Gait lower extremity model data is obtained from used motion data + Ground Reaction Force
(muscle activity, torque, etc…)
can I get inverse activity data from BIKE3DMODEL like Gait lower extremity model does?
I have acquired a pedal force data and pedal coordination
Could you get both the motion capture and the pedal force data of the pedaling motion?
Then you can just use the gait lower extremity model using your experimental data.
Applying only the pedal force on the existing Bike3DModel does not make sense.
yes, I have both the motion capture and the pedal force data
I using motion capture system(Motion analysis)
program is EvaRT, Cortex
can I make valuable c3d data?
As I advised you already,
you can try our MocapModel with your C3D file.
http://wiki.anyscript.org/index.php/NEW:_How_to_setup_your_own_MoCap_driven_Model
