shoulder 2D model
Hi guys,
I’m still working with anybody to finish the first part of
my simulations in 2 dimensions. After some revisions of the model,
i’ve found a big error in it.
If you don’t remember, I try to simulate the migration of the humeral
head, in the case of a massive rotator cuff tear. So, my model allows
a translation of the humerus upward and a permanent contact of the
prosthetic head on the acromion. This contact is allowed by a driver
(acromion driver), related to mathematical properties of the elliptic
shape. Because this contact is between a prosthesis and a bone, it
can’t supply a pulling force (just pushing force is allowed) (It was
the error !!). To correct that, I have switched off the reaction of
the driver and put a general “only pushing” muscle on it. So now, the
abduction can goes until a certain degree and after that, the geometry
is not able to carry the movement, and the simulation stops. It is
exactly that I want because it directly shows if the geometry is
efficient or not.
My problem is when I try to perform a parametric simulation. I look on
the maximum abduction reached during the simulation (kinematic
rotational measure). The results are very strange and I think that
they are not representative, probably because the simulation stops
with an error. So, if I would get rid of this error by changing
something on the model, it would maybe works.
Maybe you have a little idea of what I should do (I hope …). I send
you my model and a picture of the results.
Thank you in advance for your support and say hello to everyone of
Anybody for me :wink:
bye bye
Pierre
Hi again,
the files are “Shoulder 2D model” and “Shoulder 2D model results”.
Thank you again
Hi Pierre
I think there is a simple solution to your problem….
The reason why you are getting this strange solution is that the analysis
has not been finished due to the inverse analysis, this is as you expect.
The abduction angle you find by taking the max value of the abduction angle
function. This is fine if the analysis had finished correctly because then
it would look at all the values in the output function (nStep values) and
find the maximum one. When the analysis stops it will still look at these
nStep values, but now some of these can contain “garbage” numbers.
So the remedy in this case is to change the output function in the
parameterstudy to the following
AnyDesMeasure AbductionMax = {
Val = -Main.MyModel.GH.Pos[0];
This function do not take the max of any values it will just return the last
one … and this is what you would like in this case I guess.
There will be the same kind of problems with your other output function in
the parameter study as I see it. The Abduction angle is reported ok but if
you did the same with the deltoid activity it would not work I believe
because this value is not calculated in the last step because it fails in
inverse analysis, it goes ok with the abduction angle because the kinematics
has been solved ok.
So using the function
AnyDesMeasure DeltoidActivity = {
   Val = max(..Study.MaxActivity());
I am not really sure what you get since you take the max of values which are
initialized, and this may give strange results. So I think you should
consider exporting these numbers using an output file and then process them
externally.
I hope this helps you move on.
Otherwise please write again.
Of Pierre-Olivier Lemieux
Sent: 07 February 2008 18:46
Subject: [AnyScript] shoulder 2D model
Hi guys,
efficient or not.
bye bye
Pierre
Hi Soeren,
thank you for you recommendations. It seems to works now for
the abduction. The deltoid activity is not what I want most, so I’ve
just commented it out.
I have an other question now. When I went to Aalborg, John gave me a
folder with some special scripts. One of these scripts is
“ContactSurfaceLinPush”. Like it says, it was to create a pushing
force on a contact node (I guess). However, I have some difficulties
to understand this script. Also, it works with a constant radius
humeral head, but not for my elliptic shape. Do you think this is
possible ?
You can check the folder “AcromionHumerusContact” in the bottom of my
main script (The file is “PO_Lemieux_shoulder2D.zip”). I will send you
the special script, because I don’t know who has written it.
Thank you again,
Pierre-Olivier
> Hi Pierre
analysis
expect.
abduction angle
because then
values) and
these
the last
function in
but if
fails in
kinematics
> has been solved ok.
> Val = max(…Study.MaxActivity());
which are
process them
> externally.
> Best regards
> _____
On Behalf
> Hi guys,
> efficient or not.
> bye bye
> Pierre
Hi Pierre-Olivier
I will try to give you some more information on the file
ContactSurfaceLinPush, this file can create a conditional contact
with pushing muscles. If the two contact points are close enough
(this distance is set by the user) then the muscles will have a high
strength and can create the contact force. If the two contact points
are to far from each other, the muscles will have no strength at
all, and there can be no contact force.
But I am not sure if this utility is useful for your model because
you want a permanent contact of the humerus head?
The file also holds another utility which is the ability to create
normal reaction force and friction force at the contact point. This
could maybe be interesting for your model. But you have to take care
to apply those forces to the acromion contact point. You actually
applied them to the center of the humerus head instead of the
contact point.
I tried running the files you uploaded and it is working with the
elliptic shape without doing any changes. However the model is now
fully balanced and it is not possible anymore to see that point you
was interested in the last time (where the geometry cannot carry the
load) to plot the max abduction.
So the solution of recreating the humeral contact depends on the
simulation you want to perform
An example of using ContactSurfaceLinPush is available in the
repository 7/Application/Examples/PedalDemoConditional, as I recall
it the contact muscles are defined in the JointAndDriver.any file.
Sylvain, AnyBody Support
— In anyscript@yahoogroups.com, “Pierre-Olivier Lemieux”
<pothekid@…> wrote:
> Hi Soeren,
for
I’ve
a
difficulties
> possible ?
my
you
> Thank you again,
> Pierre-Olivier
wrote:
> > Hi Pierre
> analysis
> expect.
> abduction angle
> because then
> values) and
at
> these
numbers.
the
return
> the last
> function in
ok
> but if
believe
> fails in
> kinematics
> > has been solved ok.
values
> which are
should
> process them
> > externally.
> > Best regards
> > _____
> On Behalf
> > Hi guys,
model,
humeral
allows
the
driver
elliptic
it
was
of
now, the
geometry
is
> > efficient or not.
look on
that
stops
send
of
> > bye bye
> > Pierre
Hi Sylvain,
thank you for your support. I’ve worked around
the “ContactLinePush” problem all the week-end and I’ve found that
by swithching the “Base” and “Target” objects, the friction appears.
However, it gives me too high results because the switch mixed up
all the calculations. For exemple, the resulting friction force is
equal to the normal force, that is not correct. Also, the arrows
rotate following the abduction angle. Maybe a “ContactRotPush” would
perform better ?
So, I guess that I’m on a good way to find a solution, but I still
need to understand how this script works, and what are the
accepted “RefFrame” for the “Base” and “Target” objects.
Also, in the present case, there is an external pushing force
(ContactLinePush) on the shoulder upward during all abduction to
keep the contact between the acromion and the ellipse.
However, in the real case, the deltoid, while performing the
abduction alone, pulls on the humerus, instead of “ContactLinePush”,
and creates a contact force between the acromion and humeral head
(that should be the ContactLinePush). I’ve made an experimental set-
up that has shown me these results.
Also, I’ve noticed another strange behavior. For exemple, when I use
the acromion contact point P12 : (0,0.039,0) and deltoid origin
point P8 : (0,0.050,0) and use the “ContactLinPush” script, the
results are very different from using the same P12, but changing P8
to a closer distance (0,0.038,0) from P12. Note that the first set
of values for P8 and P12 are the ones that I need.
So, if you can help me understanding these problems, it would help
me a lot.
Have a good week and thank you again.
Pierre.
P.S. : I’ve not found the repository 7, is it normal ?
wrote:
> Hi Pierre-Olivier
high
points
This
care
> contact point.
you
the
recall
> Best regards,
> <pothekid@> wrote:
> > Hi Soeren,
now
> for
> I’ve
me
> a
> difficulties
> > possible ?
of
> my
send
> you
> > Thank you again,
> > Pierre-Olivier
> wrote:
> > > Hi Pierre
the
> > analysis
you
> > expect.
> > abduction angle
> > because then
> > values) and
look
> at
> > these
> numbers.
> the
> return
> > the last
> > function in
reported
> ok
> > but if
> believe
it
> > fails in
the
> > kinematics
> > > has been solved ok.
> values
> > which are
> should
> > process them
> > > externally.
> > > Best regards
> > > _____
> > On Behalf
> > > Hi guys,
> model,
> humeral
> allows
> the
> driver
> elliptic
bone,
> it
(It
> was
reaction
> of
> now, the
> geometry
It
> is
is
> > > efficient or not.
> look on
> that
> stops
I
> send
everyone
> of
> > > bye bye
> > > Pierre
Hi Pierre,
In the file ContactSurfaceLinPush the object Base define the node
that is applying the force. The object Target defines the node where
the force is applied to. So by switching Base and Target object you
are now applying the reaction forces from the center of the
ellipsoid to p12. And the reaction forces are displayed in the Base
frame (ellipsoid frame in this case) that’s why the arrows follow
This can be improved by applying the reaction forces from P12 to a
floating point on the external shape of the ellipsoid, where the
contact really occurs. You can create a segment (with no mass) that
you drive to slide on the ellipsoid shape as you did with the
AcromionDriver, and you set the distance between one point of this
segment and P12 to 0. Then you have to create some reaction forces
between this segment and the ellipsoid to transmit all the forces.
So you will now have a floating contact point on the ellipsoid
shape. By setting the Base to the new segment you should be able to
draw the reaction force vectors in the tangential plane of the shape.
About the ContactRotPush, this applies a moment between two segments
in contact. There are no friction forces, so this may not be what
you need.
For the external pushing force of ContactSurfaceLinPush you talk
about: this function actually use 5 muscles. One pushing in the
normal direction of the surface and 4 others creating the friction
forces in the plane of the surface combined with normal force;
please see this link where there is a short description
http://www.anybodytech.com/116.0.html?&tx_ttnews[backPid]
=37&tx_ttnews[tt_news]=23&cHash=c92c2826e9
I understand you would like to activate only the friction muscles?
That is not possible, the five muscles are linked and working
together.
And for the strange behaviour you noticed when you change the
deltoid origin, well i don’t think it’s so strange. Because by
changing the origin of the muscle you change the force it will have
to develop, you also change the reaction forces in the contact
point. But i think you don’t have a big interest in changing the
muscle origin and you should just keep it in its normal value.
It’s correct that you did not find repository 7, it is not public, I
forgot this, sorry. You should look in the repository 6, here you
will find the file PedalDemoConditional in ARep\Aalborg.
Best Regards
Sylvain, AnyBodySupport
<pothekid@…> wrote:
> Hi Sylvain,
appears.
would
> perform better ?
set-
use
P8
> me a lot.
> Pierre.
> wrote:
> > Hi Pierre-Olivier
contact
> high
> points
because
create
> This
> care
actually
> > contact point.
the
now
> you
> the
> recall
file.
> > Best regards,
> > <pothekid@> wrote:
> > > Hi Soeren,
> now
> > for
so
> > I’ve
gave
> me
> > a
pushing
> > difficulties
radius
is
> > > possible ?
bottom
> of
> > my
> send
> > you
> > > Thank you again,
> > > Pierre-Olivier
> > wrote:
> > > > Hi Pierre
> the
> > > analysis
as
> you
> > > expect.
> > > abduction angle
> > > because then
> > > values) and
> look
> > at
> > > these
> > numbers.
in
> > the
> > return
> > > the last
output
> > > function in
> reported
> > ok
> > > but if
I
> > believe
because
> it
> > > fails in
because
> the
> > > kinematics
> > > > has been solved ok.
> > values
> > > which are
you
> > should
then
> > > process them
> > > > externally.
