Hi everyone,
I would like to remove the left AdductorLongus from the MoCapModel to simulate a zero activation from this muscle (only 1 & 2 for the moment, to be sure my code is correct).
I tried to follow a thread that I found with a similar problematics(http://forum.anyscript.org/showthread.php?t=3611) but unfortunately, I do not manage to load the model.
Here are the changes I made in MoCap_FullBody.main.any :
AnyFolder Studies ={
MechObjectExclude = arrcat(
ObjSearch(“Main.Studies.HumanModel.BodyModel.Left.Leg.Mus.AdductorLongus1”, “AnyViaPointMuscle”),
ObjSearch(“Main.Studies.HumanModel.BodyModel.Left.Leg.Mus.AdductorLongus2”, “AnyViaPointMuscle”)
// Usually, there is no need to make changes in the following files. PLease be aware. that
// changes in the Kinematics and InverseDynamics may lead to model failure and/or unrealistic results:
#if MotionAndParameterOptimizationModel
#include “Model/Kinematics.any”
#endif
#if InverseDynamicModel
#include “Model/InverseDynamics.any”
#endif
What am I doing wrong ?
Thank you in advance for your help,
