After inverse dynamics simulation, I’m going to report the results. I have a question about the magnitude of Muscle forces and powers. How can I report just a number (or graph) for each muscle while In the results tree, there is not just one number for each muscle? Some examples are:
First Example: Tibialis anterior results consisted of: TibialisAnterior1, TibialisAnterior2 and TibialisAnterior3. or Gluteus Maximus consisted of GluteusMaximusSuperior1, GluteusMaximusSuperior2, …, GluteusMaximusSuperior6.
What should I do to find the force generated in these muscles? Should I sum these numbers or make an average?
Second example: The results for psoas muscle consisted of:
Muscle branches in the model are a simplified representation of a complex muscle architecture. For example, the Psoas Major muscle attaches to many different vertebra and depending on the tasks some will activate, some will not.
Similarly to very wide sheet muscles - some parts could be activated separately. Example
You would have to decide yourself what it is you are after. Depending on your task you could, for example, if focus on forces acting on L1, then you would choose a particular Psoas Major branch. But say you focus on pelvis - then you could compute a net force for a particular muscle/muscle group.