> > > > Best regards
> > > > _____
> > > On Behalf
> > > > Hi guys,
> > model,
the
> > humeral
model
> > allows
of
> > the
a
> > driver
> > elliptic
> bone,
> > it
> (It
> > was
> reaction
> > of
> > now, the
the
> > geometry
> It
> > is
geometry
> is
> > > > efficient or not.
I
> > look on
(kinematic
think
> > that
> > stops
changing
hope …).
> I
> > send
> everyone
> > of
> > > > bye bye
> > > > Pierre
Hi Sylvain,
I’ve made the changes that you told me about, but I’m not
able to make my model works well. I don’t have any
“ContactSurfaceLinPush” reaction forces and friction forces.
In Excel, I’ve calculated the displacement of the humeral head in term
of static equations for the abduction and put those values in the
model (“SliderDriver” and “AbductionDriver”). With these values, the
displacement is upward at the beginning of abduction and downward at
the end. So, the contact between the acromion and humeral head is not
always there. For this reason, the “ContactSurfaceLinPush” is very
useful for me.
I’m not sure to understand well when you talk about adding some
reaction forces. Is it the “AnyReacForce” object ? If it is the case,
can you help me to write it correctly ?
My new model is named “PO_Lemieux_shoulder_3”.
Pierre-Olivier
> Hi Pierre,
> you need.
> together.
> Best Regards
> <pothekid@> wrote:
> > Hi Sylvain,
> appears.
> would
> > perform better ?
> set-
> use
> P8
> > me a lot.
> > Pierre.
> > wrote:
> > > Hi Pierre-Olivier
> contact
> > high
> > points
> because
> create
> > This
> > care
> actually
> > > contact point.
> the
> now
> > you
> > the
> > recall
> file.
> > > Best regards,
> > > <pothekid@> wrote:
> > > > Hi Soeren,
> > now
> > > for
> so
> > > I’ve
> gave
> > me
> > > a
> pushing
> > > difficulties
> radius
> is
> > > > possible ?
> bottom
> > of
> > > my
> > send
> > > you
> > > > Thank you again,
> > > > Pierre-Olivier
> > > wrote:
> > > > > Hi Pierre
> > the
> > > > analysis
> as
> > you
> > > > expect.
> > > > abduction angle
> > > > because then
> > > > values) and
> > look
> > > at
> > > > these
> > > numbers.
> in
> > > the
> > > return
> > > > the last
> output
> > > > function in
> > reported
> > > ok
> > > > but if
> I
> > > believe
> because
> > it
> > > > fails in
> because
> > the
> > > > kinematics
> > > > > has been solved ok.
> > > values
> > > > which are
> you
> > > should
> then
> > > > process them
> > > > > externally.
> > > > > Best regards
> > > > > _____
> > > > On Behalf
> > > > > Hi guys,
> > > model,
> the
> > > humeral
> model
> > > allows
> of
> > > the
> a
> > > driver
> > > elliptic
> > bone,
> > > it
> > (It
> > > was
> > reaction
> > > of
> > > now, the
> the
> > > geometry
> > It
> > > is
> geometry
> > is
> > > > > efficient or not.
> I
> > > look on
> (kinematic
> think
> > > that
> > > stops
> changing
> hope …).
> > I
> > > send
> > everyone
> > > of
> > > > > bye bye
> > > > > Pierre
The reason you cannot see the reaction force of
ContactSurfaceLinPush is because the ContactSeg you created is not
fully balanced. I was effectively talking about adding some
AnyReacForce between the ContactSeg and the humerus, so that the
ContactSeg is carried in all directions in term of forces and it can
transmit the reaction forces from the acromion point to the humerus
head.
But it’s not the only way to do it: by adding a prismatic joint you
drive the ContactSeg in five directions, you just have to switch on
the ReactionType of the Ellipse2ContactDriver to carry the load of
the segment in the sliding direction also. Now you will be able to
see appear the reaction force at the contact point.
Best regards.
<pothekid@…> wrote:
> Hi Sylvain,
not
term
the
at
not
> useful for me.
case,
> Pierre-Olivier
wrote:
> > Hi Pierre,
node
where
you
Base
follow
a
that
this
forces
forces.
to
shape.
segments
what
> > you need.
friction
muscles?
> > together.
have
public, I
you
> > Best Regards
> > <pothekid@> wrote:
> > > Hi Sylvain,
that
> > appears.
up
force is
arrows
> > would
> > > perform better ?
still
to
head
experimental
> > set-
I
> > use
origin
the
changing
> > P8
set
help
> > > me a lot.
> > > Pierre.
> > > wrote:
> > > > Hi Pierre-Olivier
> > contact
enough
have a
> > > high
contact
> > > points
strength at
> > because
> > create
point.
> > > This
take
> > > care
> > actually
the
> > > > contact point.
with
> > the
is
> > now
point
> > > you
carry
> > > the
the
the
> > > recall
> > file.
> > > > Best regards,
> > > > <pothekid@> wrote:
> > > > > Hi Soeren,
works
> > > now
> > > > for
most,
> > so
> > > > I’ve
> > gave
> > > me
> > > > a
> > pushing
> > > > difficulties
> > radius
this
> > is
> > > > > possible ?
> > bottom
> > > of
> > > > my
will
> > > send
> > > > you
it.
> > > > > Thank you again,
> > > > > Pierre-Olivier
<support@>
> > > > wrote:
> > > > > > Hi Pierre
that
> > > the
> > > > > analysis
is
> > as
> > > you
> > > > > expect.
the
> > > > > abduction angle
correctly
> > > > > because then
(nStep
> > > > > values) and
still
> > > look
> > > > at
> > > > > these
contain “garbage”
> > > > numbers.
function
> > in
> > > > the
just
> > > > return
> > > > > the last
guess.
> > output
> > > > > function in
> > > reported
> > > > ok
> > > > > but if
work
> > I
> > > > believe
> > because
> > > it
> > > > > fails in
> > because
> > > the
> > > > > kinematics
> > > > > > has been solved ok.
of
> > > > values
> > > > > which are
think
> > you
> > > > should
and
> > then
> > > > > process them
> > > > > > externally.
> > > > > > Best regards
> > > > > > _____
> > > > > On Behalf
> > > > > > Hi guys,
of
the
> > > > model,
of
> > the
> > > > humeral
> > model
> > > > allows
contact
> > of
> > > > the
by
> > a
> > > > driver
the
> > > > elliptic
a
> > > bone,
> > > > it
allowed)
> > > (It
> > > > was
> > > reaction
> > > > of
it. So
> > > > now, the
that,
> > the
> > > > geometry
stops.
> > > It
> > > > is
> > geometry
> > > is
> > > > > > efficient or not.
simulation.
> > I
> > > > look on
> > (kinematic
> > think
> > > > that
simulation
> > > > stops
> > changing
> > hope …).
> > > I
> > > > send
> > > everyone
> > > > of
> > > > > > bye bye
> > > > > > Pierre
Hi again Sylvain,
my model works well now with the Reaction.Type turned
on within the Contact driver. However, it makes this reaction able to
pull or push. For some set-up of the parameters of the ellipse, I got
negative forces for the Contact driver. It tells me that the permanent
contact with the acromion is not valid in all the case. Maybe I should
know the real displacement in term of the elliptic shape, prior to
proceed to the inverse analysis.
Also, it is not only the deltoid that pulls on the humeral head, it is
also the WeakMuscles. These muscles are not there normally and when I
comment them, it gives me a “Muscle recruitment” error if the tStart
is 0. Thus, I want to know why the deltoid can’t do the complete
abduction by itself ?
Thank you again.
Pierre-Olivier
> Hi,
> head.
> Best regards.
> <pothekid@> wrote:
> > Hi Sylvain,
> not
> term
> the
> at
> not
> > useful for me.
> case,
> > Pierre-Olivier
> wrote:
> > > Hi Pierre,
> node
> where
> you
> Base
> follow
> a
> that
> this
> forces
> forces.
> to
> shape.
> segments
> what
> > > you need.
> friction
> muscles?
> > > together.
> have
> public, I
> you
> > > Best Regards
> > > <pothekid@> wrote:
> > > > Hi Sylvain,
> that
> > > appears.
> up
> force is
> arrows
> > > would
> > > > perform better ?
> still
> to
> head
> experimental
> > > set-
> I
> > > use
> origin
> the
> changing
> > > P8
> set
> help
> > > > me a lot.
> > > > Pierre.
> > > > wrote:
> > > > > Hi Pierre-Olivier
> > > contact
> enough
> have a
> > > > high
> contact
> > > > points
> strength at
> > > because
> > > create
> point.
> > > > This
> take
> > > > care
> > > actually
> the
> > > > > contact point.
> with
> > > the
> is
> > > now
> point
> > > > you
> carry
> > > > the
> the
> the
> > > > recall
> > > file.
> > > > > Best regards,
> > > > > <pothekid@> wrote:
> > > > > > Hi Soeren,
> works
> > > > now
> > > > > for
> most,
> > > so
> > > > > I’ve
> > > gave
> > > > me
> > > > > a
> > > pushing
> > > > > difficulties
> > > radius
> this
> > > is
> > > > > > possible ?
> > > bottom
> > > > of
> > > > > my
> will
> > > > send
> > > > > you
> it.
> > > > > > Thank you again,
> > > > > > Pierre-Olivier
> <support@>
> > > > > wrote:
> > > > > > > Hi Pierre
> that
> > > > the
> > > > > > analysis
> is
> > > as
> > > > you
> > > > > > expect.
> the
> > > > > > abduction angle
> correctly
> > > > > > because then
> (nStep
> > > > > > values) and
> still
> > > > look
> > > > > at
> > > > > > these
> contain “garbage”
> > > > > numbers.
> function
> > > in
> > > > > the
> just
> > > > > return
> > > > > > the last
> guess.
> > > output
> > > > > > function in
> > > > reported
> > > > > ok
> > > > > > but if
> work
> > > I
> > > > > believe
> > > because
> > > > it
> > > > > > fails in
> > > because
> > > > the
> > > > > > kinematics
> > > > > > > has been solved ok.
> of
> > > > > values
> > > > > > which are
> think
> > > you
> > > > > should
> and
> > > then
> > > > > > process them
> > > > > > > externally.
> > > > > > > Best regards
> > > > > > > _____
> > > > > > On Behalf
> > > > > > > Hi guys,
> of
> the
> > > > > model,
> of
> > > the
> > > > > humeral
> > > model
> > > > > allows
> contact
> > > of
> > > > > the
> by
> > > a
> > > > > driver
> the
> > > > > elliptic
> a
> > > > bone,
> > > > > it
> allowed)
> > > > (It
> > > > > was
> > > > reaction
> > > > > of
> it. So
> > > > > now, the
> that,
> > > the
> > > > > geometry
> stops.
> > > > It
> > > > > is
> > > geometry
> > > > is
> > > > > > > efficient or not.
> simulation.
> > > I
> > > > > look on
> > > (kinematic
> > > think
> > > > > that
> simulation
> > > > > stops
> > > changing
> > > hope …).
> > > > I
> > > > > send
> > > > everyone
> > > > > of
> > > > > > > bye bye
> > > > > > > Pierre
Hi Pierre
The contact force you have applied works on the contact segment. This
element will need to be carried by the driver otherwise the model will be
unbalanced and unable to solve; it can not be left unbalanced.
The contact force you have applied can only do a pushing force, so the
reactions you will see in this contact driver will only be in one direction.
The weak muscles also need to be there, there can not be dof in the model
which are unbalanced. Even if these are supposed to have force, it will lead
to numeric problems if they are left unbalanced.
