STL File
I want to add a STL File (a bag) on the FreePosturMove Model.
It should be connected to the PalmJoint Node and hence is inserted
in the Arm3D File:
AnyRefNode PalmJoint={ sRel=.Scale({-0.08,-0.02,0.0})*.Mirror;};
AnyDrawSTL Bag = {
 RGB = {1, 0, 0};
 ScaleXYZ = {0.001, 0.001, 0.001};
 //Transparency = 1;
 //Face = 2;
 FileName = "bag.stl";
Unfortunately the PalmJoint Node is mirrored and thus the bag
appears on both sides of the model. What can I do to fix this
problem?
Thank you.
Thomas
Hello Thomas,
Including these lines, maybe a different path, in e.g. the Environment file
does the trick.
AnyRefNode &PalmNode1 =
Main.HumanModel.BodyModel.Left.ShoulderArm.Seg.Hand.PalmJoint;
PalmNode1 = {
AnyDrawSTL drawbag =
RGB = {1, 0, 0};
FileName = “bag.stl”;
Sebastian
Of knox40
Sent: 29. juli 2008 15:49
Subject: [AnyScript] STL File
in the Arm3D File:
AnyDrawSTL Bag = {
RGB = {1, 0, 0};
//Transparency = 1;
//Face = 2;
problem?
Thank you.
Thomas
