Hi all,
is it possible to change the local ref frame of a segment and impose the desired one?
what is AnyRefFrameAxis used for?
Noemi
Hi all,
Noemi
Hi Noemi,
In principle yes but it requires you to change the “sRel” values of the nodes…
The segmental reference system is indirectly defined by the position of the nodes.
You can always define new references frames on the segment as desired.
Thanks for your reply!
