Hello
My name is S. Anirudh. I am working in SUNY Buffalo on AnyBody project
involving the leg model. I am trying to get the leg model from the
repository to load , but can’t. The files are in RepositoryLeg.zip
S. Anirudh
Hello
S. Anirudh
In order to load a body part from the repository the model must respect a
certain structure of the folders. Your application is missing some folders
and files (Mannequin file for example), and some other folders are not in
the good location. That is why the model won’t load.
So the best way to respect this structure is to take one of the existing
applications as a starting point (the closest to what you aim at, I think in
your case the PedalDemo could be a good one) and then modify it as you need.
Sylvain, AnyBody Support
Of Anirudh Shivaswamy
Sent: 20. januar 2009 02:59
Subject: [AnyScript] Using the leg model from AnyBody repository
Hello
S. Anirudh
