Theory behind the ideal assistance
The webinar on 'Simulation-Driven Conceptual Design of Exoskeletons' describes the usage of ideal assistance for design purposes using a code segment like the one shown below.
AnyReacForce Reacs = {
AnyKinMeasure &k1 = Main.HumanModel.BodyModel.Right.Leg.Jnt.Knee;
Is any equation or other explanation to understand how these ideal motors provide (determine) all the required assistance to the selected DOF of the joint during the simulation.
Jeevan
Hi Jeevan,
The most comprehensive theory can be found in some of the papers describing the mathematics behind AnyBody Modeling System. I would suggest you this paper:
Damsgaard M, Rasmussen J, Christensen ST, Surma E, de Zee M, (2006), "Analysis of musculoskeletal systems in the AnyBody Modeling System". Simulation Modelling Practice and Theory, vol. 14, pp. 1100-1111.
There are a couple of other book chapters that can be helpful:
https://doi.org/10.1016/B978-0-12-819531-4.00004-3
https://doi.org/10.1016/B978-0-12-816713-7.00008-8
Hi Dave,
Thank you for providing the references. After looking at the documents you provided, we thought of two ways that the ideal torque can be possibly explained, as shown below.
Could you please let us know if any of these are correct, or if not, we would appreciate any directions to clarify the math behind ideal torque.
Jeevan
Hi Jeevan,
Let me try an explanation in words. AnyBody basically computes the internal forces in the body to balance external loads and dynamics. These internal forces get split into two groups:
  1. Muscle forces
  2. Joint reactions
The first step to understanding is to make sure that you accept that the system will give you these forces as output when you run the analysis.
The second step is to notice that only the first set, the muscle forces, are minimized, because they carry a cost in the optimization problem that is being solved. The second set, the joint reactions, are costless and will therefore have the value that is maximally beneficial for the muscles.
When you define something to be an AnyReacForce in the model, then the item will belong to the second category. This means that this force will be calculated but not minimized. Instead, at every time of the motion, it will take the value that is the most beneficial for minimizing the muscle forces. Therefore, when you look at the resulting values after the analysis, these values will represent the optimum support a motor placed at the location of the AnyReacForce could possibly provide to support the muscle actions in the whole body.
I hope this helps.
John
Hi John,
Thank you very much for the explanation. It was very useful to clarify our question.
Jeevan
