Hi Pierre,
I’m glad you found what you wanted.
I am not an expert user of Matlab but I guess it might be possible to
recreate forward dynamic. We have been thinking on including forward
dynamic in AnyBody but nothing has been really decided yet.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “Pierre-Olivier Lemieux”
<pothekid@…> wrote:
> Hi Sylvain,
> I’ve found what I was searching for in the Nikravesh
> textbook (Planar multibody dynamics) that you have put the reference
> under FAQs in the publications section.
> This book explain how to apply joint coordinate method works and
also
> the kinematic equations. It also explain how to apply the forward
and
> inverse dynamic.
> Do you think that is feasible to create a 2D model in Matlab that
work
> in forward dynamic ? Do you work on that for further version ?
> My idea is to find a movement for the shoulder that rely upon the
> deltoid activity, knowing that this muscle is the only one that
makes
> the movement in case of a massive rotator cuff tear.
> Thank you for you support
> Pierre
wrote:
> > Hi Pierre,
> > There is a good explanation of how AnyBody perform the muscle
> > calculation in this tutorial:
> > http://www.anybodytech.com/691.0.html
> > Hope you will find there what you want.
> > Best regards,
> > <pothekid@> wrote:
> > > Hi Soren,
> > > there is no change of geometry during abduction. It’s
surely
> > > just a codec differences or the video encryption method in
Matlab.
> > The
> > > geometry changes only during the parameters study.
> > > My question was more about how Anybody do the calculations.
Does it
> > > make a static calculation or a dynamic one ? I mean, does the
> > program
> > > compute the minimal force to have equilibrium or a more complex
> > > calculation ?
> > > I ask this question because I have to understand how the
program
> > works
> > > in order to be able to explain it in my paper.
> > > Maybe you can refer me to an article in the Documentation
repository
> > > of Anybody that explain how AnyBody perfom the muscle
calculation. I
> > > know about the muscle recruitment, but not about the force
itself.
> > > I hope that is more clear for you.
> > > Thank you again
> > > Pierre
> > wrote:
> > > > Hi Pierre
> > > > I have seen the video and have a question about the GH head
> > shape.
> > > I do not
> > > > understand why the GH head changes its shape while the
analysis is
> > > running,
> > > > initially it has a long narrow shape and in the end it looks
more
> > > compressed
> > > > in shape. Could it be graphic related and just something seen
on
> > > this video?
> > > > In AnyBody such a change in the shape is not possible while
the
> > model is
> > > > running, there would have to be several segments to replicate
> > this.
> > > > I understand your point of not replicating the same
optimization
> > in
> > > AnyBody
> > > > and Matlab, but if you plan to impose the results found in
matlab
> > on the
> > > > AnyBody model it will be important that the models gives the
same
> > > results.
> > > > Please write again if you have further questions, I was a bit
> > unsure
> > > if the
> > > > last part of your posting was a question.
> > > > Best regards
> > > > Søren, AnyBody Support
> > > > _____
> > > > From: anyscript@yahoogroups.com
[mailto:anyscript@yahoogroups.com]
> > > On Behalf
> > > > Of Pierre-Olivier Lemieux
> > > > Sent: 19 March 2008 19:22
> > > > To: anyscript@yahoogroups.com
> > > > Subject: [AnyScript] Re: shoulder 2D model
> > > > Hi Soren,
> > > > the Matlab routine (which I’ve created entirely) is pretty
> > > > simple. For each positions, it perform a calculation of the
lever
> > arm
> > > > and the angle of the upper part of the muscle to separate the
X
> > and Y
> > > > direction of the muscle force. When the contact between the
> > prosthesis
> > > > and the acromion occurs, the acromial reaction is possible
and is
> > > > drawn on the figure. There is no recruitment muscle because
there
> > is
> > > > only one muscle in my routine (deltoid).
> > > > The strength model is a constant force model. Like you can
see,
> > the
> > > > muscle wrapping is done by using a thin rope between the
origin
> > and
> > > > insertion point.
> > > > I send you a little video of all that under (GH_Movement.zip).
> > > > I understand your idea about creating the same routine in
> > Anybody, but
> > > > I don’t see any interest about doing that if the results
between
> > > > AnyBody and Matlab are the same.
