StandingModel GlobalRef Origin: STL import problems
In the StandingModel, why is the Origin of the GlobalRef {0, 0.1, 0}?
I am loading a cube stl and using a reference node at {0,0,0} in the
GlobalRef folder. The reference node is placed correctly on the
displayed global reference frame, however when the stl is loaded at
{0, 0, 0}, it is 0.1 below the Origin. If the GlobalRef Origin is
changed to {0, 0, 0} everything lines up.
It seems that when loading an stl, AnyBody is always using an Origin
of {0,0,0} and not the value set in the GlobalRef folder.
Brent
Hi Brent,
Here by me it is working fine, I think. I think I may have
misunderstood exactly what you did.
I have tried something like this:
 // Global Reference Frame
   Origin = {0,0,1};
   //AnyDrawRefFrame drw = {};
   AnyRefNode node = {
     AnyDrawRefFrame drw = { RGB = {1,0,0}; };
     AnyDrawSurf drw_stl = {
       FileName = "crank.anysurf";
 };  // Global reference frame
This draws a red reference frame in the ‘node’ of ‘GlobalRef’, which
is placed in point (0,0,1) according to ‘Origin’ in ‘GlobalRef’.
The AnyDrawSurf is placed here too, I am sure.
Adding
AnyFixedRefFrame GlobalRef1 = {
you will get a yellow reference at the global origin (0,0,0) for
comparison.
If you still think thee is something fishy, could you please upload
the files with your example and I shall have a look.
Michael
AnyBody Support
— In anyscript@yahoogroups.com, “blulrey” <blulrey@…> wrote:
> Hello,
> Brent
Michael,
I attempted to put a ref node at the point I wanted to import a cube
(BoxPnt). The cube is 1 meter square, and AnyBody loads it at a
corner of the cube.
Origin ={0.0,0.1,0.0};
#include “drawcoorsystem.any”
   AnyRefNode BoxPnt = {
     sRel = {0.0, 0.0, 0.0};
     AnyDrawNode drw = {};
 };//GlobalRef
 AnySeg Box = {
   AnyVar Length = 0.3048; //meters
   AnyVar Width = 0.3048;
   AnyVar Height = 0.3048;
   Mass = 4.5359237; // kilograms
   Jii = {1, 1, 1}; // dummy values
   r0 = .GlobalRef.BoxPnt.sRel;
   AnyDrawSurf Cube = {
     FileName = "Cube"; //Cube.anysurf in Yahoo group files
     Transparency = 0.5;
     ScaleXYZ = {.Width,.Height,.Length};
The Cube is imported to {0,0,0} because that is the value of
.GlobalRef.BoxPnt.sRel I thought that it would load the Cube at the
actual location of .GlobalRef.BoxPnt.sRel, which in this case is
{0,0.1,0}. Perhaps I do not understand how the GlobalRef Origin
works. It makes sense that the definition of the GlobalRef Origin
would define the axes for all other points.
My other question was: Why is the GlobalRef origin for the
StandingModel at {0,0.1,0}? It seems that a global origin should be
at {0,0,0}.
Thank you,
Brent
> Hi Brent,
> Origin = {0,0,1};
> AnyRefNode node = {
> FileName = “crank.anysurf”;
> Adding
> comparison.
> Best regards,
> Michael
> AnyBody Support
> — In anyscript@yahoogroups.com, “blulrey” <blulrey@> wrote:
> > Hello,
> > Brent
Hi Brent
I am not sure if this is your problem, but when you import an *.stl
file to the global ref, it is the origin of the local coordinate
system of the *.stl file that is placed in the global coordinate
system. This means if the box is made with the corner in the origin,
then it will be imported as that.
I don’t know why the standing model has a global ref at (0,0.1,0).
Regards Christian
> Michael,
> corner of the cube.
> };//GlobalRef
> AnySeg Box = {
> FileName = “Cube”; //Cube.anysurf in Yahoo group files
> Transparency = 0.5;
> at {0,0,0}.
> Thank you,
> Brent
> — In anyscript@yahoogroups.com, “AnyBody Support” <support@> wrote:
> > Hi Brent,
> > Origin = {0,0,1};
> > AnyRefNode node = {
> > Adding
> > comparison.
