Hi Henrik and Tobias,
I am writing you regarding the Vista 64 issue. We have only little
experience with Vista and in particular Vista 64 yet. We are currently
preparing to support Vista 32 better in future versions of AnyBody.
I would like to help you as much as I can, but you will have to help me too
then, i.e., to gain experience into the problem. I would very much
appreciate this assistance from you.
If you are ready for this I suggest that we take the conversation off the
group while experimenting.
Michael
Michael Damsgaard, AnyBody Support
<http://www.anybodytech.com> www.anybodytech.com
Of AnyBody Support
Sent: Tuesday, November 20, 2007 21:35
Subject: RE: [AnyScript] Trouble with multi-dimensional analysis and home
installation
Welcome to the group, it sounds as an interesting problem.
From your description it sounds as you may have a recruitment problem, but
it is difficult to say from the description.
To find out if it is recruitment related please try to rerun the parameter
study but only run the kinematical analysis.
If the error is related to recruitment and if the error is reproducible my
suggestion would be to try to locate which parameter set, in the parameters
study are causing this error. I think that it may be the combination of the
parameters rather than the number of steps in the parameter study which are
causing the crash. So if you try running the parameter study again and then
notice for which parameter set it crash? Then subsequently try to rerun the
model with this set of parameters only and see if the error can be
reproduced. If this is that case, then investigate the parameters and if
possible evaluate if there could be any apparent reason for the problem. If
this seems not to be the case you could try to change the recruitment solver
it may possible solve the problem.
Please read more about the different solvers in the tutorial
http://www.anybodyt <http://www.anybodytech.com/691.0.html>
ech.com/691.0.html
There are two Linear algorithms to choose between MinMaxSimplex and
MinMaxNRSimplex , if you have tried only one of these, please try the other
one and see if this solves the problem, the results are identical.
In some cases if the problem is ill conditioned, it helps to add a small
amount of gravity in the zero direction of the gravity vector, so something
like Gravity={0.001,-9.81,0.001}; may also help solve recruitment problems
if this is the root of the problem, it will not change the solution.
If the problems persist, please try to find the parameter set causing the
problem and then upload this model to the file section of the group, then we
will try to debug it, please also write which version of AnyBody you are
using.
About the output, please try to insert an AnyOutPutFile object in your study
this will let you export as many variables you like to a text file.
I am uncertain about the installation problem; i will pass this question on
the development team.
I hope this helped you solved the problem; otherwise please do not hesitate
to write again.
From: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
Behalf
Of vtveteran
Sent: 20 November 2007 13:39
Subject: [AnyScript] Trouble with multi-dimensional analysis and home
installation
We are two students at LTH in Lund, Sweden who are using Anybody
v3.0.0 to do a biomechanical analysis of a cyclist as part of our
master thesis project. Unfortunately we have run into a little
difficulty and hope you can help us with a few points. We have
adapted the Bike Model 3D program from the repository to run
parameter and optimisation studies so that we can investigate the
effects of varying saddle height, saddle position and pedal arm
width, in the hope of comparing these results to real-world results
from test subjects.
Our first and greatest problem is that our program is prone to
unexpected, but reproducible, crashes that simply halt the analysis
with no error messages given or explanations as to the cause. The
program gives no compilation errors when loaded, and the crashes seem
to be mainly caused by the number of steps we make the program
investigate. Our most recent crash, for example, involved an n =
{4,4,4} step analysis, given a certain set starting value and
variable values for each parameter. A previously run n = {2,2,2} step
analysis, with identical start values and variable values, ran
through to its conclusion with no crashes. We found we could reduce
the number of crashes by using the simple muscle model as opposed to
the 3E model, but they still occur, thus far, every time we attempt an
analysis of more than around 40 steps in total.
Our second problem is that we cannot export our results to an external
browser. Given our need for a 4-dimensional graph to view our results
satisfactorily, the ability to export the results is vitally
important for us. We realise that it is possible, but are having
difficulties implemeting the commands found under the Export folder
in the properties meny of the 2D/3D Chart. Any pointers you could
give us on how to do this properly would be greatly appreciated!
Thirdly, I have attempted to install Anybody on my home computer, with
which we could perform these analyses much faster than on campus, but
am having problems with the student license dongle installation. I am
running Vista 64-bit, which I realise isn’t ideal for the moment, but
I have managed to install all the relevant parts of Anybody itself
and the License Manager using Windows XP SP2 compatibility mode. When
I try to open Anybody, the License window appears, and when I
press “Dongle Bound License”, a screen pops up telling me to insert
the dongle. Unfortunately, this happens despite the fact that the
dongle is already inserted in the USB drive with a constant red
light, and the HASP License Manager is active (even when in XP SP2
compatability mode).
We would greatly appreciate any help you can give us! The school PC
we are trying to run on is a P4 1.8GHz with 512mb RAM with WinXP; is
this a factor in the crashes? If so, running it on my home computer
(Core 2 Duo 2.66GHz, 4gb RAM) is an even more pressing necessity,
given that Vista isn’t a limiting factor on its own.
Hope you can help us! Thanks in advance. We can of course send you our
program if you need it.
Henrik Sjöstedt
Tobias Lestrell
