I tried to use AnyGait with static and dynamic files from the examples in the repository (Standing Reference as static, and Slow Run as dynamic), just like in the webcast, and operations failed when I load “PreProcessing” step.
I have the following message:
No Object selected in tree view. Please select an object to view Object Description.
I also tried with personal files, and I have exactly the same message at the same step.
Could you help me to solve the problem?
Thank you very much,
Claude Pothrat
