I have one question about the WeightTransitionTime.
I’ve got a C3D file, in which one marker is lost in a short period of time. I searched for several solutions and I found that if I set the WeightTransitionTime into 0 it runs, as opposed to if I set this value into 0.1 that it appears an error like this: The values in Ts must be monotonically increasing
Is that ok, to set it into 0? or, do I have to do anything more?
If you marker is only away for one time frame a transition time of 0.1 may result in the error you get i think.
This is because the gap is much smaller that the transition time you are using, so genrally speaking the transition time can not be bigget than the gap, then it may create this error.
I have set the transition time into 0.001 and the error doesn’t appear. But it appears another error: Kinematic analysis failed in time step 0. So here I set the transition time into 0 and it works.
Is this ok?