> > Best regards,
> > Michael
> > AnyBody Support
> > > Hello,
0.1, 0}?
in the
> > > Brent
Hi Brent,
I see you confusion now. It is not what Christian speaks of that
tricks you (though he is right of course). What happens in your case
is the following:
You define GloablRef at (0,0.1,0). Then you make a node with the
relative displacement (sRel) of zero in all direction. This implies
of course that the node is place on top of GlobalRef.
Then you make a segment (AnySeg) called Box. A segment is also a
reference frame but a movable one and therefore you can give it a
position, but this is just an initial position. The initial position
you set equal to sRel (which is the zero vector) and therefore the
segment is (initially) positioned at the global origin (not the
origin of GlobalRef).
You can put (declare) your stl geometry in BoxPnt itself. Then you
will get what you want, I believe.
Alternatively (not what you want in this case but just to explain),
you can make kinematic constraints on the motion of the segment
called Box that state that it must be fixed to the BoxPnt. Then when
you run the kinematic analysis, the segment will be moved away from
its initial position to the correct position (specified by the
constraints).
I hope this clear the matter a bit.
Michael
Anybody Support
> Michael,
cube
> corner of the cube.
> };//GlobalRef
> AnySeg Box = {
> Transparency = 0.5;
the
be
> at {0,0,0}.
> Thank you,
> Brent
wrote:
> > Hi Brent,
> > Origin = {0,0,1};
> > AnyRefNode node = {
which
> > Adding
> > comparison.
upload
> > Best regards,
> > Michael
> > AnyBody Support
> > > Hello,
0.1, 0}?
in the
the
loaded at
Origin is
Origin
> > > Brent
Thanks for the note Christian. This was confusing me also because the
origin for the cube is in the center of one of the cube’s faces, but
AnyBody loads it to the corner of the cube. Thus, AnyBody is ignoring
the local coordinate system of the STL. (See Cube.STL in Yahoo group
files.)
Brent
— In anyscript@yahoogroups.com, “cgol03” <cgammel@…> wrote:
> Hi Brent
> Regards Christian
> > Michael,
> > corner of the cube.
> > };//GlobalRef
> > AnySeg Box = {
> > Transparency = 0.5;
> > at {0,0,0}.
> > Thank you,
> > Brent
> > > Hi Brent,
> > > Origin = {0,0,1};
> > > AnyRefNode node = {
> > > Adding
> > > comparison.
> > > Best regards,
> > > Michael
> > > AnyBody Support
> > > > Hello,
> 0.1, 0}?
> in the
loaded at
Origin
> > > > Brent
Michael,
I see now that the GlobalRef.Origin is different than the global
origin. My first thought was that the definition of GlobalRef would
define an origin for all other reference frames. From what you said,
there is a fixed global origin at {0,0,0} and GlobalRef.Origin is a
reference frame, like any other defined reference frame.
Brent
> Hi Brent,
> is the following:
> constraints).
> Best regards,
> Michael
> Anybody Support
> > Michael,
> cube
> > corner of the cube.
> > };//GlobalRef
> > AnySeg Box = {
> > Transparency = 0.5;
> the
> be
> > at {0,0,0}.
> > Thank you,
> > Brent
> wrote:
> > > Hi Brent,
> > > Origin = {0,0,1};
> > > AnyRefNode node = {
> which
> > > Adding
> > > comparison.
> upload
> > > Best regards,
> > > Michael
> > > AnyBody Support
> > > > Hello,
> 0.1, 0}?
> in the
> the
> loaded at
> Origin is
> Origin
> > > > Brent
Brent,
Yes - exactly.
Well I can understand your confusion due to the name ‘GlobalRef’,
but the name could have been anything, which might have made it
clearer.
I too do not know why it is displaced the 0.1 meter in the model you
speak of.
About the Cube.stl: I do not think it has a local frame in the
center of the cube. I looked in the file and all vertices have
positive or zero coordinates in all directions, as far as I can see.
This indicates that the local system is indeed locaed in a corner.
Was it different in the CAD system where you created it?
Michael
AnyBody Support
> Michael,
would
said,
> Brent
wrote:
> > Hi Brent,
case
> > is the following:
implies
a
position
the
you
explain),
when
from
> > constraints).
> > Best regards,
> > Michael
> > Anybody Support
> > > Michael,
a
> > cube
a
> > > corner of the cube.