> > > > My idea was rather to find the correct movement pattern in
term of
> > > > prosthetic dimensions in Matlab and then put this movement
into my
> > > > AnyBody model, to find the deltoid forces. By obtaining the
same
> > > > results in AnyBody and Matlab, I think this is a way to
verify the
> > > > accuracy of my findings… What do you think about that ?
> > > > I have try to get the same models between AnyBody and Matlab.
To
> > do
> > > > so, I’ve put the static friction coefficient to 0 and put a
> > constant
> > > > force model for the deltoid. Thus, I think that the
differences
> > are
> > > > just in the WeakMuscle definition. In my Matlab routine,
there is
> > no
> > > > WeakMuscle because the acromion force give us a hint that
> > something
> > > > don’t work during the first abduction degrees (check the
> > results.jpg).
> > > > I hope that was more clear for you.
> > > > Thank you very much.
> > > > Pierre
> > > > — In anyscript@yahoogrou <mailto:anyscript%
40yahoogroups.com>
> > ps.com,
> > > > “AnyBody Support” <support@> wrote:
> > > > > Hi Pierre
> > > > > I think I understand what your algorithm is doing, it finds
the
> > > minimum
> > > > > deltoid force and if there is a force unbalance it moves
the
> > humeral
> > > > until
> > > > > balance is obtained.
> > > > > Using the build in optimizer in AnyBody something similar
> > should be
> > > > possible
> > > > > I guess, but it will be a slightly differently approach.
> > Basically
> > > > you will
> > > > > need a model that will always be able to balance itself
through
> > > > artificial
> > > > > joint reactions, but through the optimization you can
change the
> > > > motion so
> > > > > that it tries to minimize those reactions.
> > > > > 1 you will need the extra muscle that ensures that a force
> > balance can
> > > > > always be obtained.
> > > > > 2 a design variable has to be defined, this is the
translation,
> > > > maybe this
> > > > > should be done using an interpolation function…
> > > > > 3 an objective function has to be setup, here I would
choose to
> > > > minimize the
> > > > > forces in the artificial muscles which you did not want to
> > become
> > > > active. So
> > > > > you will be minimizing these reaction forces by moving the
> > humeral
> > > > head to
> > > > > another position.
> > > > > There is a tutorial of parameter and optimization studies
it
> > might be
> > > > > helpful.
> > > > > I can not judge if the MatLab code is ok sorry, I can think
of
> > the
> > > > following
> > > > > questions
> > > > > 1 Are there any differences in the models, that in anyway
could
> > > justify
> > > > > these differences?
> > > > > 2 What about muscles wrapping, how is this done in MatLab…
> > > > > 3 Muscles strength models
> > > > > 4 Recruitment criteria?
> > > > > Etc…
> > > > > Best regards
> > > > > _____
> > > > > From: anyscript@yahoogrou <mailto:anyscript%
40yahoogroups.com>
> > ps.com
> > > > [mailto:anyscript@yahoogrou <mailto:anyscript%
40yahoogroups.com>
> > ps.com]
> > > > On Behalf
> > > > > Sent: 18 March 2008 19:18
> > > > > To: anyscript@yahoogrou <mailto:anyscript%
40yahoogroups.com>
> > ps.com
> > > > > Hi Soren,
> > > > > thank you for your support. Now I have a model that
represent
> > > > > more my pathology and I have also created a Matlab
algorithm
> > that find
> > > > > the movement of the humeral head and import it into my
AnyBody
> > model.
> > > > > My Matlab algorithm compute the minimum force in the
deltoid to
> > > > > perform an increment of abduction with a moment balance
> > (constant
> > > > > velocity). If there is a non-equilibrium of the forces and
a
> > degree of
> > > > > freedom in the direction of the force, there is
automatically an
> > > > > increment of displacement. This is the case for the vertical
> > > > > displacement in my model.
> > > > > Now, I want to know how Anybody solve a problem. I know
that
> > for each
> > > > > step time, it use the min/max criterion to find the minimum
> > muscle
> > > > > activity. Does it works like my Matlab routine ?
> > > > > I have compared the Matlab results from those obtained in
> > Anybody from
> > > > > the same movement and in a lot of situation it gives me
similar
> > > > > results. However, there is some differences that I’m not
able to
> > > > > explain. Do you think that my Matlab routine is well made ?
