total, self.desc, self.ncols)
240 self.container.pbar = self
C:\Anaconda3\envs\py37\lib\site-packages\tqdm\notebook.py in status_printer(_, total, desc, ncols)
112 raise ImportError(
--> 113 "IProgress not found. Please update jupyter and ipywidgets."
114 " See https://ipywidgets.readthedocs.io/en/stable"
ImportError: IProgress not found. Please update jupyter and ipywidgets. See https://ipywidgets.readthedocs.io/en/stable/user_install.html
During handling of the above exception, another exception occurred:
AttributeError Traceback (most recent call last)
<ipython-input-10-00ae1bb65ffb> in <module>
----> 1 app.start_macro(macrolist);
785 finally:
786 if not self.silent:
--> 787 tqdm.write(tasklist_summery(tasklist))
788
789 self.cleanup_logfiles(tasklist)
C:\Anaconda3\envs\py37\lib\site-packages\tqdm\std.py in write(cls, s, file, end, nolock)
621 # Write the message
622 fp.write(s)
--> 623 fp.write(end)
624
625 @classmethod
C:\Anaconda3\envs\py37\lib\contextlib.py in __exit__(self, type, value, traceback)
117 if type is None:
118 try:
--> 119 next(self.gen)
120 except StopIteration:
121 return False
C:\Anaconda3\envs\py37\lib\site-packages\tqdm\std.py in external_write_mode(cls, file, nolock)
648 # Force refresh display of bars we cleared
649 for inst in inst_cleared:
--> 650 inst.refresh(nolock=True)
651 finally:
652 if not nolock:
C:\Anaconda3\envs\py37\lib\site-packages\tqdm\std.py in refresh(self, nolock, lock_args)
1349 else:
1350 self._lock.acquire()
-> 1351 self.display()
1352 if not nolock:
1353 self._lock.release()
C:\Anaconda3\envs\py37\lib\site-packages\tqdm\notebook.py in display(self, msg, pos, close, bar_style, check_delay)
161 msg = self.format_meter(**d)
162
--> 163 ltext, pbar, rtext = self.container.children
164 pbar.value = self.n
165
AttributeError: 'tqdm' object has no attribute 'container'
Can data save as csv or pandas dataframe?
Or I want to save some simulation results as one h5 file.
and How do I separate columns when one variable contains three values, such as marker acceleration values?
Thank you for your help.
