Hi Sarah
> I have continued looking into my simple arm model and I have a
couple
> more questions.
> 1.) First off, from my analysis, it looks like there is no
> optimization going on within AnyBody. For example, when there are
5
> muscles in the problem (brachialis, brachioradialis, biceps long
and
> short, and deltoid), after the inverse dynamics analysis, 3 of the
> muscles have equal force values, and the other two have equal force
> values. So five muscles is essentially represented as two; is
this so
> that equal muscle forces reduce the number of unknowns in the
system
> of equations?
It would be typical for the solution of such a problem that some of
the muscles would end up with the same muscle activation. This is
due to the fact that the optimization algorithm at any time step
tries to minimized the muscles activity of the highest activated
muscle. This means that typically many muscles will be on the
activity envelope. If the muscles also ends up having the same force
value it could be beacuse they have the same moment arm and
strength ?
> For example in my model, the brachialis, brachioradialis, and
biceps
> short all have the same muscle force values (120 N), and the
deltoid
> and biceps long have the same muscle force (305 N). So instead of
5
> unknowns for each the upper and lower limbs, there are 2 unknowns.
The system do not couple the muscles together and reduce the numbers
of unknowns in this way. It will solve the problem with five
independent muscles. I think it is due to the mechanics of this
problem that you end up with this solution, but i will need to have
a closer look at the model in order to verify this.
> This reduces the number of unknowns to solve the equilibrium
equations
> quite easily. Mathematically, how is optimization utilized in this
> case?
> 2.) Also, in my model looking at the brachialis and
brachioradialis,
> for example, how can they both be exerting the same force in an
> optimal setting? Just looking at the moment free body diagram, the
> brachioradialis has a longer moment arm so one would think that the
> force in it would be greater than in the brachialis which has a
> smaller moment arm.
The optimization algorithm tries to minimize the muscle activity so
it will also depend on the strength relation between these two
muscles. If the brachioradialis muscle has a much lower strength
than brachialis you could end up with the solution you describe,
since it will try to use the brachialis muscle for unloading the
brachioradialis muscle.
> 3.) Lastly, if I am getting maximum muscle forces greater than my
F0
> input of 300 (deltoid and biceps long = 305), I can change the
epsilon
> values to result in more physiologically realizable results, right?
There is nothing in the algorithm that prevents the muscles from
being overloaded. In your case i am sure that the muscle activity is
larger than one meaning that muscle holds a larger load than its
strength. I am not sure what you mean by epsilon values, i think
that it could be moment arm values, strength values or mass
properties of the segments which could be wrong.
I hope this answered your questions otherwise please write again.
AnyBody Support
> Thanks again for your help.
> Sarah
