tumor bone
Dear sir
I am doing the fea analysis of tumor femur bone.After export loads on tumor bone my output file is not opening well in abaqus. Its nodes are getting stretched (pic attached). As it parent mesh are opening well in abaqus without anybody loads. Sir is it mesh generation problem or something else.
Mohit Kuamr
Hi Mohit,
I may see two problems here - A) the muscle attachment areas are not matching your geometry; see our previous conversation about having consistent output from AnyBody and FEA; B) The node number of your mesh is higher than 250000 ? COuld it be the case? The load application nodes generated by the converter start from 250000 (might be a different number), and, thus, might overwrite some of the nodes of your mesh. To solve that - you can process the result of the converter by changing the indices to start from a larger number (a search and replace should do it, e.g. replace 250 by say 999 if your mesh is below 998999 nodes).