> > > > > I send you my results (Matlab & AnyBody) for a particular
case
> > under
> > > > > (PO_Lemieux_shoulder_model_March_18). Just take a look and
give
> > me
> > > > > your idea about it.
> > > > > Thank you again.
> > > > > Pierre
40yahoogroups.com>
> > > ps.com,
> > > > > > Hi Pierre
> > > > > > The contact force you have applied works on the contact
> > segment.
> > > This
> > > > > > element will need to be carried by the driver otherwise
the
> > model
> > > > > will be
> > > > > > unbalanced and unable to solve; it can not be left
unbalanced.
> > > > > > The contact force you have applied can only do a pushing
> > force,
> > > so the
> > > > > > reactions you will see in this contact driver will only
be in
> > one
> > > > > direction.
> > > > > > The weak muscles also need to be there, there can not be
dof
> > in the
> > > > > model
> > > > > > which are unbalanced. Even if these are supposed to have
> > force, it
> > > > > will lead
> > > > > > to numeric problems if they are left unbalanced.
> > > > > > The reason why the weak muscles are needed must be a
moment
> > balance
> > > > > issue
> > > > > > there appears to be situation where the deltoid muscle it
self
> > > can not
> > > > > > balance the upper arm. To me it sounds reasonable, these
weak
> > > muscles
> > > > > > replicated the joint reactions up/down and these would
always
> > be non
> > > > > zero.
> > > > > > In you had more muscles in the model these might be able
to
> > > > control this
> > > > > > up/down dofs., and the weak muscles could be excluded.
> > > > > > Best regards
> > > > > > Søren
> > > > > > _____
40yahoogroups.com>
> > > ps.com
40yahoogroups.com>
> > > ps.com]
> > > > > On Behalf
> > > > > > Sent: 20 February 2008 03:31
40yahoogroups.com>
> > ps.com
> > > > > > Hi again Sylvain,
> > > > > > my model works well now with the Reaction.Type turned
> > > > > > on within the Contact driver. However, it makes this
reaction
> > > able to
> > > > > > pull or push. For some set-up of the parameters of the
> > ellipse,
> > > I got
> > > > > > negative forces for the Contact driver. It tells me that
the
> > > permanent
> > > > > > contact with the acromion is not valid in all the case.
Maybe
> > I
> > > should
> > > > > > know the real displacement in term of the elliptic shape,
> > prior to
> > > > > > proceed to the inverse analysis.
> > > > > > Also, it is not only the deltoid that pulls on the
humeral
> > head,
> > > it is
> > > > > > also the WeakMuscles. These muscles are not there
normally and
> > > when I
> > > > > > comment them, it gives me a “Muscle recruitment” error if
the
> > tStart
> > > > > > is 0. Thus, I want to know why the deltoid can’t do the
> > complete
> > > > > > abduction by itself ?
> > > > > > Thank you again.
> > > > > > Pierre-Olivier
> > 40yahoogroups.com>
> > > > ps.com,
> > > > > > > Hi,
> > > > > > > The reason you cannot see the reaction force of
> > > > > > > ContactSurfaceLinPush is because the ContactSeg you
created
> > is
> > > not
> > > > > > > fully balanced. I was effectively talking about adding
some
> > > > > > > AnyReacForce between the ContactSeg and the humerus, so
> > that the
> > > > > > > ContactSeg is carried in all directions in term of
forces
> > and it
> > > > can
> > > > > > > transmit the reaction forces from the acromion point to
the
> > > humerus
> > > > > > > head.
> > > > > > > But it’s not the only way to do it: by adding a
prismatic
> > > joint you
> > > > > > > drive the ContactSeg in five directions, you just have
to
> > > switch on
> > > > > > > the ReactionType of the Ellipse2ContactDriver to carry
the
> > > load of
> > > > > > > the segment in the sliding direction also. Now you will
be
> > > able to
> > > > > > > see appear the reaction force at the contact point.
> > > > > > > Best regards.
> > 40yahoogroups.com>
> > > > > ps.com,
> > > > > > > <pothekid@> wrote:
> > > > > > > > Hi Sylvain,
> > > > > > > > I’ve made the changes that you told me about, but I’m
> > > > > > > not
> > > > > > > > able to make my model works well. I don’t have any
> > > > > > > > “ContactSurfaceLinPush” reaction forces and friction
> > forces.
