Modify BackPack Model
I want to modify the BackPack Model. The originally model has a left and a right strap... I want a strap diagonally across the upper body and strap around the waist.
  1. If I use the original right Strap and the modelled waist strap it works but the BackPack turns to the right. Why?
Code for the original right strap:
AnyKinPLine RightStrap={
AnyRefNode &ref1=.BackPack.TopStrapNodeRight;
AnyRefNode &ref2=..HumanModel.Right.ShoulderArm.Seg.Clavicula.StrapNode;
AnyRefNode &ref4=..HumanModel.Trunk.SegmentsThorax.ThoraxSeg.RightShoulderNodeFront;
AnyRefNode &ref5=.BackPack.BottomNodeRight;
AnyDrawPLine strap={Thickness=0.01; RGB={1,0,0};};
  1. If I model a strap diagonally across the upper body there is an Error during the kinematic analysis... Why do I get that Error?
Code for the diagonally strap:
AnyRefNode &ref4=..HumanModel.Trunk.SegmentsThorax.ThoraxSeg.LeftShoulderNodeFront;
AnyRefNode &ref5=.BackPack.BottomNodeLeft;
Can somebody pls help me?
I attached the model.
Thank you in advance.
Best
Stefan
Dear Stefan,
Attached please find a modified version of your model.
Of course here I assumed this AnyKinPLine can replicate a kind of the shortest path across this thorax segment.
But if would be better in you can use the AnyKinSPLine to implement the strap with a proper bounding ellipsoid on top of the thorax segment.
Thank you very much Moonki !!!
It works :smiley:
But why did you change the DriverPos from {0.63} to {0.63+0.15}?
DriverPos={0.63+0.15};
Best
Stefan
Hi Stefan,
Because those drivers will determine the lengths of the straps.
Because I changed the path of the strap, it had to be longer than before to keep a similar relative location of the backpack segment with respect to human thorax.
