muscle recruitment type for GaitLowerExtremity
I did not find the muscle recruitment type in GaitLowerExtremity.any.
Does GaitLowerExtremity.any uses the default recruitment type? If so, please could you let me know which type is the default.
If I want to change the recruitment type, I guess I should add the following line in GaitLowerExtremity.any:
InverseDynamics.Criterion = {
Type = MR_Quadratic;
UpperBoundOnOff = Off;
nStep=Main.ModelSetup.nStep;
Gravity ={0.0, 0,-9.81};
tStart = Main.TrialSpecificData.tStart+2Kinematics.ApproxVelAccPerturb;
tEnd = Main.TrialSpecificData.tEnd-2
[SIZE=2]
The above lines are in [SIZE=3][SIZE=3]
AnyBodyStudy[/SIZE] InverseDynamicStudy = {…}
[/SIZE]If I change these lines, can I get a different muscle recruitment type?
Thanks in advance.
Jerry
[/SIZE]
Yes. You are right. You can change the muscle recruitment type as you did.
And the default muscle recruitment criteria is the polynomial muscle recruitment with power 3(p=3) if there is not any specification.
You can find this in the tutorial.
‘Inverse dynamics of muscle systems’->Lesson 4: Polynomial muscle recruitment
I hope this may help you.
