CAD files into Anybody
Hey, I want to use the CAD file of the crutch I designed inside Anybody. I want to use it in the inverse dynamics analysis but I just don’t understand AnySurfSTL. I’m sort of following the FDK example (https://anyscript.org/tutorials/ForceDependentKinematics/lesson4.html). I’m trying by creating an AnySeg file and then using AnySurfSTL. It loads but I’m not seeing the crutch in the model viewer. I’m probably misunderstanding how to use AnySurfSTL, please help.
You should put your STL file in the same folder where your AnyScript files are located.
