when I load C3D file, Receive an error message.(-attachment)
Please answer me…
Please answer me…
Your problem is that the analog channel names in your C3D file may be different from the ‘EnvironmentAutoDetection.any’ file.
You can check the analog channel names in many C3D viewers such as MOKKA. You can try this software to check your C3D files:
https://b-tk.googlecode.com/svn/web/mokka/index.html
And I attached an example of the C3D file which has different analog channel names.
In this case, you can edit the analog channel names in your C3D file.
Or you can modify your ‘EnvironmentAutoDetection.any’ file.
I hope this may help you.
