Hello
can i visualize COM (center of mass) during analysis in fullbody main, I am not sure where to add the draw line in the code in full body main under mocap examples, could someone guide me through this.
Hi Bharathhs,
I think the code below would do the trick
you can add it in eg. Labspecific.any file
AnyFolder ShowCoM ={
AnyKinCoM CoMMeasure = {
AnyFolder& ref = Main.HumanModel.BodyModel;
AnyDrawSphere Sphere ={
RGB={0,0,1};
Position = .CoMMeasure.Pos;
ScaleXYZ={1,1,1}*0.2;
Hello
the above code of yours works perfectly fine. and it is possible to visualize the COM sphere in the boy model. I want to also know how to get a line through the center of mass. I tried to draw a reference frame from the center of mass sphere but it doesnt move with the position of the sphere. is there a way to have a line from the COM sphere to the ground. So visually i could check the COM and COP lines overlap for a ballet dancers during turn movements.
AnyFolder Interface = {
AnyKinCoM CenterOfMass = {
AnyFixedRefFrame GlobalRef ={
Origin={0,0,0};
AnyDrawRefFrame drw={
ScaleXYZ=0.6*{0,0,-1};
AnyDrawSphere COM_ball ={
RGB={1,0,0};
Position = Main.HumanModel.BodyModel.Interface.CenterOfMass.Pos;
ScaleXYZ={1,1,1}*0.1;
If you have any solution for this. It would be a great help.
thank you
Hi Bharathhs,
Sorry for the slow answer, please see the object AnyDrawLine it can draw a line between two points "p0" and "p1" i think this will be the easiest way to do this.
thank you so much
yes it works.
