I would like to generate an output file much like the one from the standinglift FEA main file in the tutorial to study. How do I do this with the standing human template? Is there a way of deleting the aquarium and using the standing lift model instead? I have tried this and get lots of error messages.
I just want to alter the joint angles and generate an output file of the forces on the L4,L5.
I did as you suggested (copied the relevant blocks of code) and was able to load the model. However, when I try to run the Inverse dynamic analysis I get an error in the study folder:
ERROR(OBJ.MCH.KIN2) : C:/U…s/w…g/D…s/A…y/F…l/s…n/standing human.main.any(40) : Study : Model is kinematically over-constrained : Position analysis failed : 8 unsolvable constraint(s) found
I did 2 (added code). I copied the output generating code from the standing lift FEA model onto the standing human Study folder. I have put the section of code at the end of the text. Just in case.
My aim is to generate an output file from the standing human model for use in FEA. I did not change the other folders.
Hi Victor,
Sorry for the slow reply,
I can not see why the code you have listed would cause a kinematic problem, in my view it must be something else which has been changed.
Please try to out-comment your added lines and verify that the model runs?
The file is self-explaining - it contains data optimized kinematics of the trunk (positions of pelvis in XYZ, rotations wrt global ref. frame, thoracopelvic flexion/lat. bending/rotation, and the neck flexion). See this description copied from the file below:
