When I am trying to settled the problem of adding vibration function, There is a question, when examining the abdomen muscles' activation. For example, Multifidi muscle, I noticed this muscle is divided into many blocks, when performing the inverseDynamics, The results are as follows:
if want to know Multifidi muscle's activation , How can I do? to take the average of all the values?or to add up all the values, or to take the maximum of all values?or to take the square root of the sum? or by any other algorithm?
Could you tell me how to solve it?
zhong
You use the built in function in AnyBody like max min mean to create one number out of a vector of numbers. I am not sure what is the correct answer in this case it depends on what you want to obtain, a max number would be a somewhat reasonable choice ii guess it would give the muscle envelope.