The reason why the weak muscles are needed must be a moment balance issue
there appears to be situation where the deltoid muscle it self can not
balance the upper arm. To me it sounds reasonable, these weak muscles
replicated the joint reactions up/down and these would always be non zero.
In you had more muscles in the model these might be able to control this
up/down dofs., and the weak muscles could be excluded.
Sent: 20 February 2008 03:31
Subject: [AnyScript] Re: shoulder 2D model
Hi again Sylvain,
Thank you again.
Pierre-Olivier
> Hi,
> head.
> Best regards.
> <pothekid@> wrote:
> > Hi Sylvain,
> not
> term
> the
> at
> not
> > useful for me.
> case,
> > Pierre-Olivier
> wrote:
> > > Hi Pierre,
> node
> where
> you
> Base
> follow
> a
> that
> this
> forces
> forces.
> to
> shape.
> segments
> what
> > > you need.
> friction
> > > http://www.anybodyt <http://www.anybodytech.com/116.0.html?&tx_ttnews>
> muscles?
> > > together.
> have
> public, I
> you
> > > Best Regards
> > > <pothekid@> wrote:
> > > > Hi Sylvain,
> that
> > > appears.
> up
> force is
> arrows
> > > would
> > > > perform better ?
> still
> to
> head
> experimental
> > > set-
> I
> > > use
> origin
> the
> changing
> > > P8
> set
> help
> > > > me a lot.
> > > > Pierre.
> > > > wrote:
> > > > > Hi Pierre-Olivier
> > > contact
> enough
> have a
> > > > high
> contact
> > > > points
> strength at
> > > because
> > > create
> point.
> > > > This
> take
> > > > care
> > > actually
> the
> > > > > contact point.
> with
> > > the
> is
> > > now
> point
> > > > you
> carry
> > > > the
> the
> the
> > > > recall
> > > file.
> > > > > Best regards,
> > > > > <pothekid@> wrote:
> > > > > > Hi Soeren,
> works
> > > > now
> > > > > for
> most,
> > > so
> > > > > I’ve
> > > gave
> > > > me
> > > > > a
> > > pushing
> > > > > difficulties
> > > radius
> this
> > > is
> > > > > > possible ?
> > > bottom
> > > > of
> > > > > my
> will
> > > > send
> > > > > you
> it.
> > > > > > Thank you again,
> > > > > > Pierre-Olivier
> <support@>
> > > > > wrote:
> > > > > > > Hi Pierre
> that
> > > > the
> > > > > > analysis
> is
> > > as
> > > > you
> > > > > > expect.
> the
> > > > > > abduction angle
> correctly
> > > > > > because then
> (nStep
> > > > > > values) and
> still
> > > > look
> > > > > at
> > > > > > these
> contain “garbage”
> > > > > numbers.
> function
> > > in
> > > > > the
> just
> > > > > return
> > > > > > the last
> guess.
> > > output
> > > > > > function in
> > > > reported
> > > > > ok
> > > > > > but if
> work
> > > I
> > > > > believe
> > > because
> > > > it
> > > > > > fails in
> > > because
> > > > the
> > > > > > kinematics
> > > > > > > has been solved ok.
> of
> > > > > values
> > > > > > which are
> think
> > > you
> > > > > should
> and
> > > then
> > > > > > process them
> > > > > > > externally.
> > > > > > > Best regards
> > > > > > > _____
> > > > > > > From: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com>
ps.com
> > > > > [mailto:anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com>
ps.com]
> > > > > > On Behalf
> > > > > > > To: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com>
ps.com
> > > > > > > Hi guys,
> of
> the
> > > > > model,
> of
> > > the
> > > > > humeral
> > > model
> > > > > allows
> contact
> > > of
> > > > > the
> by
> > > a
> > > > > driver
> the
> > > > > elliptic
> a
> > > > bone,
> > > > > it
> allowed)
> > > > (It
> > > > > was
> > > > reaction
> > > > > of
> it. So
> > > > > now, the
> that,
> > > the
> > > > > geometry
> stops.
> > > > It
> > > > > is
> > > geometry
> > > > is
> > > > > > > efficient or not.
> simulation.
> > > I
> > > > > look on
> > > (kinematic
> > > think
> > > > > that
> simulation
> > > > > stops
> > > changing
> > > hope …).
> > > > I
> > > > > send
> > > > everyone
> > > > > of
> > > > > > > bye bye
> > > > > > > Pierre
Hi Soren,
thank you for your support. Now I have a model that represent
more my pathology and I have also created a Matlab algorithm that find
the movement of the humeral head and import it into my AnyBody model.
My Matlab algorithm compute the minimum force in the deltoid to
perform an increment of abduction with a moment balance (constant
velocity). If there is a non-equilibrium of the forces and a degree of
freedom in the direction of the force, there is automatically an
increment of displacement. This is the case for the vertical
displacement in my model.
Now, I want to know how Anybody solve a problem. I know that for each
step time, it use the min/max criterion to find the minimum muscle
activity. Does it works like my Matlab routine ?
I have compared the Matlab results from those obtained in Anybody from
the same movement and in a lot of situation it gives me similar
results. However, there is some differences that I’m not able to
explain. Do you think that my Matlab routine is well made ?
I send you my results (Matlab & AnyBody) for a particular case under
(PO_Lemieux_shoulder_model_March_18). Just take a look and give me
your idea about it.
Thank you again.
Pierre
> Hi Pierre
will be
direction.
model
will lead
issue
zero.
> Best regards
> Søren
> _____
On Behalf
> Hi again Sylvain,
> Thank you again.
> Pierre-Olivier
> “AnyBody Support” <support@> wrote:
> > Hi,
> > head.
> > Best regards.
ps.com,
> > <pothekid@> wrote:
> > > Hi Sylvain,
> > not
> > term
> > the
> > at
> > not
> > > useful for me.
> > case,
> > > Pierre-Olivier
ps.com,
> > wrote:
> > > > Hi Pierre,
> > node
> > where
> > you
> > Base
> > follow
> > a
> > that
> > this
> > forces
> > forces.
> > to
> > shape.
> > segments
> > what
> > > > you need.
> > friction
> > > > http://www.anybodyt
> > muscles?
> > > > together.
> > have
> > public, I
> > you
> > > > Best Regards
> > > > <pothekid@> wrote:
> > > > > Hi Sylvain,
> > that
> > > > appears.
> > up
> > force is
> > arrows
> > > > would
> > > > > perform better ?
> > still
> > to
> > head
> > experimental
> > > > set-
> > I
> > > > use
> > origin
> > the
> > changing
> > > > P8
> > set
> > help
> > > > > me a lot.
> > > > > Pierre.
> > > > > wrote:
> > > > > > Hi Pierre-Olivier
> > > > contact
> > enough
> > have a
> > > > > high
> > contact
> > > > > points
> > strength at
> > > > because
> > > > create
> > point.
> > > > > This
> > take
> > > > > care
> > > > actually
> > the
> > > > > > contact point.
> > with
> > > > the
> > is
> > > > now
> > point
> > > > > you
> > carry
> > > > > the
> > the
> > the
> > > > > recall
> > > > file.
> > > > > > Best regards,
> > > > > > <pothekid@> wrote:
> > > > > > > Hi Soeren,
> > works
> > > > > now
> > > > > > for
> > most,
> > > > so
> > > > > > I’ve
> > > > gave
> > > > > me
> > > > > > a
> > > > pushing
> > > > > > difficulties
> > > > radius
> > this
> > > > is
> > > > > > > possible ?
> > > > bottom
> > > > > of
> > > > > > my
> > will
> > > > > send
> > > > > > you
> > it.
> > > > > > > Thank you again,
> > > > > > > Pierre-Olivier
> > <support@>
> > > > > > wrote:
> > > > > > > > Hi Pierre
> > that
> > > > > the
> > > > > > > analysis
> > is
> > > > as
> > > > > you
> > > > > > > expect.
> > the
> > > > > > > abduction angle
> > correctly
> > > > > > > because then
> > (nStep
> > > > > > > values) and
> > still
> > > > > look
> > > > > > at
> > > > > > > these
> > contain “garbage”
> > > > > > numbers.
> > function
> > > > in
> > > > > > the
> > just
> > > > > > return
> > > > > > > the last
> > guess.
> > > > output
> > > > > > > function in
> > > > > reported
> > > > > > ok
> > > > > > > but if
> > work
> > > > I
> > > > > > believe
> > > > because
> > > > > it
> > > > > > > fails in
> > > > because
> > > > > the
> > > > > > > kinematics
> > > > > > > > has been solved ok.
> > of
> > > > > > values
> > > > > > > which are
> > think
> > > > you
> > > > > > should
> > and
> > > > then
> > > > > > > process them
> > > > > > > > externally.
> > > > > > > > Best regards
> > > > > > > > _____
> ps.com
> ps.com]
> > > > > > > On Behalf
> ps.com
> > > > > > > > Hi guys,
> > of
> > the
> > > > > > model,
> > of
> > > > the
> > > > > > humeral
> > > > model
> > > > > > allows
> > contact
> > > > of
> > > > > > the
> > by
> > > > a
> > > > > > driver
> > the
> > > > > > elliptic
> > a
> > > > > bone,
> > > > > > it
> > allowed)
> > > > > (It
> > > > > > was
> > > > > reaction
> > > > > > of
> > it. So
> > > > > > now, the
> > that,
> > > > the
> > > > > > geometry
> > stops.
> > > > > It
> > > > > > is
> > > > geometry
> > > > > is
> > > > > > > > efficient or not.
> > simulation.
> > > > I
> > > > > > look on
> > > > (kinematic
> > > > think
> > > > > > that
> > simulation
> > > > > > stops
> > > > changing
> > > > hope …).
> > > > > I
> > > > > > send
> > > > > everyone
> > > > > > of
> > > > > > > > bye bye
> > > > > > > > Pierre
Hi again,
I’ve forgot to mention you that I’ve put together the
WeakMuscle1 (pulling muscle) and the deltoid muscle, because they do a
common task, that is normally perform by the deltoid itself. I’ve made
the same thing with the AcromionPush-Conditional-contact-Muscle and
WeakMuscle2 (pushing muscle). Do you think that can be a mistake ?
Pierre
<pothekid@…> wrote:
> Hi Soren,
> your idea about it.
> Thank you again.
> Pierre
> — In anyscript@yahoogroups.com, “AnyBody Support” <support@> wrote:
> > Hi Pierre
> will be
> direction.
> model
> will lead
> issue
> zero.
control this
> > Best regards
> > Søren
> > _____
> On Behalf
> > Hi again Sylvain,
> > Thank you again.
> > Pierre-Olivier
ps.com,
> > > Hi,
can
> > > head.
> > > Best regards.
> ps.com,
> > > <pothekid@> wrote:
> > > > Hi Sylvain,
> > > not
> > > term
> > > the
> > > at
> > > not
> > > > useful for me.
> > > case,
> > > > Pierre-Olivier
> ps.com,
> > > wrote:
> > > > > Hi Pierre,
> > > node
> > > where
> > > you
> > > Base
> > > follow
P12 to
> > > a
the
> > > that
> > > this
> > > forces
> > > forces.
able
> > > to
> > > shape.
> > > segments
> > > what
> > > > > you need.
talk
> > > friction
> > > > > http://www.anybodyt
> > > muscles?
> > > > > together.
