Dear Sir/Madam
I am working on inverse dynamic analysis for squatting motion but I’ve got error as following. Could you check what is wrong?
I attached all files in working folder.
Thank you
Seungkook Jun
1.0) Inverse dynamic analysis…
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Pollicis_Brevis.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Hand.Ref.Via1_Extensor_Pollicis_Brevis’ on ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Mus.Extensor_Pollicis_Brevis.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Pollicis_Longus.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Hand.Ref.Via1_Extensor_Pollicis_Longus’ on ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Mus.Extensor_Pollicis_Longus.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Pollicis_Brevis.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Hand.Ref.Via1_Extensor_Pollicis_Brevis’ on ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Mus.Extensor_Pollicis_Brevis.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Pollicis_Longus.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Hand.Ref.Via1_Extensor_Pollicis_Longus’ on ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Mus.Extensor_Pollicis_Longus.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : serratus_anterior_6.SPLine : Penetration of surface : EllipsoidSurf : Via-point ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Scapula.I_serratus_anterior_6’ on ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Mus.serratus_anterior_6.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Trunk.SegmentsThorax.ThoraxSeg.ij.EllipsoidSerratusAnteriorOrigin.EllipsoidSurf
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Digitorum__Digit2.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Hand.Ref.Via_Extensor_Digitorum_Digit2’ on ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Mus.Extensor_Digitorum__Digit2.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Digitorum__Digit2.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Hand.Ref.Via_Extensor_Digitorum_Digit2’ on ‘Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Mus.Extensor_Digitorum__Digit2.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Right.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
WARNING(OBJ.MCH.KIN7) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : Extensor_Carpi_Radialis_Brevis.SPLine : Penetration of surface : cyl : Via-point ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Hand.Ref.Via_Extensor_Carpi_Radialis_Brevis’ on ‘Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Mus.Extensor_Carpi_Radialis_Brevis.SPLine’ is located below the wrapping surface 'Main.Studies.HumanModel.BodyModel.Left.ShoulderArm.Seg.Radius.MedialExtensorCyl.cyl
ERROR(OBJ.LIB.OOS1) : C:/U…s/SK/A…a/R…g/A…y/A…x/A…4/Body/A…n/Arm/Muscle.any : subscapularis_3.SPLine : Unexpected exception in the library OOSol :
OOSol exception : MISSING MESSAGE.
