In the gait example “GaitLowerExtremity (AMMRV1.3)”, the model is driven by the joint angles calculated by the trajectory of the markers. This is realized through [SIZE=3]#include[/SIZE] “JointsAndDriversOptimized.any” [SIZE=2]by using the data from a .txt. However, I cannot figure out how the ground reaction force is applied to the model. Is it applied to the force plate first and then to the part foot in contact with the plate, or applied directly to the foot? Which part of the script specifies how this is realized. [/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]Thanks in advance.[/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]Cheers,
Jerry
[/SIZE]