> > > have
the
> > > public, I
> > > you
> > > > > Best Regards
> > > > > <pothekid@> wrote:
> > > > > > Hi Sylvain,
> > > that
> > > > > appears.
mixed
> > > up
> > > force is
> > > arrows
“ContactRotPush”
> > > > > would
> > > > > > perform better ?
> > > still
> > > to
> > > head
> > > experimental
> > > > > set-
when
> > > I
> > > > > use
> > > origin
> > > the
> > > changing
> > > > > P8
first
> > > set
> > > help
> > > > > > me a lot.
> > > > > > Pierre.
> > > > > > wrote:
> > > > > > > Hi Pierre-Olivier
> > > > > contact
> > > enough
> > > have a
> > > > > > high
> > > contact
> > > > > > points
> > > strength at
> > > > > because
> > > > > create
> > > point.
> > > > > > This
> > > take
> > > > > > care
> > > > > actually
> > > the
> > > > > > > contact point.
> > > with
> > > > > the
> > > is
> > > > > now
> > > point
> > > > > > you
> > > carry
> > > > > > the
depends on
> > > the
> > > the
as I
> > > > > > recall
JointAndDriver.any
> > > > > file.
> > > > > > > Best regards,
> > > > > > > <pothekid@> wrote:
> > > > > > > > Hi Soeren,
> > > works
> > > > > > now
> > > > > > > for
> > > most,
> > > > > so
> > > > > > > I’ve
John
> > > > > gave
> > > > > > me
> > > > > > > a
> > > > > pushing
> > > > > > > difficulties
> > > > > radius
> > > this
> > > > > is
> > > > > > > > possible ?
> > > > > bottom
> > > > > > of
> > > > > > > my
> > > will
> > > > > > send
> > > > > > > you
> > > it.
> > > > > > > > Thank you again,
> > > > > > > > Pierre-Olivier
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > Hi Pierre
> > > that
> > > > > > the
> > > > > > > > analysis
> > > is
> > > > > as
> > > > > > you
> > > > > > > > expect.
> > > the
> > > > > > > > abduction angle
> > > correctly
> > > > > > > > because then
> > > (nStep
> > > > > > > > values) and
> > > still
> > > > > > look
> > > > > > > at
> > > > > > > > these
> > > contain “garbage”
> > > > > > > numbers.
> > > function
> > > > > in
> > > > > > > the
> > > just
> > > > > > > return
> > > > > > > > the last
> > > guess.
> > > > > output
> > > > > > > > function in
> > > > > > reported
> > > > > > > ok
> > > > > > > > but if
> > > work
> > > > > I
> > > > > > > believe
> > > > > because
> > > > > > it
> > > > > > > > fails in
> > > > > because
> > > > > > the
> > > > > > > > kinematics
> > > > > > > > > has been solved ok.
max
> > > of
> > > > > > > values
> > > > > > > > which are
> > > think
> > > > > you
> > > > > > > should
> > > and
> > > > > then
> > > > > > > > process them
> > > > > > > > > externally.
> > > > > > > > > Best regards
> > > > > > > > > _____
> > ps.com
> > ps.com]
> > > > > > > > On Behalf
> > ps.com
> > > > > > > > > Hi guys,
> > > of
> > > the
> > > > > > > model,
> > > of
> > > > > the
> > > > > > > humeral
So, my
> > > > > model
> > > > > > > allows
> > > contact
> > > > > of
> > > > > > > the
allowed
> > > by
> > > > > a
> > > > > > > driver
properties of
> > > the
> > > > > > > elliptic
> > > a
> > > > > > bone,
> > > > > > > it
> > > allowed)
> > > > > > (It
> > > > > > > was
> > > > > > reaction
> > > > > > > of
> > > it. So
> > > > > > > now, the
> > > that,
> > > > > the
> > > > > > > geometry
> > > stops.
> > > > > > It
> > > > > > > is
> > > > > geometry
> > > > > > is
> > > > > > > > > efficient or not.
> > > simulation.
> > > > > I
> > > > > > > look on
> > > > > (kinematic
> > > > > think
> > > > > > > that
> > > simulation
> > > > > > > stops
> > > > > changing
> > > > > hope …).
> > > > > > I
> > > > > > > send
> > > > > > everyone
> > > > > > > of
> > > > > > > > > bye bye
> > > > > > > > > Pierre
Hi Pierre
I think I understand what your algorithm is doing, it finds the minimum
deltoid force and if there is a force unbalance it moves the humeral until
balance is obtained.
Using the build in optimizer in AnyBody something similar should be possible
I guess, but it will be a slightly differently approach. Basically you will
need a model that will always be able to balance itself through artificial
joint reactions, but through the optimization you can change the motion so
that it tries to minimize those reactions.
1 you will need the extra muscle that ensures that a force balance can
always be obtained.
2 a design variable has to be defined, this is the translation, maybe this
should be done using an interpolation function…
3 an objective function has to be setup, here I would choose to minimize the
forces in the artificial muscles which you did not want to become active. So
you will be minimizing these reaction forces by moving the humeral head to
another position.
There is a tutorial of parameter and optimization studies it might be
helpful.
I can not judge if the MatLab code is ok sorry, I can think of the following
questions
1 Are there any differences in the models, that in anyway could justify
these differences?
2 What about muscles wrapping, how is this done in MatLab…
3 Muscles strength models
4 Recruitment criteria?
Etc…
Sent: 18 March 2008 19:18
Hi Soren,
your idea about it.
Thank you again.
Pierre
> Hi Pierre
will be
direction.
model
will lead
issue
zero.
> Best regards
> Søren
> _____
On Behalf
> Hi again Sylvain,
> Thank you again.
> Pierre-Olivier
> > Hi,
> > head.
> > Best regards.
ps.com,
> > <pothekid@> wrote:
> > > Hi Sylvain,
> > not
> > term
> > the
> > at
> > not
> > > useful for me.
> > case,
> > > Pierre-Olivier
ps.com,
> > wrote:
> > > > Hi Pierre,
> > node
> > where
> > you
> > Base
> > follow
> > a
> > that
> > this
> > forces
> > forces.
> > to
> > shape.
> > segments
> > what
> > > > you need.
> > friction
> > > > http://www.anybodyt
<http://www.anybodyt <http://www.anybodytech.com/116.0.html?&tx_ttnews>
> > muscles?
> > > > together.
> > have
> > public, I
> > you
> > > > Best Regards
> > > > <pothekid@> wrote:
> > > > > Hi Sylvain,
> > that
> > > > appears.
> > up
> > force is
> > arrows
> > > > would
> > > > > perform better ?
> > still
> > to
> > head
> > experimental
> > > > set-
> > I
> > > > use
> > origin
> > the
> > changing
> > > > P8
> > set
> > help
> > > > > me a lot.
> > > > > Pierre.
> > > > > wrote:
> > > > > > Hi Pierre-Olivier
> > > > contact
> > enough
> > have a
> > > > > high
> > contact
> > > > > points
> > strength at
> > > > because
> > > > create
> > point.
> > > > > This
> > take
> > > > > care
> > > > actually
> > the
> > > > > > contact point.
> > with
> > > > the
> > is
> > > > now
> > point
> > > > > you
> > carry
> > > > > the
> > the
> > the
> > > > > recall
> > > > file.
> > > > > > Best regards,
> > > > > > <pothekid@> wrote:
> > > > > > > Hi Soeren,
> > works
> > > > > now
> > > > > > for
> > most,
> > > > so
> > > > > > I’ve
> > > > gave
> > > > > me
> > > > > > a
> > > > pushing
> > > > > > difficulties
> > > > radius
> > this
> > > > is
> > > > > > > possible ?
> > > > bottom
> > > > > of
> > > > > > my
> > will
> > > > > send
> > > > > > you
> > it.
> > > > > > > Thank you again,
> > > > > > > Pierre-Olivier
> > <support@>
> > > > > > wrote:
> > > > > > > > Hi Pierre
> > that
> > > > > the
> > > > > > > analysis
> > is
> > > > as
> > > > > you
> > > > > > > expect.
> > the
> > > > > > > abduction angle
> > correctly
> > > > > > > because then
> > (nStep
> > > > > > > values) and
> > still
> > > > > look
> > > > > > at
> > > > > > > these
> > contain “garbage”
> > > > > > numbers.
> > function
> > > > in
> > > > > > the
> > just
> > > > > > return
> > > > > > > the last
> > guess.
> > > > output
> > > > > > > function in
> > > > > reported
> > > > > > ok
> > > > > > > but if
> > work
> > > > I
> > > > > > believe
> > > > because
> > > > > it
> > > > > > > fails in
> > > > because
> > > > > the
> > > > > > > kinematics
> > > > > > > > has been solved ok.
> > of
> > > > > > values
> > > > > > > which are
> > think
> > > > you
> > > > > > should
> > and
> > > > then
> > > > > > > process them
> > > > > > > > externally.
> > > > > > > > Best regards
> > > > > > > > _____
> ps.com
> ps.com]
> > > > > > > On Behalf
> ps.com
> > > > > > > > Hi guys,
> > of
> > the
> > > > > > model,
> > of
> > > > the
> > > > > > humeral
> > > > model
> > > > > > allows
> > contact
> > > > of
> > > > > > the
> > by
> > > > a
> > > > > > driver
> > the
> > > > > > elliptic
> > a
> > > > > bone,
> > > > > > it
> > allowed)
> > > > > (It
> > > > > > was
> > > > > reaction
> > > > > > of
> > it. So
> > > > > > now, the
> > that,
> > > > the
> > > > > > geometry
> > stops.
> > > > > It
> > > > > > is
> > > > geometry
> > > > > is
> > > > > > > > efficient or not.
> > simulation.
> > > > I
> > > > > > look on
> > > > (kinematic
> > > > think
> > > > > > that
> > simulation
> > > > > > stops
> > > > changing
> > > > hope …).
> > > > > I
> > > > > > send
> > > > > everyone
> > > > > > of
> > > > > > > > bye bye
> > > > > > > > Pierre
Hi Pierre
I am not sure I really understand this, does this means that the muscles
configuration in the two models are not the same?
If this is the case and if you have force in these muscles in the AnyBody
model, then I guess your results will never be exactly the same…
Maybe you should try to identify if the areas where you have large
differences corresponds to the locations where you have force in these
artificial muscles…
Sent: 18 March 2008 19:34
Hi again,
Pierre
<pothekid@…> wrote:
> Hi Soren,
> your idea about it.
> Thank you again.
> Pierre
> > Hi Pierre
> will be
> direction.
> model
> will lead
> issue
> zero.
control this
> > Best regards
> > Søren
> > _____
> On Behalf
> > Hi again Sylvain,
> > Thank you again.
> > Pierre-Olivier
ps.com,
> > > Hi,
can
> > > head.
> > > Best regards.
> ps.com,
> > > <pothekid@> wrote:
> > > > Hi Sylvain,
> > > not
> > > term
> > > the
> > > at
> > > not
> > > > useful for me.
> > > case,
> > > > Pierre-Olivier
> ps.com,
> > > wrote:
> > > > > Hi Pierre,
> > > node
> > > where
> > > you
> > > Base
> > > follow
P12 to
> > > a
the
> > > that
> > > this
> > > forces
> > > forces.
able
> > > to
> > > shape.
> > > segments
> > > what
> > > > > you need.
talk
> > > friction
> > > > > http://www.anybodyt
> > > muscles?
> > > > > together.
