Hello dear Anybody team,
I am modeling a task with Anymocap(simple gait). I get a lot of warnings about the penetration of surface via points, but I do not get any errors, and the inverse dynamics is run without any problems. I wonder if this has any problems and can affect my results( compression force on L5-S1). The warnings and the picture of my model is below. Thanks for your help.
) Operation Sequence: (Operation: Main.RunAnalysis):
0.0) Operation Sequence: (Operation: Main.RunAnalysis.LoadParameters):
0.0.0) Operation Sequence: (Operation: Main.RunAnalysis.LoadParameters.SubOperations):
0.0.0.0) Dummy operation: (Operation: Main.RunAnalysis.LoadParameters.SubOperations.dummy):
0.1.0) Load_parameters (Operation: Main.ModelSetup.Macros.Load_parameters):
Macro command : Load_parameters(1:10)> classoperation Main "Load Values" --file="C:\Users\user2\Documents\AnyBody.7.3.x\bahramian\Application\MocapExamples\Plug-in-gait_Simple\Output/FullBody_st60 50 0.anyset"
Loading and overriding values from : 'C' ...
...Values updated
Macro command : Load_parameters(10:10)> classoperation Main "Update Values"
Updating expressions...
WARNING(OBJ.MCH.KIN7) : Mus.any(875) : VastusLateralisInferior1.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisInferior1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(895) : VastusLateralisInferior2.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisInferior2Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(908) : VastusLateralisInferior3.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisInferior3Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(921) : VastusLateralisInferior4.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisInferior4Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(934) : VastusLateralisInferior5.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisInferior5Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(947) : VastusLateralisInferior6.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisInferior6Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(962) : VastusLateralisSuperior1.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisSuperior1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(975) : VastusLateralisSuperior2.SPLine : Penetration of surface : cyl : Via-point 'VastusLateralisSuperior2Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(990) : VastusMedialisInferior1.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisInferior1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1003) : VastusMedialisInferior2.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisInferior2Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1018) : VastusMedialisMid1.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisMid1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1031) : VastusMedialisMid2.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisMid2Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1045) : VastusMedialisSuperior1.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisSuperior1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1058) : VastusMedialisSuperior2.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisSuperior2Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1071) : VastusMedialisSuperior3.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisSuperior3Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1084) : VastusMedialisSuperior4.SPLine : Penetration of surface : cyl : Via-point 'VastusMedialisSuperior4Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1127) : VastusIntermedius1.SPLine : Penetration of surface : cyl : Via-point 'VastusIntermedius1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1140) : VastusIntermedius2.SPLine : Penetration of surface : cyl : Via-point 'VastusIntermedius2Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1153) : VastusIntermedius3.SPLine : Penetration of surface : cyl : Via-point 'VastusIntermedius3Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1166) : VastusIntermedius4.SPLine : Penetration of surface : cyl : Via-point 'VastusIntermedius4Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1179) : VastusIntermedius5.SPLine : Penetration of surface : cyl : Via-point 'VastusIntermedius5Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1192) : VastusIntermedius6.SPLine : Penetration of surface : cyl : Via-point 'VastusIntermedius6Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1207) : RectusFemoris1.SPLine : Penetration of surface : cyl : Via-point 'RectusFemoris1Node' on 'SPLine' is located below the wrapping surface'cyl
WARNING(OBJ.MCH.KIN7) : Mus.any(1230) : RectusFemoris2.SPLine : Penetration of surface : cyl : Via-point 'RectusFemoris2Node' on 'SPLine' is located below the wrapping surface'cyl
...Finished updating expressions
1.0) Operation Sequence: (Operation: Main.RunAnalysis.MarkerTracking):
1.0.0) Operation Sequence: (Operation: Main.RunAnalysis.MarkerTracking.SubOperations):
1.0.0.0) Dummy operation: (Operation: Main.RunAnalysis.MarkerTracking.SubOperations.dummy):
1.0.1.0) Kinematics (Operation: Main.Studies.MarkerTracking.Kinematics):
1.0.1.0.0) PreOperation (Operation: Main.Studies.MarkerTracking.Kinematics.PreOperation):
1.0.1.0.0.0) InitialConditions (Operation: Main.Studies.MarkerTracking.InitialConditions):
1.0.1.0.0.0) ...Design variables have been updated.
1.0.1.0.0.1) ...Load-time positions have been re-established.
1.0.1.0.0.1.0) PreOperation (Operation: Main.Studies.MarkerTracking.InitialConditions.PreOperation):
1.0.1.0.0.1.0.0) Operation Sequence: (Operation: Main.ModelSetup.Views.SetViewMacros.KinematicView):
1.0.1.0.0.1.0.0.0) mcr (Operation: Main.ModelSetup.Views.SetViewMacros.KinematicView.mcr):
Macro command : mcr(1:1)> classoperation Main.ModelSetup.Views.KinematicView"Set View"
1.0.1.0.0.2) ...Kinematic analysis completed.
1.0.1.0.0.3) ...Dependent variables are fully updated.
1.0.1.0) Kinematic analysis...
and the picture of the model is here.
