Synching data
I wrote earlier with a question regarding whether or not I have to
synch and/or filter data, and you responded that AnyBody does that for
us. I have a problem though: I am trying to drive a model with both
kinetic and kinematics data. The problem is that kinetics is
collected at 240Hz, and kinematics at 60Hz. So I have more kinetics
data points over a half-a-second time interval than kinematics data
points. I am trying to create a model similar to the Sway Practice
model in the files section of this website, but I keep getting the
error, “The matrix must contain the same number of columns as T has
elements, i.e., data points and time must match.” How can I get the
data points and time to match, if I have collected more kinetics data
points in a set amount of time than kinematics data points?
Thanks for your time,
Sarah
Hi Sarah
If you click on the error message it will jump to the location where the error
is. I think problem could be that the T vector is not matching the data matrix.
There must be as many elements in the T vector as there are Columns in the data
matrix. So when you have two different sampling frequencies you must have two
different time vectors, where one of them is four times bigger, in this case.
For the data matrix with the high sampling freq. you must then use the large
time vector.>>> >Here is a small sample that shows how a matching data set could
look like>>> > T = {0,0.33,0.66,1.01};>> Data={>> {0,0.2,0.2,0.4},>>
{0,0.3,0.3,.0.4},>> {0,0.4,0.4,.0.5}>> };>>> >This data set can be used for
driving three dof since the data matrix has three rows, it has four time values
in the T vector and four columns in the Data matrix.>>> >The model will be
correctly synchronized if the time vectors has the same initial start time.>>
>>Best regards>>AnyBody Support>>
Thanks for getting back to me so quickly. Could I use a fraction to
represent a time-step? For example, could I use 1/240 instead of
0.004167? I think that AnyBody has a problem with irrational or repeating
numbers - will fractions work?
Thanks again,
Sarah
> Hi Sarah
> has
> the
> error is. I think problem could be that the T vector is not matching the
> data matrix. There must be as many elements in the T vector as there are
> Columns in the data matrix. So when you have two different sampling
> frequencies you must have two different time vectors, where one of them
> is four times bigger, in this case. For the data matrix with the high
> sampling freq. you must then use the large time vector.>>> >Here is a
> small sample that shows how a matching data set could look like>>> > T =
> used for driving three dof since the data matrix has three rows, it has
> four time values in the T vector and four columns in the Data matrix.>>>
> >The m odel will be correctly synchronized if the time vectors has the
> same initial start time.>> >>Best regards>>AnyBody Support>>
> AnyBody Technology provides free support on the use of the AnyBody
> Modeling System and the Scripting language AnyScript. Other users are
> welcome to join the discussions.
> SPONSORED LINKS
> Biomedical engineering degree
> Biomedical engineering career
> Biomedical engineering program
> schools Biomedical
> engineering jobs Biomedical
> engineering
> YAHOO! GROUPS LINKS
> Visit your group “anyscript” on the web.
> To unsubscribe from this group, send an email to:
> anyscript-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Sarah R. Sullivan
PhD Candidate, Biomedical Engineering
Rutgers, The State University of New Jersey
Piscataway, NJ 08854
sarsulli@eden.rutgers.edu
908-420-3371
Hi Sarah
Yes frations should do ok.
You could also consider having only the frame numbers in the vector
and then multiply by 1/framerate.
In this way
T={1,2,3,4…}*1/framerate;
You are right that it is not allowed to have repeating number like
T={1,1,2,2} the vetor needs to be monotonical increasing otherwise
the interpolation functions will not be able to work.
AnyBody support
— In anyscript@yahoogroups.com, “Sarah R. Sullivan”
to
repeating
> Thanks again,
> Sarah
> > Hi Sarah
have to
that for
with both
kinetics
kinematics data
Practice
getting the
columns as T
> > has
can I get
> > the
kinetics data
where the
matching the
there are
sampling
of them
high
is a
like>>> > T =
can be
it has
matrix.>>>
has the
AnyBody
users are
> > SPONSORED LINKS
> > schools Biomedical
> > engineering
> > YAHOO! GROUPS LINKS
Service.
> Sarah R. Sullivan
> sarsulli@e…
> 908-420-3371
Last night I was able to compile my model, however this morning, I can’t
get past the error, “ERROR : C:\Documents and
Settings\ssullivan\Desktop\Supplement\k5x1\Model\Repository.5\BRep\Aalborg\Spine
\PelvisSeg.any(6)
: AnyFunTransform3D : Class name expected.
Model loading skipped.” I have tried loading a couple of models (in case
my own has failed), and I get the same thing for the ArmCurl model as
well. Is something wrong with the program? Or with my files? I’ll
upload them to Yahoo Groups to have a look at.
Sarah
> Hi Sarah
> In this way
> Best regards
> AnyBody support
> to
> repeating
> > Thanks again,
> > Sarah
> > > Hi Sarah
> have to
> that for
> with both
> kinetics
> kinematics data
> Practice
> getting the
> columns as T
> > > has
> can I get
> > > the
> kinetics data
> where the
> matching the
> there are
> sampling
> of them
> high
> is a
> like>>> > T =
> can be
> it has
> matrix.>>>
> has the
> AnyBody
> users are
> > > SPONSORED LINKS
> > > schools Biomedical
> > > engineering
> > > YAHOO! GROUPS LINKS
> Service.
> > Sarah R. Sullivan
> > sarsulli@e…
> > 908-420-3371
> SPONSORED LINKS
> schools Biomedical
> engineering
> YAHOO! GROUPS LINKS
Sarah R. Sullivan
908-420-3371
Hi Sarah
Which version of the AnyBody Modeling system are you using?
You can see this in the about box under in the help menu.
I think this problem is because you use a version which do not have
the scaling functions implemented, please update to new newest
preview version. Hopefully this will solve this problem. You can do
this online if you log into the members area on www.anybodytech.com
AnyBody Support
> Hi,
can’t
\BRep\Aalborg\Spine\PelvisSeg.any(6)
(in case
as
I’ll
> Thanks,
> Sarah
> > Hi Sarah
vector
> > In this way
like
otherwise
> > Best regards
> > AnyBody support
fraction
> > to
instead of
or
> > repeating
> > > Thanks again,
> > > Sarah
> > > > Hi Sarah
I
> > have to
does
> > that for
> > with both
kinetics is
more
> > kinetics
> > kinematics data
> > Practice
> > getting the
of
> > columns as T
> > > > has
match.” How
> > can I get
> > > > the
> > kinetics data
points?
location
> > where the
> > matching the
as
> > there are
> > sampling
one
> > of them
with the
> > high
>Here
> > is a
> > like>>> > T =
set
> > can be
rows,
> > it has
Data
> > matrix.>>>
vectors
> > has the
> > AnyBody
> > users are
> > > > SPONSORED LINKS
> > > > schools Biomedical
> > > > engineering jobs
Biomedical
> > > > engineering
> > > > YAHOO! GROUPS LINKS
Terms of
> > Service.
> > > Sarah R. Sullivan
> > > sarsulli@e…
> > > 908-420-3371
AnyBody
users are
> > SPONSORED LINKS
> > schools Biomedical
> > engineering
> > YAHOO! GROUPS LINKS
Service.
> Sarah R. Sullivan
> sarsulli@e…
> 908-420-3371