> > > have
the
> > > public, I
> > > you
> > > > > Best Regards
> > > > > <pothekid@> wrote:
> > > > > > Hi Sylvain,
> > > that
> > > > > appears.
mixed
> > > up
> > > force is
> > > arrows
“ContactRotPush”
> > > > > would
> > > > > > perform better ?
> > > still
> > > to
> > > head
> > > experimental
> > > > > set-
when
> > > I
> > > > > use
> > > origin
> > > the
> > > changing
> > > > > P8
first
> > > set
> > > help
> > > > > > me a lot.
> > > > > > Pierre.
> > > > > > wrote:
> > > > > > > Hi Pierre-Olivier
> > > > > contact
> > > enough
> > > have a
> > > > > > high
> > > contact
> > > > > > points
> > > strength at
> > > > > because
> > > > > create
> > > point.
> > > > > > This
> > > take
> > > > > > care
> > > > > actually
> > > the
> > > > > > > contact point.
> > > with
> > > > > the
> > > is
> > > > > now
> > > point
> > > > > > you
> > > carry
> > > > > > the
depends on
> > > the
> > > the
as I
> > > > > > recall
JointAndDriver.any
> > > > > file.
> > > > > > > Best regards,
> > > > > > > <pothekid@> wrote:
> > > > > > > > Hi Soeren,
> > > works
> > > > > > now
> > > > > > > for
> > > most,
> > > > > so
> > > > > > > I’ve
John
> > > > > gave
> > > > > > me
> > > > > > > a
> > > > > pushing
> > > > > > > difficulties
> > > > > radius
> > > this
> > > > > is
> > > > > > > > possible ?
> > > > > bottom
> > > > > > of
> > > > > > > my
> > > will
> > > > > > send
> > > > > > > you
> > > it.
> > > > > > > > Thank you again,
> > > > > > > > Pierre-Olivier
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > Hi Pierre
> > > that
> > > > > > the
> > > > > > > > analysis
> > > is
> > > > > as
> > > > > > you
> > > > > > > > expect.
> > > the
> > > > > > > > abduction angle
> > > correctly
> > > > > > > > because then
> > > (nStep
> > > > > > > > values) and
> > > still
> > > > > > look
> > > > > > > at
> > > > > > > > these
> > > contain “garbage”
> > > > > > > numbers.
> > > function
> > > > > in
> > > > > > > the
> > > just
> > > > > > > return
> > > > > > > > the last
> > > guess.
> > > > > output
> > > > > > > > function in
> > > > > > reported
> > > > > > > ok
> > > > > > > > but if
> > > work
> > > > > I
> > > > > > > believe
> > > > > because
> > > > > > it
> > > > > > > > fails in
> > > > > because
> > > > > > the
> > > > > > > > kinematics
> > > > > > > > > has been solved ok.
max
> > > of
> > > > > > > values
> > > > > > > > which are
> > > think
> > > > > you
> > > > > > > should
> > > and
> > > > > then
> > > > > > > > process them
> > > > > > > > > externally.
> > > > > > > > > Best regards
> > > > > > > > > _____
> > ps.com
> > ps.com]
> > > > > > > > On Behalf
> > ps.com
> > > > > > > > > Hi guys,
> > > of
> > > the
> > > > > > > model,
> > > of
> > > > > the
> > > > > > > humeral
So, my
> > > > > model
> > > > > > > allows
> > > contact
> > > > > of
> > > > > > > the
allowed
> > > by
> > > > > a
> > > > > > > driver
properties of
> > > the
> > > > > > > elliptic
> > > a
> > > > > > bone,
> > > > > > > it
> > > allowed)
> > > > > > (It
> > > > > > > was
> > > > > > reaction
> > > > > > > of
> > > it. So
> > > > > > > now, the
> > > that,
> > > > > the
> > > > > > > geometry
> > > stops.
> > > > > > It
> > > > > > > is
> > > > > geometry
> > > > > > is
> > > > > > > > > efficient or not.
> > > simulation.
> > > > > I
> > > > > > > look on
> > > > > (kinematic
> > > > > think
> > > > > > > that
> > > simulation
> > > > > > > stops
> > > > > changing
> > > > > hope …).
> > > > > > I
> > > > > > > send
> > > > > > everyone
> > > > > > > of
> > > > > > > > > bye bye
> > > > > > > > > Pierre
Hi Soren,
the Matlab routine (which I’ve created entirely) is pretty
simple. For each positions, it perform a calculation of the lever arm
and the angle of the upper part of the muscle to separate the X and Y
direction of the muscle force. When the contact between the prosthesis
and the acromion occurs, the acromial reaction is possible and is
drawn on the figure. There is no recruitment muscle because there is
only one muscle in my routine (deltoid).
The strength model is a constant force model. Like you can see, the
muscle wrapping is done by using a thin rope between the origin and
insertion point.
I send you a little video of all that under (GH_Movement.zip).
I understand your idea about creating the same routine in Anybody, but
I don’t see any interest about doing that if the results between
AnyBody and Matlab are the same.
My idea was rather to find the correct movement pattern in term of
prosthetic dimensions in Matlab and then put this movement into my
AnyBody model, to find the deltoid forces. By obtaining the same
results in AnyBody and Matlab, I think this is a way to verify the
accuracy of my findings… What do you think about that ?
I have try to get the same models between AnyBody and Matlab. To do
so, I’ve put the static friction coefficient to 0 and put a constant
force model for the deltoid. Thus, I think that the differences are
just in the WeakMuscle definition. In my Matlab routine, there is no
WeakMuscle because the acromion force give us a hint that something
don’t work during the first abduction degrees (check the results.jpg).
I hope that was more clear for you.
Thank you very much.
Pierre
> Hi Pierre
until
possible
you will
artificial
motion so
> always be obtained.
maybe this
minimize the
active. So
head to
> another position.
> helpful.
following
> questions
> these differences?
> Etc…
> Best regards
> _____
On Behalf
> Hi Soren,
> your idea about it.
> Thank you again.
> Pierre
> > Hi Pierre
> will be
> direction.
> model
> will lead
> issue
> zero.
control this
> > Best regards
> > Søren
> > _____
> On Behalf
> > Hi again Sylvain,
> > Thank you again.
> > Pierre-Olivier
ps.com,
> > > Hi,
can
> > > head.
> > > Best regards.
> ps.com,
> > > <pothekid@> wrote:
> > > > Hi Sylvain,
> > > not
> > > term
> > > the
> > > at
> > > not
> > > > useful for me.
> > > case,
> > > > Pierre-Olivier
> ps.com,
> > > wrote:
> > > > > Hi Pierre,
> > > node
> > > where
> > > you
> > > Base
> > > follow
P12 to
> > > a
the
> > > that
> > > this
> > > forces
> > > forces.
able
> > > to
> > > shape.
> > > segments
> > > what
> > > > > you need.
talk
> > > friction
> > > > > http://www.anybodyt
> > > muscles?
> > > > > together.
> > > have
the
> > > public, I
> > > you
> > > > > Best Regards
> > > > > <pothekid@> wrote:
> > > > > > Hi Sylvain,
> > > that
> > > > > appears.
mixed
> > > up
> > > force is
> > > arrows
“ContactRotPush”
> > > > > would
> > > > > > perform better ?
> > > still
> > > to
> > > head
> > > experimental
> > > > > set-
when
> > > I
> > > > > use
> > > origin
> > > the
> > > changing
> > > > > P8
first
> > > set
> > > help
> > > > > > me a lot.
> > > > > > Pierre.
> > > > > > wrote:
> > > > > > > Hi Pierre-Olivier
> > > > > contact
> > > enough
> > > have a
> > > > > > high
> > > contact
> > > > > > points
> > > strength at
> > > > > because
> > > > > create
> > > point.
> > > > > > This
> > > take
> > > > > > care
> > > > > actually
> > > the
> > > > > > > contact point.
> > > with
> > > > > the
> > > is
> > > > > now
> > > point
> > > > > > you
> > > carry
> > > > > > the
depends on
> > > the
> > > the
as I
> > > > > > recall
JointAndDriver.any
> > > > > file.
> > > > > > > Best regards,
> > > > > > > <pothekid@> wrote:
> > > > > > > > Hi Soeren,
> > > works
> > > > > > now
> > > > > > > for
> > > most,
> > > > > so
> > > > > > > I’ve
John
> > > > > gave
> > > > > > me
> > > > > > > a
> > > > > pushing
> > > > > > > difficulties
> > > > > radius
> > > this
> > > > > is
> > > > > > > > possible ?
> > > > > bottom
> > > > > > of
> > > > > > > my
> > > will
> > > > > > send
> > > > > > > you
> > > it.
> > > > > > > > Thank you again,
> > > > > > > > Pierre-Olivier
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > Hi Pierre
> > > that
> > > > > > the
> > > > > > > > analysis
> > > is
> > > > > as
> > > > > > you
> > > > > > > > expect.
> > > the
> > > > > > > > abduction angle
> > > correctly
> > > > > > > > because then
> > > (nStep
> > > > > > > > values) and
> > > still
> > > > > > look
> > > > > > > at
> > > > > > > > these
> > > contain “garbage”
> > > > > > > numbers.
> > > function
> > > > > in
> > > > > > > the
> > > just
> > > > > > > return
> > > > > > > > the last
> > > guess.
> > > > > output
> > > > > > > > function in
> > > > > > reported
> > > > > > > ok
> > > > > > > > but if
> > > work
> > > > > I
> > > > > > > believe
> > > > > because
> > > > > > it
> > > > > > > > fails in
> > > > > because
> > > > > > the
> > > > > > > > kinematics
> > > > > > > > > has been solved ok.
max
> > > of
> > > > > > > values
> > > > > > > > which are
> > > think
> > > > > you
> > > > > > > should
> > > and
> > > > > then
> > > > > > > > process them
> > > > > > > > > externally.
> > > > > > > > > Best regards
> > > > > > > > > _____
> > ps.com
> > ps.com]
> > > > > > > > On Behalf
> > ps.com
> > > > > > > > > Hi guys,
> > > of
> > > the
> > > > > > > model,
> > > of
> > > > > the
> > > > > > > humeral
So, my
> > > > > model
> > > > > > > allows
> > > contact
> > > > > of
> > > > > > > the
allowed
> > > by
> > > > > a
> > > > > > > driver
properties of
> > > the
> > > > > > > elliptic
> > > a
> > > > > > bone,
> > > > > > > it
> > > allowed)
> > > > > > (It
> > > > > > > was
> > > > > > reaction
> > > > > > > of
> > > it. So
> > > > > > > now, the
> > > that,
> > > > > the
> > > > > > > geometry
> > > stops.
> > > > > > It
> > > > > > > is
> > > > > geometry
> > > > > > is
> > > > > > > > > efficient or not.
> > > simulation.
> > > > > I
> > > > > > > look on
> > > > > (kinematic
> > > > > think
> > > > > > > that
> > > simulation
> > > > > > > stops
> > > > > changing
> > > > > hope …).
> > > > > > I
> > > > > > > send
> > > > > > everyone
> > > > > > > of
> > > > > > > > > bye bye
> > > > > > > > > Pierre
Hi Pierre
I have seen the video and have a question about the GH head shape. I do not
understand why the GH head changes its shape while the analysis is running,
initially it has a long narrow shape and in the end it looks more compressed
in shape. Could it be graphic related and just something seen on this video?
In AnyBody such a change in the shape is not possible while the model is
running, there would have to be several segments to replicate this.