> > > > > > > > In Excel, I’ve calculated the displacement of the
humeral
> > > head in
> > > > > > > term
> > > > > > > > of static equations for the abduction and put those
values
> > > in the
> > > > > > > > model (“SliderDriver” and “AbductionDriver”). With
these
> > > values,
> > > > > > > the
> > > > > > > > displacement is upward at the beginning of abduction
and
> > > downward
> > > > > > > at
> > > > > > > > the end. So, the contact between the acromion and
humeral
> > > head is
> > > > > > > not
> > > > > > > > always there. For this reason,
the “ContactSurfaceLinPush”
> > > is very
> > > > > > > > useful for me.
> > > > > > > > I’m not sure to understand well when you talk about
> > adding some
> > > > > > > > reaction forces. Is it the “AnyReacForce” object ? If
it
> > is the
> > > > > > > case,
> > > > > > > > can you help me to write it correctly ?
> > > > > > > > My new model is named “PO_Lemieux_shoulder_3”.
> > > > > > > > Pierre-Olivier
> > 40yahoogroups.com>
> > > > > ps.com,
> > > > > > > wrote:
> > > > > > > > > Hi Pierre,
> > > > > > > > > In the file ContactSurfaceLinPush the object Base
> > define the
> > > > > > > node
> > > > > > > > > that is applying the force. The object Target
defines
> > the
> > > node
> > > > > > > where
> > > > > > > > > the force is applied to. So by switching Base and
Target
> > > object
> > > > > > > you
> > > > > > > > > are now applying the reaction forces from the
center of
> > the
> > > > > > > > > ellipsoid to p12. And the reaction forces are
displayed
> > in
> > > the
> > > > > > > Base
> > > > > > > > > frame (ellipsoid frame in this case) that’s why the
> > arrows
> > > > > > > follow
> > > > > > > > > the abduction angle.
> > > > > > > > > This can be improved by applying the reaction
forces
> > from
> > > > P12 to
> > > > > > > a
> > > > > > > > > floating point on the external shape of the
ellipsoid,
> > where
> > > > the
> > > > > > > > > contact really occurs. You can create a segment
(with no
> > > mass)
> > > > > > > that
> > > > > > > > > you drive to slide on the ellipsoid shape as you
did
> > with the
> > > > > > > > > AcromionDriver, and you set the distance between
one
> > point of
> > > > > > > this
> > > > > > > > > segment and P12 to 0. Then you have to create some
> > reaction
> > > > > > > forces
> > > > > > > > > between this segment and the ellipsoid to transmit
all
> > the
> > > > > > > forces.
> > > > > > > > > So you will now have a floating contact point on the
> > > ellipsoid
> > > > > > > > > shape. By setting the Base to the new segment you
> > should be
> > > > able
> > > > > > > to
> > > > > > > > > draw the reaction force vectors in the tangential
plane
> > of
> > > the
> > > > > > > shape.
> > > > > > > > > About the ContactRotPush, this applies a moment
between
> > two
> > > > > > > segments
> > > > > > > > > in contact. There are no friction forces, so this
may
> > not be
> > > > > > > what
> > > > > > > > > you need.
> > > > > > > > > For the external pushing force of
> > you
> > > > talk
> > > > > > > > > about: this function actually use 5 muscles. One
pushing
> > > in the
> > > > > > > > > normal direction of the surface and 4 others
creating
> > the
> > > > > > > friction
> > > > > > > > > forces in the plane of the surface combined with
normal
> > > force;
> > > > > > > > > please see this link where there is a short
description
> > > > > > > > > http://www.anybodyt
> > > > > <http://www.anybodyt <http://www.anybodyt
> > > > <http://www.anybodytech.com/116.0.html?&tx_ttnews>
> > > > > > ech.com/116.0.html?&tx_ttnews[backPid]
> > > > > > > > > =37&tx_ttnews[tt_news]=23&cHash=c92c2826e9
> > > > > > > > > I understand you would like to activate only the
> > friction
> > > > > > > muscles?
> > > > > > > > > That is not possible, the five muscles are linked
and
> > working
> > > > > > > > > together.
