Hi Christian!
Today I did some some modification in the model. but there still some problem
and the model(Jan-23.rar) is uploaded to the folder(“yueningma”) . It said that
3 constaints are lost.
But the model donot any constraints. The constraints added in the following:
3 contraints added on pelvis; 1 added on the knee; and 2 added on the foot.
what should I do for contious working!
best regrads
yuening
----- 原始邮件 ----
�件人: yuening ma <yueningma@yahoo.com.cn>
æ"¶ä»¶äººï¼š anyscript@yahoogroups.com
2008/1/23, 9:30:31
[AnyScript] Re: Using the "AnyKinEqSImpleDriver "
Christian!
Thanks for your time.
Yes. It is what I want to do.
best regards
yuening
----- 原始邮件 ----
�件人: AnyBody Support <support@anybodytech .com>
æ"¶ä»¶äººï¼š anyscript@yahoogrou ps.com
2008/1/23, 4:00:40
主题: [AnyScript] Re: Using the "AnyKinEqSImpleDriv er "
Hi Yuening
No worries. I looked at the model and your problem is that the model
is over-constrained. If you have a look in the JointsAndDrivers. any
you will see that you have constrained the hip with a AnyStdJoint and
you also tries to drive it with a marker.
The same kind of joint is used at the foot which you also tries to
drive with a marker. At the same time you tries to drive the knee and
the ankle in the x-direction. If you outcomment the AnyEqSimpleDrivers
your model will run because this removes the 4 constraints that makes
the system over-constrained. I don’t think that is what you want… is
it? I think you wanna drive the foot, ankle, knee and pelvis with the
marker data?
You only have one marker for the pelvis?
Let me know if I am right and I will try to guide you through:D
Christian, AnyBody Support
— In anyscript@yahoogrou ps.com, yuening ma <yueningma@. …> wrote:
> Christian
> Sorry ! I uploaded it just now.
> ----- �熷�嬮�浠� ----
> é?â„¢`浠朵汉é"›ï¿½ AnyBody Support <support@… >
> �"朵欢浜猴細 anyscript@yahoogrou ps.com
> 宸æ?’廯閫侊細 2008/1/22(錪ㄤ簩), æ¶"å©‚å´?4:24:22
> æ¶"婚�橈細 [AnyScript] Re: Using the "AnyKinEqSImpleDriv er "
> Hi Yuening
> I downloaded the model but can load it because I don’t have:
> …\BRep\ Aalborg\ToolBox\ Markersets\ KitVaughanMarker sR.any
> Can you zip it all together?
> Best regards Christian
> AnyBody Support
> — In anyscript@yahoogrou ps.com, yuening ma <yueningma@ …> wrote:
> > it said “3 unsolvable constraint(s) found”.
> > Now I up the model named “Jan-18” to the folder “yueningma”
> > ----- �"颅脢录茂驴陆脢录茂驴陆----
> > 茂驴陆茂驴陆茂驴陆茂驴陆茂驴陆脣拢茂驴陆AnyBody Support
<support@ >
> > 茂驴陆脮录茂驴陆茂驴陆脣拢茂驴陆anyscript@yahoogrou ps.com
> > 茂驴陆胉路茂驴陆茂驴陆脥拢茂驴é™â€
2008/1/21(茂驴陆茂驴陆�’禄),
茂驴陆茂驴陆茂驴陆茂驴陆5:18:42
> > 茂驴陆茂驴陆茂驴陆芒拢潞 [AnyScript] Re: Using the
> > Hello yuening
> > What errors do you get?
> > Best regards
> > — In anyscript@yahoogrou ps.com, “yueningma” <yueningma@ …> wrote:
> > > Hello!
> > > Now I am doing a model with a single leg. More description in the
> > > following:
> > > there are 4 marks on the leg: one is one the foot;one is on the at
> > > ankle;one is at kneemarker the thigh and the last is on the pelvis.
> > > I want to use the 4 marks to drive the motion.
> > > And I use the class “AnyKinEqSImpleDriv er”. When runing the
> kinematic
> > > analysis , the model doesn’t work. the problem must be in adding
> joints
> > > and drivers. What should I do?
> > > yuening
> > ____________ _________ _________ _________ _________ _________ _
茂驴陆脜禄茂驴陆茂驴陆茂驴陆茂驴陆盲éº"芦茂驴陆茂驴陆èŒ
‚驴陆茂驴陆茂驴陆茂驴陆脳拢茂驴陆茂驴陆茂驴陆茂驴陆茂é
©´é™†èŒ‚驴陆茂驴陆�"潞脴驴茂驴陆茂驴陆茂驴陆茂驴陆茂驴é™
†èŒ‚驴陆茂驴é™â€
> http://cn.mail. yahoo.com/ gc/index. html?entry= 5&souce=mail_
mailletter_ tagline
闆呰檸é–Â�绠å?˜ç´¶é–«'é?‚æ?¿å‹¾ç»?濈�忥ç´?æ¶"�鎬ц春é?—¢�佷ç¿
°é?ˆå¬¶ç´’
http://cn.mail. yahoo.com/ gc/index. html?entry= 5&souce=mail_ mailletter_
tagline
雅虎邮箱传递新年��,个性贺��亲朋�
tagline
___________________________________________________________
雅虎邮箱传递新年��,个性贺��亲朋�
http://cn.mail.yahoo.com/gc/index.html?entry=5&souce=mail_mailletter_tagline