I understand your point of not replicating the same optimization in AnyBody
and Matlab, but if you plan to impose the results found in matlab on the
AnyBody model it will be important that the models gives the same results.
Please write again if you have further questions, I was a bit unsure if the
last part of your posting was a question.
Sent: 19 March 2008 19:22
Hi Soren,
insertion point.
Pierre
> Hi Pierre
until
possible
you will
artificial
motion so
> always be obtained.
maybe this
minimize the
active. So
head to
> another position.
> helpful.
following
> questions
> these differences?
> Etc…
> Best regards
> _____
On Behalf
> Hi Soren,
> your idea about it.
> Thank you again.
> Pierre
> > Hi Pierre
> will be
> direction.
> model
> will lead
> issue
> zero.
control this
> > Best regards
> > Søren
> > _____
> On Behalf
> > Hi again Sylvain,
> > Thank you again.
> > Pierre-Olivier
ps.com,
> > > Hi,
can
> > > head.
> > > Best regards.
> ps.com,
> > > <pothekid@> wrote:
> > > > Hi Sylvain,
> > > not
> > > term
> > > the
> > > at
> > > not
> > > > useful for me.
> > > case,
> > > > Pierre-Olivier
> ps.com,
> > > wrote:
> > > > > Hi Pierre,
> > > node
> > > where
> > > you
> > > Base
> > > follow
P12 to
> > > a
the
> > > that
> > > this
> > > forces
> > > forces.
able
> > > to
> > > shape.
> > > segments
> > > what
> > > > > you need.
talk
> > > friction
> > > > > http://www.anybodyt
> > > muscles?
> > > > > together.
> > > have
the
> > > public, I
> > > you
> > > > > Best Regards
> > > > > <pothekid@> wrote:
> > > > > > Hi Sylvain,
> > > that
> > > > > appears.
mixed
> > > up
> > > force is
> > > arrows
“ContactRotPush”
> > > > > would
> > > > > > perform better ?
> > > still
> > > to
> > > head
> > > experimental
> > > > > set-
when
> > > I
> > > > > use
> > > origin
> > > the
> > > changing
> > > > > P8
first
> > > set
> > > help
> > > > > > me a lot.
> > > > > > Pierre.
> > > > > > wrote:
> > > > > > > Hi Pierre-Olivier
> > > > > contact
> > > enough
> > > have a
> > > > > > high
> > > contact
> > > > > > points
> > > strength at
> > > > > because
> > > > > create
> > > point.
> > > > > > This
> > > take
> > > > > > care
> > > > > actually
> > > the
> > > > > > > contact point.
> > > with
> > > > > the
> > > is
> > > > > now
> > > point
> > > > > > you
> > > carry
> > > > > > the
depends on
> > > the
> > > the
as I
> > > > > > recall
JointAndDriver.any
> > > > > file.
> > > > > > > Best regards,
> > > > > > > <pothekid@> wrote:
> > > > > > > > Hi Soeren,
> > > works
> > > > > > now
> > > > > > > for
> > > most,
> > > > > so
> > > > > > > I’ve
John
> > > > > gave
> > > > > > me
> > > > > > > a
> > > > > pushing
> > > > > > > difficulties
> > > > > radius
> > > this
> > > > > is
> > > > > > > > possible ?
> > > > > bottom
> > > > > > of
> > > > > > > my
> > > will
> > > > > > send
> > > > > > > you
> > > it.
> > > > > > > > Thank you again,
> > > > > > > > Pierre-Olivier
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > Hi Pierre
> > > that
> > > > > > the
> > > > > > > > analysis
> > > is
> > > > > as
> > > > > > you
> > > > > > > > expect.
> > > the
> > > > > > > > abduction angle
> > > correctly
> > > > > > > > because then
> > > (nStep
> > > > > > > > values) and
> > > still
> > > > > > look
> > > > > > > at
> > > > > > > > these
> > > contain “garbage”
> > > > > > > numbers.
> > > function
> > > > > in
> > > > > > > the
> > > just
> > > > > > > return
> > > > > > > > the last
> > > guess.
> > > > > output
> > > > > > > > function in
> > > > > > reported
> > > > > > > ok
> > > > > > > > but if
> > > work
> > > > > I
> > > > > > > believe
> > > > > because
> > > > > > it
> > > > > > > > fails in
> > > > > because
> > > > > > the
> > > > > > > > kinematics
> > > > > > > > > has been solved ok.
max
> > > of
> > > > > > > values
> > > > > > > > which are
> > > think
> > > > > you
> > > > > > > should
> > > and
> > > > > then
> > > > > > > > process them
> > > > > > > > > externally.
> > > > > > > > > Best regards
> > > > > > > > > _____
> > ps.com
> > ps.com]
> > > > > > > > On Behalf
> > ps.com
> > > > > > > > > Hi guys,
> > > of
> > > the
> > > > > > > model,
> > > of
> > > > > the
> > > > > > > humeral
So, my
> > > > > model
> > > > > > > allows
> > > contact
> > > > > of
> > > > > > > the
allowed
> > > by
> > > > > a
> > > > > > > driver
properties of
> > > the
> > > > > > > elliptic
> > > a
> > > > > > bone,
> > > > > > > it
> > > allowed)
> > > > > > (It
> > > > > > > was
> > > > > > reaction
> > > > > > > of
> > > it. So
> > > > > > > now, the
> > > that,
> > > > > the
> > > > > > > geometry
> > > stops.
> > > > > > It
> > > > > > > is
> > > > > geometry
> > > > > > is
> > > > > > > > > efficient or not.
> > > simulation.
> > > > > I
> > > > > > > look on
> > > > > (kinematic
> > > > > think
> > > > > > > that
> > > simulation
> > > > > > > stops
> > > > > changing
> > > > > hope …).
> > > > > > I
> > > > > > > send
> > > > > > everyone
> > > > > > > of
> > > > > > > > > bye bye
> > > > > > > > > Pierre
Hi Soren,
there is no change of geometry during abduction. It’s surely
just a codec differences or the video encryption method in Matlab. The
geometry changes only during the parameters study.
My question was more about how Anybody do the calculations. Does it
make a static calculation or a dynamic one ? I mean, does the program
compute the minimal force to have equilibrium or a more complex
calculation ?
I ask this question because I have to understand how the program works
in order to be able to explain it in my paper.
Maybe you can refer me to an article in the Documentation repository
of Anybody that explain how AnyBody perfom the muscle calculation. I
know about the muscle recruitment, but not about the force itself.
I hope that is more clear for you.
Thank you again
Pierre
> Hi Pierre
I do not
running,
compressed
this video?
AnyBody
results.
if the
> Best regards
> _____
On Behalf
> Hi Soren,
> insertion point.
> Pierre
> > Hi Pierre
minimum
> until
> possible
> you will
> artificial
> motion so
> > always be obtained.
> maybe this
> minimize the
> active. So
> head to
> > another position.
> > helpful.
> following
> > questions
justify
> > these differences?
> > Etc…
> > Best regards
> > _____
> On Behalf
> > Hi Soren,
> > your idea about it.
> > Thank you again.
> > Pierre
ps.com,
> > > Hi Pierre
This
> > will be
so the
> > direction.
> > model
> > will lead
> > issue
can not
muscles
> > zero.
> control this
> > > Best regards
> > > Søren
> > > _____
ps.com
ps.com]
> > On Behalf
> > > Hi again Sylvain,
able to
I got
permanent
should
it is
when I
> > > Thank you again.
> > > Pierre-Olivier
> ps.com,
> > > > Hi,
not
> can
humerus
> > > > head.
joint you
switch on
load of
able to
> > > > Best regards.
> > ps.com,
> > > > <pothekid@> wrote:
> > > > > Hi Sylvain,
> > > > not
head in
> > > > term
in the
values,
> > > > the
downward
> > > > at
head is
> > > > not
is very
> > > > > useful for me.
> > > > case,
> > > > > Pierre-Olivier
> > ps.com,
> > > > wrote:
> > > > > > Hi Pierre,
> > > > node
node
> > > > where
object
> > > > you
the
> > > > Base
> > > > follow
> P12 to
> > > > a
> the
mass)
> > > > that
> > > > this
> > > > forces
> > > > forces.
ellipsoid
> able
> > > > to
the
> > > > shape.
> > > > segments
> > > > what
> > > > > > you need.
> talk
in the
> > > > friction
force;
> > > > > > http://www.anybodyt
> > > > muscles?
> > > > > > together.
Because by
will
> > > > have
contact
> the
> > > > public, I
> > > > you
> > > > > > Best Regards
> > > > > > <pothekid@> wrote:
> > > > > > > Hi Sylvain,
found
> > > > that
> > > > > > appears.
> mixed
> > > > up
> > > > force is
> > > > arrows
> “ContactRotPush”
> > > > > > would
> > > > > > > perform better ?
but I
> > > > still
force
abduction
> > > > to
the
humeral
> > > > head
> > > > experimental
> > > > > > set-
> when
> > > > I
> > > > > > use
> > > > origin
> > > > the
> > > > changing
> > > > > > P8
> first
> > > > set
would
> > > > help
> > > > > > > me a lot.
> > > > > > > Pierre.
> > > > > > > wrote:
> > > > > > > > Hi Pierre-Olivier
> > > > > > contact
> > > > enough
> > > > have a
> > > > > > > high
> > > > contact
> > > > > > > points
> > > > strength at
model
> > > > > > because
ability to
> > > > > > create
> > > > point.
> > > > > > > This
have to
> > > > take
> > > > > > > care
> > > > > > actually
> > > > the
> > > > > > > > contact point.
> > > > with
> > > > > > the
model
> > > > is
> > > > > > now
> > > > point
> > > > > > > you
cannot
> > > > carry
> > > > > > > the
> depends on
> > > > the
> > > > the
> as I
> > > > > > > recall
> JointAndDriver.any
> > > > > > file.
> > > > > > > > Best regards,
> > > > > > > > <pothekid@> wrote:
> > > > > > > > > Hi Soeren,
> > > > works
> > > > > > > now
> > > > > > > > for
> > > > most,
> > > > > > so
> > > > > > > > I’ve
> John
> > > > > > gave
> > > > > > > me
> > > > > > > > a
scripts is
create a
> > > > > > pushing
> > > > > > > > difficulties
constant
> > > > > > radius
think
> > > > this
> > > > > > is
> > > > > > > > > possible ?
the
> > > > > > bottom
> > > > > > > of
> > > > > > > > my
> > > > will
> > > > > > > send
> > > > > > > > you
written
> > > > it.
> > > > > > > > > Thank you again,
> > > > > > > > > Pierre-Olivier
> > > > <support@>
> > > > > > > > wrote:
> > > > > > > > > > Hi Pierre
solution is
> > > > that
> > > > > > > the
> > > > > > > > > analysis
this
> > > > is
> > > > > > as
> > > > > > > you
> > > > > > > > > expect.
value of
> > > > the
> > > > > > > > > abduction angle
> > > > correctly
> > > > > > > > > because then
function
> > > > (nStep
> > > > > > > > > values) and
> > > > still
> > > > > > > look
> > > > > > > > at
> > > > > > > > > these
> > > > contain “garbage”
> > > > > > > > numbers.
> > > > function
> > > > > > in
> > > > > > > > the
will
> > > > just
> > > > > > > > return
> > > > > > > > > the last
> > > > guess.
other
> > > > > > output
> > > > > > > > > function in
angle is
> > > > > > > reported
> > > > > > > > ok
> > > > > > > > > but if
would not
> > > > work
> > > > > > I
> > > > > > > > believe
> > > > > > because
> > > > > > > it
> > > > > > > > > fails in
> > > > > > because
> > > > > > > the
> > > > > > > > > kinematics
> > > > > > > > > > has been solved ok.
