Segment orientations
Hi there,
In my model, I would like to constraint my kinematics using segment
orientation. Basically, I would specify the tridimensional orientation of
all segments using quaternions. To do so, I need to be able to know how the
current segment axis have been chosen, so I can superpose both reference
systems. I know that currently the origins of the segments axis are the
center of mass, but how are the longitudinal, transverse and
antero-posterior axis of the pelvis, shank, thigh and foot defined?
Known data:
Shank longitudinal: KneeJoint -> AnkleJoint
Jean-Olivier
Hi Jean-Olivier
If you want the segment axes displayed you can add
an “AnyDrawRefFrame” in the segments of the leg, this will display
the segment axis orientations. For the leg this can be done in the
file Leg3d/Seg.any
Please ask again if this do not answer your questions.
— In anyscript@yahoogroups.com, Jean-Olivier Racine <jean-
olivier.racine.1@…> wrote:
> Hi there,
orientation of
know how the
reference
are the
> Known data:
> Jean-Olivier
Hello Søren,
I’ll try to explain it better with an example:
  •      Winter (table 6.3, p. 63) defines the foot segment’s longitudinal
axis as the line formed by connecting the second metatarsal with the lateral
malleolus, located at this last landmark.
  •      Vaughan (fig. 3.6, p. 25) defines the foot longitudinal axis as
being a line formed by connecting the heel with the fifth metatarsal, again,
located at the malleolus.
Choosing any of these two definitions gives very different results because
anybody defines the ankle as an universal joint that rotates around the
common z and y axis of both reference systems. The flexion-extension angle
is offset by almost 30 degree and tilted by at least 15. Same (opposite)
goes for the abduction-adduction angle. Therefore, if I specify a
flexion-extension angle to a driver that drives the ankle, I have no clue
what 30 degrees means, unless I know the exact local reference system
definitions of both the foot and shank.
What rules were used to defined the local reference systems of the foot,
shank, thigh and pelvis?
Jean-Olivier
Of AnyBody Support
Sent: Sunday, June 17, 2007 7:03 AM
Subject: [AnyScript] Re: Segment orientations
Hi Jean-Olivier
file Leg3d/Seg.any
— In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ,
> Hi there,
orientation of
know how the
reference
are the
> Known data:
> Jean-Olivier
Hi Jean-Olivier
I am not so sure about these rules for the legs, unfortunately. I
know that the x axis of the foot is parrallel to the footsole and
that the center of mass for the foot is defined according to
Winters.
If you look in the Leg3d/interface.any you will see some rotational
measures. If you prefer to use a specific set of definitions this
is the location to create them. If you create new nodes of the
segments that has the right locations and orientations you can
create your own rotational measures that can co-exist with the
original ones. In this way you would be sure about the definitions.
> Hello Søren,
> - Winter (table 6.3, p. 63) defines the foot segment’s
longitudinal
the lateral
> - Vaughan (fig. 3.6, p. 25) defines the foot longitudinal
axis as
metatarsal, again,
because
around the
extension angle
(opposite)
no clue
system
foot,
> Jean-Olivier
On Behalf
> Of AnyBody Support
> Hi Jean-Olivier
> file Leg3d/Seg.any
> Best regards
> olivier.racine.1@> wrote:
> > Hi there,
segment
> orientation of
> know how the
> reference
> are the
defined?
> > Known data:
> > Jean-Olivier
Thanks for the answer.
  1.   I’ll try to work with that*…
  2.   I cannot create new nodes on the segment because I do not know the
position of the segment. It poses the exact same problem… How can I place a
node on a segment for which I do not know the orientation?
*I could possibly overlap the reference systems using the KitVaughan markers
file, but unfortunately, it looks like the Metatarsal marker isn`t the 5th
metatarsal (looking at the model view). Is it?
Thanks again,
Jean-Olivier
Of AnyBody Support
Sent: Tuesday, June 19, 2007 6:16 PM
Hi Jean-Olivier
Winters.
— In HYPERLINK
"mailto:anyscript%40yahoogroups.com"anyscript@yahoogroups.com, Jean-Olivier
Racine <jean-
> Hello Søren,
longitudinal
the lateral
axis as
metatarsal, again,
because
around the
extension angle
(opposite)
no clue
system
foot,
> Jean-Olivier
> From: HYPERLINK
[mailto:HYPERLINK
"mailto:anyscript%40yahoogroups.com"anyscript@yahoogroups.com]
On Behalf
> Of AnyBody Support
> To: HYPERLINK
> Hi Jean-Olivier
> file Leg3d/Seg.any
> Best regards
> — In HYPERLINK
<mailto:anyscript%
> > Hi there,
segment
> orientation of
> know how the
> reference
> are the
defined?
> > Known data:
> > Jean-Olivier
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.9.0/853 - Release Date: 6/18/2007
3:02 PM
No virus found in this outgoing message.
Version: 7.5.472 / Virus Database: 269.9.1/857 - Release Date: 6/20/2007
2:18 PM
Hi Jean-Olivier
The nodes will have to place “by the eye”. If the nodes are
anatomical landmarks you will need to fit them manually to the
bones. Drawing a small cooridnate system in the nodes will help you
keep track on the directions, i am sorry but i think there is no
other way.
Søren AnyBody Support
know the
I place a
KitVaughan markers
the 5th
> Thanks again,
> Jean-Olivier
On Behalf
> Of AnyBody Support
> Hi Jean-Olivier
> Winters.
rotational
> Best regards
> — In HYPERLINK
Jean-Olivier
> Racine <jean-
> > Hello Søren,
> longitudinal
> the lateral
> axis as
> metatarsal, again,
results
> because
> around the
> extension angle
> (opposite)
have
> no clue
> system
the
> foot,
> > Jean-Olivier
> > From: HYPERLINK
> [mailto:HYPERLINK
> On Behalf
> > Of AnyBody Support
> > To: HYPERLINK
> > Hi Jean-Olivier
display
the
> > file Leg3d/Seg.any
> > Best regards
> > — In HYPERLINK
> <mailto:anyscript%
> > > Hi there,
> segment
> > orientation of
> > know how the
> > reference
axis
> > are the
> defined?
> > > Known data:
> > > Jean-Olivier
6/18/2007
> 3:02 PM
6/20/2007
> 2:18 PM
