I am trying to analyse the muscular forces of a lizard’s jaws for a scientific work at university. I’ve programmed the attached file but it always says “too few kinematic constraints” when I reload it. I do not know what I’ve missed because I’ve used the AnyBody tutorials as a guide.
Maybe one of you sees where the problem is located.
Thank you in advance and regards,
Christian
PS: There are two versions attached. The file called “sicherheitskopie” may be easier to read and understand because i tried to rearrange some parts of the code in order to see if it has any effect.
Thanks for the fast answer. I already assumed that this would be the problem, but how do I implent the AnyKinLinear and AnyKinRotational? And how can I set them to 0? The AnyScript Reference did not really help me.
Thank you, Amir, but I still did not manage to run it with AnyKinLinear/Rotational.
I used the structure of demo lesson 6 in order to make the kinematics work.
My next problem is the inverse dynamics.
AnyBody keeps telling me “The muscles in the model are not loaded due to kinetically over-constrained mechanical system.[SIZE=2]”[/SIZE]
[SIZE=2]But why and especially where is it over-constrained now?[/SIZE]
[SIZE=2][/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]EDIT: I works now. I had to set the reaction type to off.
[/SIZE]
