Dear AnyBody team,
Which multifidus muscles I should use if I want to turn off only muscles attached to L3? Is it the one that ends or begins with L3, L3L5 or T12L3 for example?
Thanks a lot
Dear AnyBody team,
Thanks a lot
Hi @faa198501
Yes, that should be the ones. If you are in doubt you can inspect their origin/insertions/via points in the model tree.
Bjørn
