Understanding of the reactions in AnyKinRotational when using the RotAxesAngles
I could understand the reactions in AnyStdJoint here:
http://wiki.anyscript.org/images/3/33/AnyStdJointReactions.any
We can define a AnyStdJoint very easy:
AnyStdJoint FixJoint1 =
   AnyRefFrame& ref1 = ..Ref1;
   AnyRefFrame& ref2 = ..Ref2;
And we can define a AnyStdJoint in a different way:
  AnyKinEqSimpleDriver FixJoint2 =
    AnyKinLinear Lin =
      Ref = 0;
      AnyRefFrame& ref1 = ...Ref1;
      AnyRefFrame& ref2 = ...Ref2;
    AnyKinRotational Rot=
      //Ref = 0;
      [b]Type = RotAxesAngles;[/b]
      Axis1 = x; Axis2 = y; Axis3 = z;
    MeasureOrganizer = {0,1,2,3,4,5};
    DriverPos = {0, 0, 0, 0, 0, 0};
    DriverVel = {0, 0, 0, 0, 0, 0};
For the reactions in the AnyStdJoint, we can understand that the reaction forces and torques are like this:
Fx,Fy,Fz,Mz,My,Mx = Fout[0],Fout[1],Fout[2],Fout[3],Fout[4],Fout[5]
Then in the case of FixJoint2 defined as AnyKinEqSimpleDriver using AnyKinLinear and AnyKinRotational class above code, I guess like this:
Fx,Fy,Fz,Mx,My,Mz = Fout[0],Fout[1],Fout[2],Fout[3],Fout[4],Fout[5]
Because in the AnyKinRotational object I set its type as ‘RotAxesAngles’ and set their axes as ‘Axis1 = x’, ‘Axis2 = y’ and ‘Axis3 = z’.
I would just like to know whether my guess is right or wrong.
Best regards and thanks in advance,
Hi Moonki, this is correct.
Best regards, Sylvain.
Hi Sylvain,
Thanks for your answer.