> > > > > > > > > And for the strange behaviour you noticed when you
> > change the
> > > > > > > > > deltoid origin, well i don’t think it’s so strange.
> > > Because by
> > > > > > > > > changing the origin of the muscle you change the
force
> > it
> > > will
> > > > > > > have
> > > > > > > > > to develop, you also change the reaction forces in
the
> > > contact
> > > > > > > > > point. But i think you don’t have a big interest in
> > changing
> > > > the
> > > > > > > > > muscle origin and you should just keep it in its
normal
> > value.
> > > > > > > > > It’s correct that you did not find repository 7, it
is
> > not
> > > > > > > public, I
> > > > > > > > > forgot this, sorry. You should look in the
repository
> > 6, here
> > > > > > > you
> > > > > > > > > will find the file PedalDemoConditional in
ARep\Aalborg.
> > > > > > > > > Best Regards
> > > > > > > > > Sylvain, AnyBodySupport
> > > <mailto:anyscript%40yahoogroups.com>
> > > > > > > > > <pothekid@> wrote:
> > > > > > > > > > Hi Sylvain,
> > > > > > > > > > thank you for your support. I’ve worked around
> > > > > > > > > > the “ContactLinePush” problem all the week-end
and
> > I’ve
> > > found
> > > > > > > that
> > > > > > > > > > by swithching the “Base” and “Target” objects,
the
> > friction
> > > > > > > > > appears.
> > > > > > > > > > However, it gives me too high results because the
> > switch
> > > > mixed
> > > > > > > up
> > > > > > > > > > all the calculations. For exemple, the resulting
> > friction
> > > > > > > force is
> > > > > > > > > > equal to the normal force, that is not correct.
Also,
> > the
> > > > > > > arrows
> > > > > > > > > > rotate following the abduction angle. Maybe a
> > > > “ContactRotPush”
> > > > > > > > > would
> > > > > > > > > > perform better ?
> > > > > > > > > > So, I guess that I’m on a good way to find a
solution,
> > > but I
> > > > > > > still
> > > > > > > > > > need to understand how this script works, and
what
> > are the
> > > > > > > > > > accepted “RefFrame” for the “Base” and “Target”
> > objects.
> > > > > > > > > > Also, in the present case, there is an external
> > pushing
> > > force
> > > > > > > > > > (ContactLinePush) on the shoulder upward during
all
> > > abduction
> > > > > > > to
> > > > > > > > > > keep the contact between the acromion and the
> > ellipse.
> > > > > > > > > > However, in the real case, the deltoid, while
> > performing
> > > the
> > > > > > > > > > abduction alone, pulls on the humerus, instead
> > > > > > > > > of “ContactLinePush”,
> > > > > > > > > > and creates a contact force between the acromion
and
> > > humeral
> > > > > > > head
> > > > > > > > > > (that should be the ContactLinePush). I’ve made
an
> > > > > > > experimental
> > > > > > > > > set-
> > > > > > > > > > up that has shown me these results.
> > > > > > > > > > Also, I’ve noticed another strange behavior. For
> > exemple,
> > > > when
> > > > > > > I
> > > > > > > > > use
> > > > > > > > > > the acromion contact point P12 : (0,0.039,0) and
> > deltoid
> > > > > > > origin
> > > > > > > > > > point P8 : (0,0.050,0) and use
the “ContactLinPush”
> > script,
> > > > > > > the
> > > > > > > > > > results are very different from using the same
P12,
> > but
> > > > > > > changing
> > > > > > > > > P8
> > > > > > > > > > to a closer distance (0,0.038,0) from P12. Note
that
> > the
> > > > first
> > > > > > > set
> > > > > > > > > > of values for P8 and P12 are the ones that I need.
> > > > > > > > > > So, if you can help me understanding these
problems,
> > it
> > > would
> > > > > > > help
> > > > > > > > > > me a lot.
> > > > > > > > > > Have a good week and thank you again.
> > > > > > > > > > Pierre.
> > > > > > > > > > P.S. : I’ve not found the repository 7, is it
normal ?
