I’m quite new to Anybody so apologies in advance if this is a bit obvious. I’m currently using a tutorial and am trying to model TKR but can’t find the repository AMMRV1.5.1? Where can I download this from?
Ammar
Ammar
Hey Ammar,
welcome to the AnyBody Forum. It is very tough to find the Rep 1.5.1, because it doesn’t exist yet
But I can explain how to get AMMRv1.5. If you run the AnyBody Modeling System v5.2, click on Help and Demo. There you will find:
[i]The AnyBody AnyScript Demo Repository
This is a demo version of the AnyBody Managed Model Repository (AMMR).
To re-install/update the installed demo files, follow this link.[/i]
So follow that link!
Thank you for your reply!
I am still having problems as if I go to help and demo I don’t get the message you specified but instead I get an error saying the file cannot be found? Should I reinstall Anybody, or is there any other way I can access those files?
Ammar
Hey Ammar,
this is a strange behaviour. I’ve never seen that before. Can you please try to re-install AnyBody. Did you get any error messages during installation?? If re-installing doesn’t work, please provide info on your system, what windows, what AMS license…
Sorry for the inconvenience.
can you check if you have a folder called AMMR in the folder where AnyBody is installed? You should find the models in there as well.
For Example at:
C:\Program Files…\AnyBody…\AMMR
Thank you Amir
I haven’t had an opportunity to go through what you said yet as I have had another problem. I cannot seem to be able to convert my C3D files into Anyscript files. I can run the c3d2any file but nothing happens apart from the DOS promt appearing and quickly disappearing. Are there any tutorial based on how to convert?
Hi Ammar,
Try using a command prompt to see what error message it gives. (CMD command in Windows)
Hi Pavel
Thank you for your reply. I have just realised that the cd32any file which I have is meant for Anybody versions 2,3 and 4. I currently have 5.2. A colleague of mine said it is possible to convert from C3D to Anyscript file using the Anybody program. If so, how would I do this?
Hi Ammar,
Yes, indeed. You don’t need the C3D2Any anymore.
Please go through the AnyBody tutorials to see how you can use c3d files: Making things move->Lesson 5: Using real data. It should explain how a c3d file can be used. Then try using and adjusting the GaitLowerExtremity model available in the AMMR to suit needs.
Hi Pavel
I get an error when loading up my own C3D file:
ERROR(SCR.PRS9) : D:/M…s/A…s/A…1/A…1/A…n/E…s/G…y/ModelSetup.any : Defined At : D:/M…s/A…s/A…1/A…1/A…n/E…s/G…y/ModelSetup.any : ‘LMT5’ : Unresolved object
Model loading skipped.
This occurs when I press F7 to reload the model.
Any ideas?
Thanks
Ammar
It means you don’t have this specific marker in c3d file - please comment all related objects. Most likely there will be more of them.
P.
Thanks that worked and I managed to comment out many of the markers that are not in my model. However, now I am getting the following message:
ERROR(SCR.PRS9) : D:/M…s/A…s/A…1/A…1/A…n/E…s/G…y/EnvironmentAutoDetection.any : ‘CAL_MATRIX’ : Unresolved object
I am assuming that I must comment out the Cal_Matrix in the EnvironmentAutoDetection file? I have tried this and I get another error in:
ERROR(SCR.SCN6) : D:/M…s/A…s/A…1/A…1/A…n/E…s/G…y/EnvironmentAutoDetection.any : ’
(new line)’ : Unexpected character.
Any help much appreciated
Ammar
Ammar, you most likely need to use a different forceplate type - it must be the type 2. It should resolve your problem.
