I want to calculate the moment of the rectus muscle to the knee joint. I wrote the code according to AnyForceMomentMeasure2 KneeNetMoment. But when I added other muscles to ObjSearch, there was no change in the MomentMeasure curve of the chart after the inverse kinetic analysis.The following two images run the same result. Can you tell me where the problem is and how to solve it? Any help would be greatly appreciate. Thank you in advance.
zzs