> > > > > > > > > > wrote:
> > > > > > > > > > > Hi Pierre-Olivier
> > > > > > > > > > > I will try to give you some more information on
the
> > file
> > > > > > > > > > > ContactSurfaceLinPush, this file can create a
> > conditional
> > > > > > > > > contact
> > > > > > > > > > > with pushing muscles. If the two contact points
are
> > close
> > > > > > > enough
> > > > > > > > > > > (this distance is set by the user) then the
muscles
> > will
> > > > > > > have a
> > > > > > > > > > high
> > > > > > > > > > > strength and can create the contact force. If
the
> > two
> > > > > > > contact
> > > > > > > > > > points
> > > > > > > > > > > are to far from each other, the muscles will
have
> > no
> > > > > > > strength at
> > > > > > > > > > > all, and there can be no contact force.
> > > > > > > > > > > But I am not sure if this utility is useful for
your
> > > model
> > > > > > > > > because
> > > > > > > > > > > you want a permanent contact of the humerus
head?
> > > > > > > > > > > The file also holds another utility which is the
> > > ability to
> > > > > > > > > create
> > > > > > > > > > > normal reaction force and friction force at the
> > contact
> > > > > > > point.
> > > > > > > > > > This
> > > > > > > > > > > could maybe be interesting for your model. But
you
> > > have to
> > > > > > > take
> > > > > > > > > > care
> > > > > > > > > > > to apply those forces to the acromion contact
> > point. You
> > > > > > > > > actually
> > > > > > > > > > > applied them to the center of the humerus head
> > instead of
> > > > > > > the
> > > > > > > > > > > contact point.
> > > > > > > > > > > I tried running the files you uploaded and it
is
> > working
> > > > > > > with
> > > > > > > > > the
> > > > > > > > > > > elliptic shape without doing any changes.
However
> > the
> > > model
> > > > > > > is
> > > > > > > > > now
> > > > > > > > > > > fully balanced and it is not possible anymore
to
> > see that
> > > > > > > point
> > > > > > > > > > you
> > > > > > > > > > > was interested in the last time (where the
geometry
> > > cannot
> > > > > > > carry
> > > > > > > > > > the
> > > > > > > > > > > load) to plot the max abduction.
> > > > > > > > > > > So the solution of recreating the humeral
contact
> > > > depends on
> > > > > > > the
> > > > > > > > > > > simulation you want to perform
> > > > > > > > > > > An example of using ContactSurfaceLinPush is
> > available in
> > > > > > > the
> > > > > > > > > > > repository
> > 7/Application/Examples/PedalDemoConditional,
> > > > as I
> > > > > > > > > > recall
> > > > > > > > > > > it the contact muscles are defined in the
> > > > JointAndDriver.any
> > > > > > > > > file.
> > > > > > > > > > > Best regards,
> > > > > > > > > > > <pothekid@> wrote:
> > > > > > > > > > > > Hi Soeren,
> > > > > > > > > > > > thank you for you recommendations. It seems
to
> > > > > > > works
> > > > > > > > > > now
> > > > > > > > > > > for
> > > > > > > > > > > > the abduction. The deltoid activity is not
what I
> > want
> > > > > > > most,
> > > > > > > > > so
> > > > > > > > > > > I’ve
> > > > > > > > > > > > just commented it out.
> > > > > > > > > > > > I have an other question now. When I went to
> > Aalborg,
> > > > John
> > > > > > > > > gave
> > > > > > > > > > me
> > > > > > > > > > > a
> > > > > > > > > > > > folder with some special scripts. One of these
> > > scripts is
> > > > > > > > > > > > “ContactSurfaceLinPush”. Like it says, it was
to
> > > create a
> > > > > > > > > pushing
> > > > > > > > > > > > force on a contact node (I guess). However, I
> > have some
> > > > > > > > > > > difficulties
> > > > > > > > > > > > to understand this script. Also, it works
with a
> > > constant
> > > > > > > > > radius
> > > > > > > > > > > > humeral head, but not for my elliptic shape.
Do
> > you
> > > think
> > > > > > > this
> > > > > > > > > is
> > > > > > > > > > > > possible ?
