Dear Iqbal
Q1:
I am not sure i entirely understand the first question; i will try to
explain how it works.
In the spine model there are 6 spherical joints in the lumbar region.
Instead of having to driver each of these dof a “spine rhythm” has been
implemented this rhythm links the dof together so that the only remaining
dof left is the rotation between thorax and pelvis. These are the angles you
can specify in the mannequin file.
So in terms of flexion you can not specify more angles than the
PelvisThoraxExtension angle. If this is not suitable for your model you
will need to switch of the Spine rhythm in the
BRep/Aalborg/Spine/JointsLumbara.any file. This will give 100% freedom of
the motion of the lumbar region, the drawback is of course that you need to
drive the three dof of each of the joints to make the model kinematical
determined.
Q2:
The values in the Mannequin.any file can be used for two things.
To calculate initialpositions at load time (this is what you saw)
For driving the model when running an analysis. Most models to not
use all the values in the Mannequin when the analysis is running. In the
case of the seatedhuman the chair a connection between the backrest and
thorax drives the flexion/extension of the spine not the Mannequin. It is
only the FreePosture models where all dof in the model are driven directly
by the mannequin values.
Q3:
Yes there is a contact the definition of this can be found in the file
Support.any, the friction coefficients can be found in the top of the
SeatedHuman.main.any file.
Please ask again if you have further questions
Of javed377
Sent: 02 November 2007 17:22
Subject: [AnyScript] Re: Section Forces in Spine
Dear Soren,
Thanks for you cooperation.
1.To calculate the forces for a standing positon in flexion i have
used the standing model and then drove the pelvisThorax angle.But its
the angle between pelvis and Thorax and i need the flexion in Lumber
Spine.How i can relate the Flexion of Thoracic Spine with Lumber
Spine if i have pelvisThrox angel of -60 degree?I mean what is angle
for Lumber Spine if i have pelvisThrox angel of -60 degree.
2.In SeatedHuman Model,when i changed the pelvisThorax angle to -20
degree,firstly it there was flexion but when i run the InverseDynamic
Analysis it came back again in sitting position and the Forces were
same like i have in the Seated Model.
3.Can you tell me is there contact between Spine and Back of the cahir
in the SeatedModel and if there is contact then what is the
coefficient of friction?
With best regards.
Iqbal
“AnyBody Support” <support@…>
wrote:
> Hi Iqbal
> Even if the Mannequin.any are the same it is not certain that the
> postures are the same, I will try to exaplin why:
> The standing model is driven only partly by the settings in the
> Mannequin.any file, the freeposture model is driven 100% by the
> mannequin.any file. In the standing model there is as i recall it a
> center of mass driver that ensures that the center of mass of the
> entire model is placed above the ankles.
> The angles in the Mannequin.any file is used at load time to set the
> initial positions and for driving some of the dof in the model once
> you run the kinematic analysis.
> To calculate the forces for a standing positon in flexion i would
> use the standing model and then drive the pelvisThorax angle to
> obtain the wanted postures of the spine and read out the compression
> forces as the values i mentioned in a previous answer.
> If you want to the same for a seated person i would start using the
> SeatedHuman model. This is a seated person with the proper boundary
> conditions.
> I hope this helps you move on otherwise please write again.
> Best regards
“javed377” <javed377@> wrote:
> > Hello Soren,
> > Thanks for your guidance.
> > Firslty As you told that posture have large effect on Reaction
> > foreces,i have check too.But i have checked with FreePosture model
> and
> > Standing Model,they have difference of about 100N with every thing
> > same in Mannequin.any file,even i changed the load equal to zero in
> > Standing Model.
> > Please let me know what the reasons may be.
> > Seconly, i want to calculate the Forces with the
> Flexion,Compression
> > and Lateral Flexion of Lumber Spine in standing position.Can you
> tell
> > me how to do it?
> > Thirdly,the same forces i want to calculate in sitting postion.Can
> you
> > tell me how to add a support(like Chair)in the Model.
> > What you suggest should i use FreePosture or Standing Model for the
> > above purposes?
> > With best regards.
> > Iqbal
“AnyBody Support” <support@>
> wrote:
> > > Hi Iqbal
> > > I think this difference may originate from the differences in the
> > posture.
> > > If the angle of the pelvis is different in the two models it will
> > have a big
> > > impact on the model, if the pelvis is tilted more backward in the
> > standing
> > > model it may have the result you list. Also the posture of the
> arms will
> > > have an influence on the result, so in order to compare the
> results
> > these
> > > should also be the same.
> > > In the standing model there might also be a load applied in the
> > > Mannequin.any file, please check the last section of the
> > mannequin.any for
> > > this, it may also have an impact in the results.
> > > I hope this helps you move on, otherwise please ask again.
> > > Have a nice weekend
> > > Best regards
> > > _____
> > > From: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
> [mailto:anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com]
> > On Behalf
> > > Of javed377
> > > Sent: 26 October 2007 12:10
> > > To: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
> > > Hi Soren,
> > > Thank you very much for your guidance.
> > > Now i have checked the rection force which are about 1400N with
> > > FreePosture model. But when i changed the posture like in
> standing
> > > model we have,i mean i changed the values in Mannequin.any of
> > > FreePosture to values as we have in Mannequin.any of Standing
> model.
> > > I got the force of 500N.
> > > Can you tell me what are the reasons may be? as i think with
> changing
> > > the posture it should not be so big difference because we have
> same
> > > loading conditions etc.
> > > Thanks in advance.
> > > and have a nice week end.
> > > Iqbal
> ps.com,
> > > “AnyBody Support” <support@> wrote:
> > > > Hi Iqbal
> > > > I think it will be best to use the FreePostureModel, this can
> be
> > > > controlled by the Mannequin.any file.
> > > > If you look at the following output
> Main.Study.Output.Model.HumanModel.Trunk.JointsLumbar.T12L1Jnt.Constr
> > > > aints.Reaction.Fout
> > > > You will get the reaction forces in the joint comming from the
> > > > external loads and the muscle contractions.
> > > > In the same manner you can also look at the other joints in
> the
> > > > lumbar region.
> > > > One more thing the FreepostureModel comes default, as a model
> with
> > > > no muscles, changing the include statement will from
> #include “…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel_N
> > > > oMuscles.any”
> > > > to
> #include “…\BRep\Aalborg\BodyModels\FullBodyModel\BodyModel.a
> > > > ny”
> > > > this will let you get the reaction forces.
> > > > Please do not hesitate to ask again if you have further
> questions.
> > > > Best regards
> > > > —In anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com>
> ps.com,
> > > > > Hello to every one,
> > > > > Can any one tell me how to calucualte section forces between
> Th12
> > > > and
> > > > > L1 in spine model for Zero degree inlcination? My final goal
> is to
> > > > > calculate the section forces in anybody spine model between
> Th12
> > > > and L1
> > > > > for different positions.
> > > > > with best regards.
> > > > > Iqbal
> > > [Non-text portions of this message have been removed]
