Hello, I have a problem with saving files. When I’m trying to save the
Main files, it always gives the same error (ERROR SCR.PRS1, object
already declared at…). Even when I remove the whole repository from
the computer and try to save the file again. Does anybody have an idea
how to solve this problem? Thanks in advance.
This looks like a loading error, not a saving error. Typically this
occurs when you load a model and you have declared two times the same
object in different parts of the script.
Does the error occurs when you save the model using the button
File/Save As or when you load it using the icon “Load Model” on the
window of the Main file?
Please give us more details on the manipulation you made, and please
give us the full error message so we can have a better idea of what
is happening.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “loekvanderheide”
the
from
idea
> Loek van der Heide
is happening.
“loekvanderheide”
the
from
idea
> Loek van der Heide
Thanks for the fast reaction. I was creating a New Main file, and
this is the whole error:
ERROR(SCR.PRS1) : D:\Repository.7\Repository7
\Application\Wrist\Wrist.Main.any(39) : ‘MyWrist’ : Object
already declared at :
D:\Repository.7\Repository7\Application\Wrist\Wrist.Main.any
(8) : ‘MyWrist’
Model loading skipped
Even when I save the file with a different file name, AnyBody gives
this error. And when I click on the error, both files direct to the
same workspace, which is the file I was trying to load.
The error also occurs when I’m saving the file (save as…) before
loading. I have no idea what I did wrong.
Loek van der Heide
wrote:
> Hi Loek
> Just a small addition…
> If you click on the error message, it will direct you to the two
locations
> where you have objects with identical names.
> Best regards
> Søren, AnyBody Support
> _____
> From: anyscript@yahoogroups.com [mailto:anyscript@yahoogroups.com]
On Behalf
> Of AnyBody Support
> Sent: 03 June 2008 09:57
> Subject: [AnyScript] Re: Saving Main files
> Hi Loek,
this
same
the
please
what
> is happening.
> Best regards,
> “loekvanderheide”
save
> the
object
repository
> from
an
> idea
> > Loek van der Heide
> (8) : ‘MyWrist’
gives
the
> Loek van der Heide
> wrote:
> > Hi Loek
> locations
> > Best regards
> > _____
> On Behalf
> > Of AnyBody Support
> > Hi Loek,
> this
> same
> the
> please
> what
> > is happening.
> > Best regards,
> ps.com,
> > “loekvanderheide”
> save
> > the
> object
> repository
> > from
> an
> > idea
> > > Loek van der Heide