> > > > > > > > > > > > You can check the
folder “AcromionHumerusContact”
> > in
> > > the
> > > > > > > > > bottom
> > > > > > > > > > of
> > > > > > > > > > > my
> > > > > > > > > > > > main script (The file is
> > > “PO_Lemieux_shoulder2D.zip”). I
> > > > > > > will
> > > > > > > > > > send
> > > > > > > > > > > you
> > > > > > > > > > > > the special script, because I don’t know who
has
> > > written
> > > > > > > it.
> > > > > > > > > > > > Thank you again,
> > > > > > > > > > > > Pierre-Olivier
> > > > > > > <support@>
> > > > > > > > > > > wrote:
> > > > > > > > > > > > > Hi Pierre
> > > > > > > > > > > > > I think there is a simple solution to your
> > problem….
> > > > > > > > > > > > > The reason why you are getting this strange
> > > solution is
> > > > > > > that
> > > > > > > > > > the
> > > > > > > > > > > > analysis
> > > > > > > > > > > > > has not been finished due to the inverse
> > analysis,
> > > this
> > > > > > > is
> > > > > > > > > as
> > > > > > > > > > you
> > > > > > > > > > > > expect.
> > > > > > > > > > > > > The abduction angle you find by taking the
max
> > > value of
> > > > > > > the
> > > > > > > > > > > > abduction angle
> > > > > > > > > > > > > function. This is fine if the analysis had
> > finished
> > > > > > > correctly
> > > > > > > > > > > > because then
> > > > > > > > > > > > > it would look at all the values in the
output
> > > function
> > > > > > > (nStep
> > > > > > > > > > > > values) and
> > > > > > > > > > > > > find the maximum one. When the analysis
stops
> > it will
> > > > > > > still
> > > > > > > > > > look
> > > > > > > > > > > at
> > > > > > > > > > > > these
> > > > > > > > > > > > > nStep values, but now some of these can
> > > > > > > contain “garbage”
> > > > > > > > > > > numbers.
> > > > > > > > > > > > > So the remedy in this case is to change the
> > output
> > > > > > > function
> > > > > > > > > in
> > > > > > > > > > > the
> > > > > > > > > > > > > parameterstudy to the following
> > > > > > > > > > > > > AnyDesMeasure AbductionMax = {
> > > > > > > > > > > > > Val = -Main.MyModel.GH.Pos[0];
> > > > > > > > > > > > > This function do not take the max of any
values
> > it
> > > will
> > > > > > > just
> > > > > > > > > > > return
> > > > > > > > > > > > the last
> > > > > > > > > > > > > one … and this is what you would like in
this
> > case I
> > > > > > > guess.
> > > > > > > > > > > > > There will be the same kind of problems
with
> > your
> > > other
> > > > > > > > > output
> > > > > > > > > > > > function in
> > > > > > > > > > > > > the parameter study as I see it. The
Abduction
> > > angle is
> > > > > > > > > > reported
> > > > > > > > > > > ok
> > > > > > > > > > > > but if
> > > > > > > > > > > > > you did the same with the deltoid activity
it
> > > would not
> > > > > > > work
> > > > > > > > > I
> > > > > > > > > > > believe
> > > > > > > > > > > > > because this value is not calculated in the
> > last step
> > > > > > > > > because
> > > > > > > > > > it
> > > > > > > > > > > > fails in
> > > > > > > > > > > > > inverse analysis, it goes ok with the
abduction
> > angle
> > > > > > > > > because
> > > > > > > > > > the
> > > > > > > > > > > > kinematics
> > > > > > > > > > > > > has been solved ok.
> > > > > > > > > > > > > So using the function
> > > > > > > > > > > > > AnyDesMeasure DeltoidActivity = {
> > > > > > > > > > > > > Val = max(…Study.MaxActivity());
> > > > > > > > > > > > > I am not really sure what you get since you
> > take the
> > > > max
> > > > > > > of
> > > > > > > > > > > values
> > > > > > > > > > > > which are
> > > > > > > > > > > > > initialized, and this may give strange
results.
> > So I
> > > > > > > think
> > > > > > > > > you
> > > > > > > > > > > should
> > > > > > > > > > > > > consider exporting these numbers using an
> > output file
> > > > > > > and
> > > > > > > > > then
> > > > > > > > > > > > process them
> > > > > > > > > > > > > externally.
> > > > > > > > > > > > > I hope this helps you move on.
> > > > > > > > > > > > > Otherwise please write again.
