Detailed hand model
Hello;
When working with the AMMR v1.6.2 and AnyBody Modeling System v6.0.6 , I wanted to turn on the detailed hand model in the StandingModel demo model, simply by defining the two body model parameters as follows:
#define BM_ARM_DETAIL_HAND_RIGHT CONST_HAND_DETAILED
#define BM_ARM_DETAIL_HAND_LEFT CONST_HAND_DETAILED
When I try to load the model I receive the following error message:
Scanning…
Parsing…
Constructing model tree…
ERROR(SCR.PRS9) : C:/U…s/Can/D…p/D…O/A…o/A…n/E…s/S…l/M…l/RightHandDrivers.any(10) : ‘CMCFlexion’ : Unresolved object
Model loading skipped
Do I need to define other model parameters to get the detailed hand model working?
Best Regards…
Hi Can,
There is a minor typo in the code, which has not been found yet:
…HumanModel.Right.ShoulderArm.Seg.Hand.Finger1.Jnt.CMCFlexion;
Should be:
Please search/replace " …HumanModel." into " …HumanModel."
Thanks for spotting the problem.
Thank you Pavel;
I have updated the two effected files RightHandDrivers.any and LeftHandDrivers.any and the model loads and runs successfully now.
I am attaching the updated files for reference here, in case someone else is interested in the subject.
Best…
Can
Hi Can,
Thanks for the files. I have also changed them in the official repository, it should be fixed starting from the next official version.