[SIZE=3][SIZE=2][COLOR=black]Hi
It still does not seem to work. Am I meant to put some values in for the Cal matrix? I have copied the file below
//This file creates the environment around the human
//It creates the force plates and add the measure load to them
[/SIZE][/COLOR][/SIZE]#define HumanModelPresent 1
AnyFixedRefFrame GlobalRef ={
Origin={0,0,0};
AnyDrawRefFrame drw={ScaleXYZ=0.4*{1,1,1};};
//ForcePlateType2AutoDetection Plate1 (
//PlateName = Plate1,
//Folder =Main.ModelSetup.C3DFileData,
//Limb1= .HumanModelRef.Right.Leg.Seg.Foot,
//Limb2= .HumanModelRef.Left.Leg.Seg.Foot,
//No=0,
//VerticalDirection =“Z”,
//HeightTolerance=0.07,
//VelThreshold=2.2,
//Fx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fx13,
//Fy=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fy13,
//Fz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fz13,
//Mx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mx13,
//My=Main.ModelSetup.C3DFileData.Analog.DataFiltered.My13,
//Mz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mz13,
//FootPresent=HumanModelPresent)
// Cal=Main.ModelSetup.C3DFileData.Groups.FORCE_PLATFORM.CAL_MATRIX.Data[0];
ForcePlateType4AutoDetection Plate2 (
PlateName = Plate2,
No=1,
VelThreshold=2.2,
Fx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fx1,
Fy=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fy1,
Fz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fz1,
Mx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mx1,
My=Main.ModelSetup.C3DFileData.Analog.DataFiltered.My1,
Mz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mz1,
Cal=Main.ModelSetup.C3DFileData.Groups.FORCE_PLATFORM.CAL_MATRIX.Data[1];
ForcePlateType4AutoDetection Plate3 (
PlateName = Plate3,
No=2,
VelThreshold=2.2,
Fx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fx3,
Fy=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fy3,
Fz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fz3,
Mx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mx3,
My=Main.ModelSetup.C3DFileData.Analog.DataFiltered.My3,
Mz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mz3,
Cal=Main.ModelSetup.C3DFileData.Groups.FORCE_PLATFORM.CAL_MATRIX.Data[2];
#undef HumanModelPresent
you need to uncomment ForcePlateType2AutoDetection and use instead of ForcePlateType4AutoDetection.
Sorry, I see it’s a wrong file.
Please have a look at the C3D project application: C3DProject\MyC3DData\EnvironmentAutoDetection.any
Sorry I’m no too sure what you meant by your last comment. Nevertheless, I have been using the following thread http://forum.anyscript.org/showthread.php?t=2766
as it has a similar problem to mine with the Cal Matix. I have found out that my gait analysis data used a force plate type 2, so would I comment out the following:
//#include “…/…/…/Body/AAUHuman/ToolBox/Mocap/ForcePlateType4AutoDetection.any”
//#include “…/…/…/Body/AAUHuman/ToolBox/Mocap/ForcePlateType4.any”
[COLOR=black]I also have done the following in the EnvironmentAutoDetection folder
[COLOR=#007f00]//This file creates the environment around the human
Origin={0,0,0};
ForcePlateType4AutoDetection Plate1 (
PlateName = Plate1,
No=0,
VerticalDirection =“Y”,
VelThreshold=2.2,
//Cal=Main.ModelSetup.C3DFileData.Groups.FORCE_PLATFORM.CAL_MATRIX.Data[0];
//ForcePlateType4AutoDetection Plate2 (
//PlateName = Plate2,
//No=1,
//VerticalDirection =“Y”,
//VelThreshold=2.2,
//Fx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fx2,
//Fy=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fy2,
//Fz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fz2,
//Mx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mx2,
//My=Main.ModelSetup.C3DFileData.Analog.DataFiltered.My2,
//Mz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mz2,
//Cal=Main.ModelSetup.C3DFileData.Groups.FORCE_PLATFORM.CAL_MATRIX.Data[1];
//ForcePlateType4AutoDetection Plate3 (
//PlateName = Plate3,
//No=2,
//VelThreshold=2.2,
//Fx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fx3,
//Fy=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fy3,
//Fz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Fz3,
//Mx=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mx3,
//My=Main.ModelSetup.C3DFileData.Analog.DataFiltered.My3,
//Mz=Main.ModelSetup.C3DFileData.Analog.DataFiltered.Mz3,
//Cal=Main.ModelSetup.C3DFileData.Groups.FORCE_PLATFORM.CAL_MATRIX.Data[2];
I just wanted to check what I’m doing is correct. After doing all this I no longer get the cal matrix error but a
ERROR(SCR.PRS11) : D:/M…s/A…s/A…1/A…1/A…n/E…s/G…y/EnvironmentAutoDetection.any : ‘(’ unexpected
and I can’t figure out where the mistake is. Any help much appreciated
[/COLOR][/COLOR]
It’s simply a syntax error - check the braces. I will take a look at the model you posted in another thread.