> > > > > > > > > > > > > Best regards
> > > > > > > > > > > > > _____
> > > > > > ps.com
> > > > > > ps.com]
> > > > > > > > > > > > On Behalf
> > > > > > > > > > > > > Sent: 07 February 2008 18:46
> > > > > > ps.com
> > > > > > > > > > > > > Subject: [AnyScript] shoulder 2D model
> > > > > > > > > > > > > Hi guys,
> > > > > > > > > > > > > I’m still working with anybody to finish
the
> > first
> > > part
> > > > > > > of
> > > > > > > > > > > > > my simulations in 2 dimensions. After some
> > > revisions of
> > > > > > > the
> > > > > > > > > > > model,
> > > > > > > > > > > > > i’ve found a big error in it.
> > > > > > > > > > > > > If you don’t remember, I try to simulate the
> > > migration
> > > > > > > of
> > > > > > > > > the
> > > > > > > > > > > humeral
> > > > > > > > > > > > > head, in the case of a massive rotator cuff
> > tear.
> > > > So, my
> > > > > > > > > model
> > > > > > > > > > > allows
> > > > > > > > > > > > > a translation of the humerus upward and a
> > permanent
> > > > > > > contact
> > > > > > > > > of
> > > > > > > > > > > the
> > > > > > > > > > > > > prosthetic head on the acromion. This
contact is
> > > > allowed
> > > > > > > by
> > > > > > > > > a
> > > > > > > > > > > driver
> > > > > > > > > > > > > (acromion driver), related to mathematical
> > > > properties of
> > > > > > > the
> > > > > > > > > > > elliptic
> > > > > > > > > > > > > shape. Because this contact is between a
> > > prosthesis and
> > > > > > > a
> > > > > > > > > > bone,
> > > > > > > > > > > it
> > > > > > > > > > > > > can’t supply a pulling force (just pushing
> > force is
> > > > > > > allowed)
> > > > > > > > > > (It
> > > > > > > > > > > was
> > > > > > > > > > > > > the error !!). To correct that, I have
switched
> > > off the
> > > > > > > > > > reaction
> > > > > > > > > > > of
> > > > > > > > > > > > > the driver and put a general “only pushing”
> > muscle on
> > > > > > > it. So
> > > > > > > > > > > now, the
> > > > > > > > > > > > > abduction can goes until a certain degree
and
> > after
> > > > > > > that,
> > > > > > > > > the
> > > > > > > > > > > geometry
> > > > > > > > > > > > > is not able to carry the movement, and the
> > simulation
> > > > > > > stops.
> > > > > > > > > > It
> > > > > > > > > > > is
> > > > > > > > > > > > > exactly that I want because it directly
shows
> > if the
> > > > > > > > > geometry
> > > > > > > > > > is
> > > > > > > > > > > > > efficient or not.
> > > > > > > > > > > > > My problem is when I try to perform a
> > parametric
> > > > > > > simulation.
> > > > > > > > > I
> > > > > > > > > > > look on
> > > > > > > > > > > > > the maximum abduction reached during the
> > simulation
> > > > > > > > > (kinematic
> > > > > > > > > > > > > rotational measure). The results are very
> > strange
> > > and I
> > > > > > > > > think
> > > > > > > > > > > that
> > > > > > > > > > > > > they are not representative, probably
because
> > the
> > > > > > > simulation
> > > > > > > > > > > stops
> > > > > > > > > > > > > with an error. So, if I would get rid of
this
> > > error by
> > > > > > > > > changing
> > > > > > > > > > > > > something on the model, it would maybe
works.
> > > > > > > > > > > > > Maybe you have a little idea of what I
should
> > do (I
> > > > > > > > > hope …).
> > > > > > > > > > I
> > > > > > > > > > > send
> > > > > > > > > > > > > you my model and a picture of the results.
> > > > > > > > > > > > > Thank you in advance for your support and
say
> > > hello to
> > > > > > > > > > everyone
> > > > > > > > > > > of
> > > > > > > > > > > > > Anybody for me
> > > > > > > > > > > > > bye bye
> > > > > > > > > > > > > Pierre
> > > > > > > > > > > > > [Non-text portions of this message have
been
> > removed]
> > > > > > [Non-text portions of this message have been removed]
