Scaling model
i have two different human models and mow i want to scale the
AnyBodymodel to the size of the other one. My first problem occurs at
Pelvis Scaling. What is the Pelvis Width needed for? The joint nodes
were defined by coordinates and not calculated by Pelvis Width. So
what will i have to scale, the Width, the Coordinates or both? I think
for scaling the Coordinates i have to use the predefines Scaling
Functions, but all Coordinates reference to “Scale” while the
scalingfunction herself is named “ScaleFunction”. How should i
understand this?
Best regards, Maren
Hi Maren
The Pelvis width sets the distance between the hipjoints. You should in
general not change the sRel value of the HipJoints nodes. The scaling
assumes that the standard distance between the hipjoints are of a
certain size, so the model knows its standard hipwidth and use the
hipwidth provided by the user to scale the hipjoint nodes so that a
certain hipwidth is obtained. If the HipJoint nodes are moved and you
at the same time scales the model you will do two changes at the time.
It is correct that all coordiates in the model have a Scale function
applied to them. It normally just says “Scale”, but if you look in the
top of the segments you will find a reference to a scale function for
that particular segment.
Please ask again, if you have further questions.
> Hi,
> understand this?
> Best regards, Maren
Hi Soeren,
i found the reference of “Scale”.
For the Hipjoint i changed “Width” under StandardParameters and
additional i defined a scaling factor, because the jointnodes of the
hip are defined with scaling. Is this correct? For your information,
it is the seating model from the repostiory.
Thank you, best regards, Maren.
> Hi Maren
> Best regards
> — In anyscript@yahoogroups.com, “Maren” <anystarter@> wrote:
> > Hi,
> > understand this?
> > Best regards, Maren
Hi Maren
I am not sure i understand 100% the changes you made. I think it
would be best not to change the scaling in the BRep. Basically by
making changes in the BRep all model will be influenced.
By changing the “pelviswidth” value in your scaling file (something
similar to AnyMan.any) it should change automatically the pelvis
width, (making use the the standard pelviswidth) this should be
enough to control the pelvis width. The Gait3D model is a good
example on how the scaling works.
Please write again if you have further questions.
> Hi Soeren,
wrote:
> > Hi Maren
should in
scaling
the
a
you
time.
function
in the
for
> > Best regards
> > > Hi,
occurs at
nodes
So
I think
> > > understand this?
> > > Best regards, Maren