> > > };//GlobalRef
> > > AnySeg Box = {
> > > Transparency = 0.5;
at
> > the
is
Origin
Origin
should
> > be
> > > at {0,0,0}.
> > > Thank you,
> > > Brent
> > wrote:
> > > > Hi Brent,
> > > > Origin = {0,0,1};
> > > > AnyRefNode node = {
of ‘GlobalRef’,
> > which
in ‘GlobalRef’.
> > > > Adding
for
> > > > comparison.
> > upload
> > > > Best regards,
> > > > Michael
> > > > AnyBody Support
> > > > > Hello,
{0,
> > 0.1, 0}?
{0,0,0}
> > in the
on
> > the
> > loaded at
> > Origin is
an
> > Origin
> > > > > Brent
Yes… just loaded the cube into Rhino, and the origin is located in a
corner of the cube.
Regards Christian
> Brent,
> Yes - exactly.
> clearer.
> speak of.
> Michael
> AnyBody Support
> > Michael,
> would
> said,
> > Brent
> wrote:
> > > Hi Brent,
> case
> > > is the following:
> implies
> a
> position
> the
> you
> explain),
> when
> from
> > > constraints).
> > > Best regards,
> > > Michael
> > > Anybody Support
> > > > Michael,
> a
> > > cube
> a
> > > > corner of the cube.
> > > > };//GlobalRef
> > > > AnySeg Box = {
> > > > Transparency = 0.5;
> at
> > > the
> is
> Origin
> Origin
> should
> > > be
> > > > at {0,0,0}.
> > > > Thank you,
> > > > Brent
> > > wrote:
> > > > > Hi Brent,
> > > > > Origin = {0,0,1};
> > > > > AnyRefNode node = {
> of ‘GlobalRef’,
> > > which
> in ‘GlobalRef’.
> > > > > Adding
> for
> > > > > comparison.
> > > upload
> > > > > Best regards,
> > > > > Michael
> > > > > AnyBody Support
> > > > > > Hello,
> {0,
> > > 0.1, 0}?
> {0,0,0}
> > > in the
> on
> > > the
> > > loaded at
> > > Origin is
> an
> > > Origin
> > > > > > Brent
I figured out that the origin was moved by the CAD program when
exporting the STL such that all values were positive. I corrected
that, and now it is importing as expected.
Thank you,
Brent
> Hi
> corner of the cube.
> Regards Christian
> > Brent,
> > Yes - exactly.
> > clearer.
> > speak of.
> > Michael
> > AnyBody Support
> > > Michael,
> > would
> > said,
> > > Brent
> > wrote:
> > > > Hi Brent,
> > case
> > > > is the following:
> > implies
> > a
> > position
> > the
> > you
> > explain),
> > when
> > from
> > > > constraints).
> > > > Best regards,
> > > > Michael
> > > > Anybody Support
> > > > > Michael,
> > a
> > > > cube
> > a
> > > > > corner of the cube.
> > > > > };//GlobalRef
> > > > > AnySeg Box = {
> > > > > Transparency = 0.5;
> > at
> > > > the
> > is
> > Origin
> > Origin
> > should
> > > > be
> > > > > at {0,0,0}.
> > > > > Thank you,
> > > > > Brent
> > > > wrote:
> > > > > > Hi Brent,
> > > > > > Origin = {0,0,1};
> > > > > > AnyRefNode node = {
> > of ‘GlobalRef’,
> > > > which
> > in ‘GlobalRef’.
> > > > > > Adding
> > for
> > > > > > comparison.
> > > > upload
> > > > > > Best regards,
> > > > > > Michael
> > > > > > AnyBody Support
> > > > > > > Hello,
> > {0,
> > > > 0.1, 0}?
> > {0,0,0}
> > > > in the
> > on
> > > > the
> > > > loaded at
> > > > Origin is
> > an
> > > > Origin
> > > > > > > Brent
Hi Brent
You are welcome. Which CAD program are you using?
Regards Christian
> Thank you,
> Brent
> — In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>,
> > Hi
> > corner of the cube.
> > Regards Christian
> <mailto:anyscript%40yahoogroups.com>, “AnyBody Support” <support@> wrote:
> > > Brent,
> > > Yes - exactly.
