just a small question to confirm whether i am correct:
The joint reaction force is the force from the second joint node acting on the first.
Correct?
I am always confused by the term “joint REaction” force.
Thanks, Thomaz
Correct?
Thanks, Thomaz
Hi Thomaz,
All forces and moments are acting on the second mentioned coordinate system and measured wrt to the first mentioned coordinate system in the measure.
thanks, Moonki
