Hi Sebastian
Here is initially a short description of the drivers of the standing
model, it is driven in the following way:
For both the right and left legs:
Toe tip vertically constrainet to ground
Heel vertically constrainet to ground
Ankle position driven in global x direction
Three rotations is driven in the hip (Means no dof left in hip)
One rotation is driven in the knee (Means no dof left in knee)
Ankle eversion is driven (Means flexion is still FREE in ankle)
This is in total 8 drivers for each leg…
COM driven sideways and for/back (X,Z)
Neck is driven
3 Rotations between Pelvis and Thorax + the spine rhythm
(this means all dof on spine is driven )
Arms are also fully driven…
Summing up the driver on the left leg add up up to 8 driven dofs, by
replacing them wiht the freePostureMove drivers will add 6 drivers
to the model, so you will have 2 less than before.
If you make a small sketch of the problem i think you will see that
this is the height of the left pelvis joint. Since the hip and knee
is driven, and the foot is driven to be flat on the floor this means
the leg provides the height of the hipjoint. Instead of the height
you could also drive the rotation of the pelvis around the global x
axis.
The other one is the position of the left hip joint in the x
direction, which was previously controlled via the x position of the
foot. You could also say that it is the rotation of the pelvis around
the global Z direction.
So to make the standing model work you need to apply these two
additional drivers.
Please do hesitate to ask again if you have further questions
— In anyscript@yahoogroups.com, “sebastian.kreissl”
<sebastian.kreissl@…> wrote:
> Hello everybody,
> I am trying to create a model that stands on one leg only. First
off, I
> just removed the lines, from the regular StandingModel where the
left
> leg is fixed to the ground, that (obviously) lead to a
kinematically
> indetermined system.
> Second try was to combine the FreePostureMove model with the
> StandingModel:
> 1. Use the StandingModel as a basis
> 2. Comment out the lines where left toe and heel are fixed to the
ground
> 3. Copy the lines from FreePostureMove where the left leg is
defined,
> to the StandingModel
> Thus I was hoping that I could create a correct model however it is
not
> compatible: the message window gives me error messages that some
> dimensions do not match. And contains too few kinematic constraints.
> Has anybody tried (maybe already succeeded) to create a model that
> Advices, suggestions would be highly appreciated
> Regards Sebastian
