is it possible to perform the analysis of different subjects one after the other by changing the code like first if a 50kg subject model is loaded after the kinematic analysis and inverse dynamics steps can it perform for a 100 kg subject
Hi @99_rea
You will need to reload the model after changing the subject weight in the code.
For processing of multiple trials we have different tools.
You can automate it from Python using the anypytools library.
Bjørn
Thank you Sir for your response
Is it possible to do batch processing in AMS
Yes, batch processing is quite easily done using the anypytools library
Bjørn
Thank you sir. Is there any detailed tutorial regarding batch processing?
Yes!
The AnPyTools library contains guides on how to batch process models:
https://anybody-research-group.github.io/anypytools-docs/#guides
best regards,
Bjørn