> max
> > > > of
> > > > > > > > values
> > > > > > > > > which are
> > > > think
> > > > > > you
> > > > > > > > should
> > > > and
> > > > > > then
> > > > > > > > > process them
> > > > > > > > > > externally.
> > > > > > > > > > Best regards
> > > > > > > > > > _____
> > > ps.com
> > > ps.com]
> > > > > > > > > On Behalf
> > > ps.com
> > > > > > > > > > Hi guys,
part
> > > > of
revisions of
> > > > the
> > > > > > > > model,
migration
> > > > of
> > > > > > the
> > > > > > > > humeral
> So, my
> > > > > > model
> > > > > > > > allows
> > > > contact
> > > > > > of
> > > > > > > > the
> allowed
> > > > by
> > > > > > a
> > > > > > > > driver
> properties of
> > > > the
> > > > > > > > elliptic
prosthesis and
> > > > a
> > > > > > > bone,
> > > > > > > > it
> > > > allowed)
> > > > > > > (It
> > > > > > > > was
off the
> > > > > > > reaction
> > > > > > > > of
> > > > it. So
> > > > > > > > now, the
> > > > that,
> > > > > > the
> > > > > > > > geometry
> > > > stops.
> > > > > > > It
> > > > > > > > is
> > > > > > geometry
> > > > > > > is
> > > > > > > > > > efficient or not.
> > > > simulation.
> > > > > > I
> > > > > > > > look on
> > > > > > (kinematic
and I
> > > > > > think
> > > > > > > > that
> > > > simulation
> > > > > > > > stops
error by
> > > > > > changing
> > > > > > hope …).
> > > > > > > I
> > > > > > > > send
hello to
> > > > > > > everyone
> > > > > > > > of
> > > > > > > > > > bye bye
> > > > > > > > > > Pierre
Hi Pierre,
There is a good explanation of how AnyBody perform the muscle
calculation in this tutorial:
http://www.anybodytech.com/691.0.html
Hope you will find there what you want.
Sylvain, AnyBody Support.
<pothekid@…> wrote:
> Hi Soren,
The
program
> calculation ?
works
> Thank you again
> Pierre
wrote:
> > Hi Pierre
shape.
> I do not
> running,
> compressed
> this video?
model is
this.
in
> AnyBody
on the
> results.
unsure
> if the
> > Best regards
> > _____
> On Behalf
> > Hi Soren,
arm
and Y
prosthesis
is
the
and
> > insertion point.
Anybody, but
do
constant
are
no
something
results.jpg).
> > Pierre
ps.com,
> > > Hi Pierre
> minimum
humeral
> > until
should be
> > possible
Basically
> > you will
> > artificial
> > motion so
balance can
> > > always be obtained.
> > maybe this
> > minimize the
become
> > active. So
humeral
> > head to
> > > another position.
might be
> > > helpful.
the
> > following
> > > questions
> justify
> > > these differences?
> > > Etc…
> > > Best regards
> > > _____
ps.com
ps.com]
> > On Behalf
ps.com
> > > Hi Soren,
that find
model.
(constant
degree of
for each
muscle
Anybody from
under
me
> > > your idea about it.
> > > Thank you again.
> > > Pierre
> ps.com,
> > > > Hi Pierre
segment.
> This
model
> > > will be
force,
> so the
one
> > > direction.
in the
> > > model
force, it
> > > will lead
balance
> > > issue
> can not
> muscles
be non
> > > zero.
> > control this
> > > > Best regards
> > > > Søren
> > > > _____
> ps.com
> ps.com]
> > > On Behalf
ps.com
> > > > Hi again Sylvain,
> able to
ellipse,
> I got
> permanent
I
> should
prior to
head,
> it is
> when I
tStart
complete
> > > > Thank you again.
> > > > Pierre-Olivier
40yahoogroups.com>
> > ps.com,
> > > > > Hi,
is
> not
that the
and it
> > can
> humerus
> > > > > head.
> joint you
> switch on
> load of
> able to
> > > > > Best regards.
40yahoogroups.com>
> > > ps.com,
> > > > > <pothekid@> wrote:
> > > > > > Hi Sylvain,
> > > > > not
forces.
> head in
> > > > > term
> in the
> values,
> > > > > the
> downward
> > > > > at
> head is
> > > > > not
> is very
> > > > > > useful for me.
adding some
is the
> > > > > case,
> > > > > > Pierre-Olivier
40yahoogroups.com>
> > > ps.com,
> > > > > wrote:
> > > > > > > Hi Pierre,
define the
> > > > > node
the
> node
> > > > > where
> object
> > > > > you
the
in
> the
> > > > > Base
arrows
> > > > > follow
from
> > P12 to
> > > > > a
where
> > the
> mass)
> > > > > that
with the
point of
> > > > > this
reaction
> > > > > forces
the
> > > > > forces.
> ellipsoid
should be
> > able
> > > > > to
of
> the
> > > > > shape.
two
> > > > > segments
not be
> > > > > what
> > > > > > > you need.
you
> > talk
> in the
the
> > > > > friction
> force;
> > > > > > > http://www.anybodyt
friction
> > > > > muscles?
working
> > > > > > > together.
change the
> Because by
it
> will
> > > > > have
> contact
changing
> > the
value.
not
> > > > > public, I
6, here
> > > > > you
> > > > > > > Best Regards
> > > > > > > <pothekid@> wrote:
> > > > > > > > Hi Sylvain,
I’ve
> found
> > > > > that
friction
> > > > > > > appears.
switch
> > mixed
> > > > > up
friction
> > > > > force is
the
> > > > > arrows
> > “ContactRotPush”
> > > > > > > would
> > > > > > > > perform better ?
> but I
> > > > > still
are the
objects.
pushing
> force
> abduction
> > > > > to
ellipse.
performing
> the
> humeral
> > > > > head
> > > > > experimental
> > > > > > > set-
exemple,
> > when
> > > > > I
> > > > > > > use
deltoid
> > > > > origin
script,
> > > > > the
but
> > > > > changing
> > > > > > > P8
the
> > first
> > > > > set
it
> would
> > > > > help
> > > > > > > > me a lot.
> > > > > > > > Pierre.
> > > > > > > > wrote:
> > > > > > > > > Hi Pierre-Olivier
file
conditional
> > > > > > > contact
close
> > > > > enough
will
> > > > > have a
> > > > > > > > high
two
> > > > > contact
> > > > > > > > points
no
> > > > > strength at
> model
> > > > > > > because
> ability to
> > > > > > > create
contact
> > > > > point.
> > > > > > > > This
> have to
> > > > > take
> > > > > > > > care
point. You
> > > > > > > actually
instead of
> > > > > the
> > > > > > > > > contact point.
working
> > > > > with
> > > > > > > the
the
> model
> > > > > is
> > > > > > > now
see that
> > > > > point
> > > > > > > > you
> cannot
> > > > > carry
> > > > > > > > the
> > depends on
> > > > > the
available in
> > > > > the
> > > > > > > > > repository
> > as I
> > > > > > > > recall
> > JointAndDriver.any
> > > > > > > file.
> > > > > > > > > Best regards,
> > > > > > > > > <pothekid@> wrote:
> > > > > > > > > > Hi Soeren,
> > > > > works
> > > > > > > > now
> > > > > > > > > for
want
> > > > > most,
> > > > > > > so
> > > > > > > > > I’ve
Aalborg,
> > John
> > > > > > > gave
> > > > > > > > me
> > > > > > > > > a
> scripts is
> create a
> > > > > > > pushing
have some
> > > > > > > > > difficulties
> constant
> > > > > > > radius
you
> think
> > > > > this
> > > > > > > is
> > > > > > > > > > possible ?
in
> the
> > > > > > > bottom
> > > > > > > > of
> > > > > > > > > my
> > > > > will
> > > > > > > > send
> > > > > > > > > you
> written
> > > > > it.
> > > > > > > > > > Thank you again,
> > > > > > > > > > Pierre-Olivier
> > > > > <support@>
> > > > > > > > > wrote:
> > > > > > > > > > > Hi Pierre
problem….
> solution is
> > > > > that
> > > > > > > > the
> > > > > > > > > > analysis
analysis,
> this
> > > > > is
> > > > > > > as
> > > > > > > > you
> > > > > > > > > > expect.
> value of
> > > > > the
> > > > > > > > > > abduction angle
finished
> > > > > correctly
> > > > > > > > > > because then
> function
> > > > > (nStep
> > > > > > > > > > values) and
it will
> > > > > still
> > > > > > > > look
> > > > > > > > > at
> > > > > > > > > > these
> > > > > contain “garbage”
> > > > > > > > > numbers.
output
> > > > > function
> > > > > > > in
> > > > > > > > > the
it
> will
> > > > > just
> > > > > > > > > return
> > > > > > > > > > the last
case I
> > > > > guess.
your
> other
> > > > > > > output
> > > > > > > > > > function in
> angle is
> > > > > > > > reported
> > > > > > > > > ok
> > > > > > > > > > but if
> would not
> > > > > work
> > > > > > > I
> > > > > > > > > believe
last step
> > > > > > > because
> > > > > > > > it
> > > > > > > > > > fails in
angle
> > > > > > > because
> > > > > > > > the
> > > > > > > > > > kinematics
> > > > > > > > > > > has been solved ok.
take the
> > max
> > > > > of
> > > > > > > > > values
> > > > > > > > > > which are
So I
> > > > > think
> > > > > > > you
> > > > > > > > > should
output file
> > > > > and
> > > > > > > then
> > > > > > > > > > process them
> > > > > > > > > > > externally.
> > > > > > > > > > > Best regards
> > > > > > > > > > > _____
> > > > ps.com
> > > > ps.com]
> > > > > > > > > > On Behalf
> > > > ps.com
> > > > > > > > > > > Hi guys,
first
> part
> > > > > of
> revisions of
> > > > > the
> > > > > > > > > model,
> migration
> > > > > of
> > > > > > > the
> > > > > > > > > humeral
tear.
> > So, my
> > > > > > > model
> > > > > > > > > allows
permanent
> > > > > contact
> > > > > > > of
> > > > > > > > > the
> > allowed
> > > > > by
> > > > > > > a
> > > > > > > > > driver
> > properties of
> > > > > the
> > > > > > > > > elliptic
> prosthesis and
> > > > > a
> > > > > > > > bone,
> > > > > > > > > it
force is
> > > > > allowed)
> > > > > > > > (It
> > > > > > > > > was
> off the
> > > > > > > > reaction
> > > > > > > > > of
muscle on
> > > > > it. So
> > > > > > > > > now, the
after
> > > > > that,
> > > > > > > the
> > > > > > > > > geometry
simulation
> > > > > stops.
> > > > > > > > It
> > > > > > > > > is
if the
> > > > > > > geometry
> > > > > > > > is
> > > > > > > > > > > efficient or not.
parametric
> > > > > simulation.
> > > > > > > I
> > > > > > > > > look on
simulation
> > > > > > > (kinematic
strange
> and I
> > > > > > > think
> > > > > > > > > that
the
> > > > > simulation
> > > > > > > > > stops
> error by
> > > > > > > changing
do (I
> > > > > > > hope …).
