StandingModel InitialPositions.any
In the “InitialPositions.any” file for StandingModel, what are
the ‘x’, ‘y’, and ‘z’ in RotMat refering to? From what I can gather
observationally, they initially refer to the global coordinates (x -
anterior, y - superior, z - lateral) located at the origin of the
humerus, but then they move with the humerus through each rotation (so
therefore order matters). Is this correct? Or are the axes used
almost the same direction as global? If this is the case, how do find
the direction of these rotational axes?
Nick
Hi Nick
the x,y and z in RotMat is refering to the axis that the first
argument is rotating around.
I am not sure I understand you correct, but the initial positions is
the position you want the model to stand in after it is loaded. The
initial position does not change during the kinematic movements.
Best Regards Christian
> Nick
Hi Christian,
I’m pretty sure that I understand the mechanics of the RotMat
command, but I am unsure as to what the x,y and z axes are referring
to. Are they global, or the local of the humerus? In context from
the InitialPositions.any file:
//right humerus
ref.Right.ShoulderArm.Seg.Humerus.Axes0 =
ref.Trunk.SegmentsThorax.ThoraxSeg.Axes0*
ref.Trunk.SegmentsThorax.ThoraxSeg.ij.ARel*
ref.Trunk.SegmentsThorax.ThoraxSeg.ij.RotNode.ARel*
RotMat((pi/180)JointPos.Right.GlenohumeralFlexion ,z)
RotMat((pi/180)JointPos.Right.GlenohumeralExternalRotation ,y)
RotMat((pi/180)JointPos.Right.GlenohumeralAbduction ,x)
ref.Right.ShoulderArm.Seg.Humerus.gh.RotNode.ARel’*
ref.Right.ShoulderArm.Seg.Humerus.gh.ARel’;
It is not immediately clear what coordinate system the x,y, and z
are with respect to.
Nick
— In anyscript@yahoogroups.com, “Christian Gammelgaard”
<cgol03@…> wrote:
> Hi Nick
is
gather
(x -
the
rotation (so
do find
> > Nick
Hi Nick
The rotations are wrt to the global ref. of the system in this case.
The RotMat will just provide a rotation matrix and it is what you
use it for which will decide if it is wrt to local or global
cooridnate systems.
So in this case where we set the Axes property of the segment it is
wrt to the global system, but if we had applied the rotation to an
ARel of an node on a segment it would be the coordinate system of
this node.
I when the lines below says:
it will rotate the segment around the global z axis
then it is mulitplied by the rotmat
RotMat((pi/180)*JointPos.Right.GlenohumeralExternalRotation ,y)
which is then effectively a rotation wrt. to already rotated syetem.
So it is only the first rotation which is wrt. to the global
coordinate system.
> Hi Christian,
referring
from
> //right humerus
> Nick
> <cgol03@> wrote:
> > Hi Nick
positions
> is
The
> gather
coordinates
> (x -
> the
> rotation (so
used
> do find
> > > Nick
