Id like to get an output file for my parameter studies, but I dont get how to use the anyoutputfile in the studies.
My code looks like this:
AnyParamStudy landmarks=
LogFile = "";
Analysis =
AnyOperation &Operation = Main.Study.InverseDynamics;
nStep = {3};
AnyDesVar offset_x = {...};
AnyDesMeasure angle ={
Val = ...
AnyDesMeasure force ={
Val = ...
AnyOutputFile outputfile = {
FileName = "test.txt"
So, how do I refer to the AnyDesMeasure Values?
And how do I create the output file that the parameter which changes and the values are all listed in the file?
I assume the file will be saved in the folder which contains the main file, right?
Thanx guys for ur help!
thanx anyways