> > > > > > > > I
> > > > > > > > > send
> hello to
> > > > > > > > everyone
> > > > > > > > > of
> > > > > > > > > > > bye bye
> > > > > > > > > > > Pierre
removed]
Hi Sylvain,
I’ve found what I was searching for in the Nikravesh
textbook (Planar multibody dynamics) that you have put the reference
under FAQs in the publications section.
This book explain how to apply joint coordinate method works and also
the kinematic equations. It also explain how to apply the forward and
inverse dynamic.
Do you think that is feasible to create a 2D model in Matlab that work
in forward dynamic ? Do you work on that for further version ?
My idea is to find a movement for the shoulder that rely upon the
deltoid activity, knowing that this muscle is the only one that makes
the movement in case of a massive rotator cuff tear.
Thank you for you support
Pierre
> Hi Pierre,
> Best regards,
> <pothekid@> wrote:
> > Hi Soren,
> The
> program
> > calculation ?
> works
> > Thank you again
> > Pierre
> wrote:
> > > Hi Pierre
> shape.
> > I do not
> > running,
> > compressed
> > this video?
> model is
> this.
> in
> > AnyBody
> on the
> > results.
> unsure
> > if the
> > > Best regards
> > > _____
> > On Behalf
> > > Hi Soren,
> arm
> and Y
> prosthesis
> is
> the
> and
> > > insertion point.
> Anybody, but
> do
> constant
> are
> no
> something
> results.jpg).
> > > Pierre
> ps.com,
> > > > Hi Pierre
> > minimum
> humeral
> > > until
> should be
> > > possible
> Basically
> > > you will
> > > artificial
> > > motion so
> balance can
> > > > always be obtained.
> > > maybe this
> > > minimize the
> become
> > > active. So
> humeral
> > > head to
> > > > another position.
> might be
> > > > helpful.
> the
> > > following
> > > > questions
> > justify
> > > > these differences?
> > > > Etc…
> > > > Best regards
> > > > _____
> ps.com
> ps.com]
> > > On Behalf
> ps.com
> > > > Hi Soren,
> that find
> model.
> (constant
> degree of
> for each
> muscle
> Anybody from
> under
> me
> > > > your idea about it.
> > > > Thank you again.
> > > > Pierre
> > ps.com,
> > > > > Hi Pierre
> segment.
> > This
> model
> > > > will be
> force,
> > so the
> one
> > > > direction.
> in the
> > > > model
> force, it
> > > > will lead
> balance
> > > > issue
> > can not
> > muscles
> be non
> > > > zero.
> > > control this
> > > > > Best regards
> > > > > Søren
> > > > > _____
> > ps.com
> > ps.com]
> > > > On Behalf
> ps.com
> > > > > Hi again Sylvain,
> > able to
> ellipse,
> > I got
> > permanent
> I
> > should
> prior to
> head,
> > it is
> > when I
> tStart
> complete
> > > > > Thank you again.
> > > > > Pierre-Olivier
> 40yahoogroups.com>
> > > ps.com,
> > > > > > Hi,
> is
> > not
> that the
> and it
> > > can
> > humerus
> > > > > > head.
> > joint you
> > switch on
> > load of
> > able to
> > > > > > Best regards.
> 40yahoogroups.com>
> > > > ps.com,
> > > > > > <pothekid@> wrote:
> > > > > > > Hi Sylvain,
> > > > > > not
> forces.
> > head in
> > > > > > term
> > in the
> > values,
> > > > > > the
> > downward
> > > > > > at
> > head is
> > > > > > not
> > is very
> > > > > > > useful for me.
> adding some
> is the
> > > > > > case,
> > > > > > > Pierre-Olivier
> 40yahoogroups.com>
> > > > ps.com,
> > > > > > wrote:
> > > > > > > > Hi Pierre,
> define the
> > > > > > node
> the
> > node
> > > > > > where
> > object
> > > > > > you
> the
> in
> > the
> > > > > > Base
> arrows
> > > > > > follow
> from
> > > P12 to
> > > > > > a
> where
> > > the
> > mass)
> > > > > > that
> with the
> point of
> > > > > > this
> reaction
> > > > > > forces
> the
> > > > > > forces.
> > ellipsoid
> should be
> > > able
> > > > > > to
> of
> > the
> > > > > > shape.
> two
> > > > > > segments
> not be
> > > > > > what
> > > > > > > > you need.
> you
> > > talk
> > in the
> the
> > > > > > friction
> > force;
> > > > > > > > http://www.anybodyt
> friction
> > > > > > muscles?
> working
> > > > > > > > together.
> change the
> > Because by
> it
> > will
> > > > > > have
> > contact
> changing
> > > the
> value.
> not
> > > > > > public, I
> 6, here
> > > > > > you
> > > > > > > > Best Regards
> > > > > > > > <pothekid@> wrote:
> > > > > > > > > Hi Sylvain,
> I’ve
> > found
> > > > > > that
> friction
> > > > > > > > appears.
> switch
> > > mixed
> > > > > > up
> friction
> > > > > > force is
> the
> > > > > > arrows
> > > “ContactRotPush”
> > > > > > > > would
> > > > > > > > > perform better ?
> > but I
> > > > > > still
> are the
> objects.
> pushing
> > force
> > abduction
> > > > > > to
> ellipse.
> performing
> > the
> > humeral
> > > > > > head
> > > > > > experimental
> > > > > > > > set-
> exemple,
> > > when
> > > > > > I
> > > > > > > > use
> deltoid
> > > > > > origin
> script,
> > > > > > the
> but
> > > > > > changing
> > > > > > > > P8
> the
> > > first
> > > > > > set
> it
> > would
> > > > > > help
> > > > > > > > > me a lot.
> > > > > > > > > Pierre.
> > > > > > > > > wrote:
> > > > > > > > > > Hi Pierre-Olivier
> file
> conditional
> > > > > > > > contact
> close
> > > > > > enough
> will
> > > > > > have a
> > > > > > > > > high
> two
> > > > > > contact
> > > > > > > > > points
> no
> > > > > > strength at
> > model
> > > > > > > > because
> > ability to
> > > > > > > > create
> contact
> > > > > > point.
> > > > > > > > > This
> > have to
> > > > > > take
> > > > > > > > > care
> point. You
> > > > > > > > actually
> instead of
> > > > > > the
> > > > > > > > > > contact point.
> working
> > > > > > with
> > > > > > > > the
> the
> > model
> > > > > > is
> > > > > > > > now
> see that
> > > > > > point
> > > > > > > > > you
> > cannot
> > > > > > carry
> > > > > > > > > the
> > > depends on
> > > > > > the
> available in
> > > > > > the
> > > > > > > > > > repository
> > > as I
> > > > > > > > > recall
> > > JointAndDriver.any
> > > > > > > > file.
> > > > > > > > > > Best regards,
> > > > > > > > > > <pothekid@> wrote:
> > > > > > > > > > > Hi Soeren,
> > > > > > works
> > > > > > > > > now
> > > > > > > > > > for
> want
> > > > > > most,
> > > > > > > > so
> > > > > > > > > > I’ve
> Aalborg,
> > > John
> > > > > > > > gave
> > > > > > > > > me
> > > > > > > > > > a
> > scripts is
> > create a
> > > > > > > > pushing
> have some
> > > > > > > > > > difficulties
> > constant
> > > > > > > > radius
> you
> > think
> > > > > > this
> > > > > > > > is
> > > > > > > > > > > possible ?
> in
> > the
> > > > > > > > bottom
> > > > > > > > > of
> > > > > > > > > > my
> > > > > > will
> > > > > > > > > send
> > > > > > > > > > you
> > written
> > > > > > it.
> > > > > > > > > > > Thank you again,
> > > > > > > > > > > Pierre-Olivier
> > > > > > <support@>
> > > > > > > > > > wrote:
> > > > > > > > > > > > Hi Pierre
> problem….
> > solution is
> > > > > > that
> > > > > > > > > the
> > > > > > > > > > > analysis
> analysis,
> > this
> > > > > > is
> > > > > > > > as
> > > > > > > > > you
> > > > > > > > > > > expect.
> > value of
> > > > > > the
> > > > > > > > > > > abduction angle
> finished
> > > > > > correctly
> > > > > > > > > > > because then
> > function
> > > > > > (nStep
> > > > > > > > > > > values) and
> it will
> > > > > > still
> > > > > > > > > look
> > > > > > > > > > at
> > > > > > > > > > > these
> > > > > > contain “garbage”
> > > > > > > > > > numbers.
> output
> > > > > > function
> > > > > > > > in
> > > > > > > > > > the
> it
> > will
> > > > > > just
> > > > > > > > > > return
> > > > > > > > > > > the last
> case I
> > > > > > guess.
> your
> > other
> > > > > > > > output
> > > > > > > > > > > function in
> > angle is
> > > > > > > > > reported
> > > > > > > > > > ok
> > > > > > > > > > > but if
> > would not
> > > > > > work
> > > > > > > > I
> > > > > > > > > > believe
> last step
> > > > > > > > because
> > > > > > > > > it
> > > > > > > > > > > fails in
> angle
> > > > > > > > because
> > > > > > > > > the
> > > > > > > > > > > kinematics
> > > > > > > > > > > > has been solved ok.
> take the
> > > max
> > > > > > of
> > > > > > > > > > values
> > > > > > > > > > > which are
> So I
> > > > > > think
> > > > > > > > you
> > > > > > > > > > should
> output file
> > > > > > and
> > > > > > > > then
> > > > > > > > > > > process them
> > > > > > > > > > > > externally.
> > > > > > > > > > > > Best regards
> > > > > > > > > > > > _____
> > > > > ps.com
> > > > > ps.com]
> > > > > > > > > > > On Behalf
> > > > > ps.com
> > > > > > > > > > > > Hi guys,
> first
> > part
> > > > > > of
> > revisions of
> > > > > > the
> > > > > > > > > > model,
> > migration
> > > > > > of
> > > > > > > > the
> > > > > > > > > > humeral
> tear.
> > > So, my
> > > > > > > > model
> > > > > > > > > > allows
> permanent
> > > > > > contact
> > > > > > > > of
> > > > > > > > > > the
> > > allowed
> > > > > > by
> > > > > > > > a
> > > > > > > > > > driver
> > > properties of
> > > > > > the
> > > > > > > > > > elliptic
> > prosthesis and
> > > > > > a
> > > > > > > > > bone,
> > > > > > > > > > it
> force is
> > > > > > allowed)
> > > > > > > > > (It
> > > > > > > > > > was
> > off the
> > > > > > > > > reaction
> > > > > > > > > > of
> muscle on
> > > > > > it. So
> > > > > > > > > > now, the
> after
> > > > > > that,
> > > > > > > > the
> > > > > > > > > > geometry
> simulation
> > > > > > stops.
> > > > > > > > > It
> > > > > > > > > > is
> if the
> > > > > > > > geometry
> > > > > > > > > is
> > > > > > > > > > > > efficient or not.
> parametric
> > > > > > simulation.
> > > > > > > > I
> > > > > > > > > > look on
> simulation
> > > > > > > > (kinematic
> strange
> > and I
> > > > > > > > think
> > > > > > > > > > that
> the
> > > > > > simulation
> > > > > > > > > > stops
> > error by
> > > > > > > > changing
> do (I
> > > > > > > > hope …).
> > > > > > > > > I
> > > > > > > > > > send
> > hello to
> > > > > > > > > everyone
> > > > > > > > > > of
> > > > > > > > > > > > bye bye
> > > > > > > > > > > > Pierre
> removed]