> > > clearer.
> > > speak of.
> > > Michael
> > > AnyBody Support
> <mailto:anyscript%40yahoogroups.com>, “blulrey” <blulrey@> wrote:
> > > > Michael,
> > > would
> > > said,
> > > > Brent
> > > wrote:
> > > > > Hi Brent,
> > > case
> > > > > is the following:
> > > implies
> > > a
> > > position
> > > the
> > > you
> > > explain),
> > > when
> > > from
> > > > > constraints).
> > > > > Best regards,
> > > > > Michael
> > > > > Anybody Support
> > > > > > Michael,
> > > a
> > > > > cube
> > > a
> > > > > > corner of the cube.
> > > > > > };//GlobalRef
> > > > > > AnySeg Box = {
> > > > > > Transparency = 0.5;
> > > at
> > > > > the
> > > is
> > > Origin
> > > Origin
> > > should
> > > > > be
> > > > > > at {0,0,0}.
> > > > > > Thank you,
> > > > > > Brent
> > > > > wrote:
> > > > > > > Hi Brent,
> > > > > > > Origin = {0,0,1};
> > > > > > > AnyRefNode node = {
> > > of ‘GlobalRef’,
> > > > > which
> > > in ‘GlobalRef’.
> > > > > > > Adding
> > > for
> > > > > > > comparison.
> > > > > upload
> > > > > > > Best regards,
> > > > > > > Michael
> > > > > > > AnyBody Support
> > > > > > > > Hello,
> > > {0,
> > > > > 0.1, 0}?
> > > {0,0,0}
> > > > > in the
> > > on
> > > > > the
> > > > > loaded at
> > > > > Origin is
> > > an
> > > > > Origin
> > > > > > > > Brent
Hi Christian,
I used Solidworks '98. In the future, I’ll probably use Solid Edge or
Autocad because the department I’m in has newer versions available for
use. I won’t be creating extensive models, but I wanted to make sure
I understood the STL importing process.
Brent
— In anyscript@yahoogroups.com, Christian Gammelgaard <cgol03@…>
wrote:
> Hi Brent
> Regards Christian
> > Thank you,
> > Brent
> > “cgol03” <cgammel@> wrote:
> > > Hi
located in a
> > > corner of the cube.
> > > Regards Christian
wrote:
> > > > Brent,
> > > > Yes - exactly.
> > > > clearer.
model you
> > > > speak of.
can see.
> > > > Michael
> > > > AnyBody Support
> > > > > Michael,
> > > > would
> > > > said,
> > > > > Brent
> > > > wrote:
> > > > > > Hi Brent,
of that
your
> > > > case
> > > > > > is the following:
with the
> > > > implies
also a
give it
> > > > a
> > > > position
> > > > the
(not the
> > > > you
> > > > explain),
segment
Then
> > > > when
> > > > from
> > > > > > constraints).
> > > > > > Best regards,
> > > > > > Michael
> > > > > > Anybody Support
> > > > > > > Michael,
import
> > > > a
> > > > > > cube
it at
> > > > a
> > > > > > > corner of the cube.
> > > > > > > };//GlobalRef
> > > > > > > AnySeg Box = {
> > > > > > > Transparency = 0.5;
> > > > at
> > > > > > the
case
> > > > is
> > > > Origin
> > > > Origin
> > > > should
> > > > > > be
> > > > > > > at {0,0,0}.
> > > > > > > Thank you,
> > > > > > > Brent
> > > > > > wrote:
> > > > > > > > Hi Brent,
> > > > > > > > Origin = {0,0,1};
> > > > > > > > AnyRefNode node = {
> > > > of ‘GlobalRef’,
> > > > > > which
> > > > in ‘GlobalRef’.
> > > > > > > > Adding
(0,0,0)
> > > > for
> > > > > > > > comparison.
please
> > > > > > upload
> > > > > > > > Best regards,
> > > > > > > > Michael
> > > > > > > > AnyBody Support
> > > > > > > > > Hello,
> > > > {0,
> > > > > > 0.1, 0}?
> > > > {0,0,0}
> > > > > > in the
> > > > on
> > > > > > the
stl is
> > > > > > loaded at
> > > > > > Origin is
using
> > > > an
> > > > > > Origin
folder.
> > > > > > > > > Brent
