Hello everyone,
First of all I’d like to introduce myself. My name is Dieter and I’m
a student of medical engineering working at the Uni Ulm.
Then I would like to apologize about my poor knowledge on anybody-
script-language but I just started using the software and I worked
through most of the tutorials available on anybodytech.com.
Unfortunately, I’m not allowed to tell you too much about my project:
We have motion capturing data of an animal received by computer
tomographic imaging. At the moment, I’m trying to drive just one
segment by this data (highest located segment). These contain
informations about the x,y,z-translations and one rotation per
timestep. I found an example somewhere here in the group:
Main = {
// The actual body model goes in this folder
AnyFolder Model = {
//Points used for defining the line
AnyVec3 p1={0,0,0};
AnyVec3 p2={0.2,0.2,0.4};
AnyVec3 p3={0.4,0.3,0.3};
AnyVec3 p4={0.7,0.4,0.1};
AnyVec3 p5={0.9,0.5,0.1};
AnyVec3 p6={0.95,-0.2,0.3};
AnyVec3 p7={1.2,-0.3,0.6};
AnyVec3 p8={1.5,-0.1,0.8};
AnyVec3 p9={2,0.2,0.9};
AnyVec3 p10={2.4,0.5,1};
// Global Reference Frame
//Create some controlpoints
AnyRefNode p1={sRel=..p1;
AnyDrawRefFrame drw={ScaleXYZ={0.01,0.01,0.01};};
AnyRefNode p2={sRel=..p2;
AnyRefNode p3={sRel=..p3;
AnyRefNode p4={sRel=..p4;
AnyRefNode p5={sRel=..p5;
AnyRefNode p6={sRel=..p6;
AnyRefNode p7={sRel=..p7;
AnyRefNode p8={sRel=..p8;
AnyRefNode p9={sRel=..p9;
AnyRefNode p10={sRel=..p10;
}; // Global reference frame
AnySeg Seg={
Mass=0;Jii={0,0,0};
AnySurfSphere Sphere= {
Radius=0.21;
AnyDrawParamSurf drw={};
AnyKinLinear lin={
AnyFixedRefFrame &ref1=.GlobalRef ;
AnySeg &ref2=.Seg;
AnyKinEq RotDrv={
AnyKinRotational rot={
AnyFixedRefFrame &ref1=..GlobalRef ;
AnySeg &ref2=..Seg;
Type=RotAxesAngles;
//Interpolation driver
AnyKinEqInterPolDriver Driver = {
Type = Bspline ; //try to swicth between the different types
BsplineOrder = 4;
// Type = Bezier ; //try to swicth between the different
types
// Type = PiecewiseLinear ;//try to swicth between the
different types
//FileName = "knecht.txt";
T =({0,1,2,3,4,5,6,7,8,9}/9)*Main.MyStudy.tEnd ;
//use the control points as data in the interpoaltion function
Data ={
{.p1[0],.p2[0],.p3[0],.p4[0],.p5[0],.p6[0],.p7[0],.p8[0],.p9
[0],.p10[0]},
{.p1[1],.p2[1],.p3[1],.p4[1],.p5[1],.p6[1],.p7[1],.p8[1],.p9
[1],.p10[1]},
{.p1[2],.p2[2],.p3[2],.p4[2],.p5[2],.p6[2],.p7[2],.p8[2],.p9
[2],.p10[2]}};
AnyKinMeasure &ref = .lin; //reference to the measue being
driven
//This section is just made in order to draw the trajectory
AnyFixedRefFrame Chart1Ref ={
Origin = -{5,5,5};
AnyChart Chart1 = {
Style = {
Sizes = {10,10,10};
Axes = { Style = 0; };
Series =
AnyChartSerie series0 = {
Lines.RGB = {0,0,1};
Abscissa = "Main.MyStudy.Output.Model.Seg.r[0]";
Abscissa2 = "Main.MyStudy.Output.Model.Seg.r[1]";
Value = "Main.MyStudy.Output.Model.Seg.r[2]";
Lines = { Thickness = 1.5; };
AbsAxis = {
Visible = Off;
Min = -5;
Max = 5;
AutoMin = Off;
AutoMax = Off;
AbsAxis2 =
Visible = Off;
Min = -5;
Max = 5;
AutoMin = Off;
AutoMax = Off;
ValueAxis =
Visible = Off;
Min = -5;
Max = 5;
AutoMin = Off;
AutoMax = Off;
}; //chart
}; // MyModel
// The study: Operations to be performed on the model
AnyBodyStudy MyStudy = {
AnyFolder &Model = .Model;
RecruitmentSolver = MinMaxSimplex;
Gravity = {0.0, -9.81, 0.0};
nStep=1000;
}; // Main
Actually it pretty much works fine but I additionally would like to
rotate the segment. How can I achieve that?
Regards
